Question about Kenmore 63942 Dryer
Dryer starts but doesn't stay on
I have the same problem.  My dryer starts and continues to run as long as the "Start" button is depressed.  Once released, the dryer stops.  Any suggestions?
  • 6,784 Answers
HI, this is a simple fix. replace the start button. the circuit has failed. it is no longer able to hold a closed circuit.
Posted on Jul 26, 2009
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Dryer requires start button to be depress constantly for dryer to operate
If I am not mistaken, once the timer is set and the button pushed, the motor should run and there is probably a contact in the cintrifugal switch of the motor to seal in the run circuit. On a working dryer, if you push the start button for a split second, and let go the dryer will stop. This is because the motor has not reached proper rpm and the switch is not made yet. If the switch hangs up or the switch goes bad the same symptom will occur.
Aug 30, 2011 | Roper Dryers
Our dryer doesn't stay on when you hit the start button. It turns off when you release the button.
The seal in ccircuit for run usually goes through a switch in the motor, whitch if it sticks or the switch goes bad, it wont stay running.
Aug 29, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
I have a kenmore elite gas dryer... i can push the button to start the dryer and it will start turning but will not continue once depressing the button...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 23, 2010 | Kenmore Dryers
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 10, 2010 | Kenmore 63942 Dryer
CHECK THERMAL FUSE #3392519 @ $15.00...RDS
Apr 21, 2010 | Kenmore 63942 Dryer
Clothes Dryer won't stay on after switch is depressed.
some of them dryers have a switch other than the push button located behind the console. it also has an identical heat switch beside it. if that holding switch is bad it will not stay running. of the two identical switches the run switch is on the left. good kuck.
Jan 20, 2010 | Kenmore Dryers
Dryer will not stay on after pushing start button
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
heatman101
Dec 21, 2009 | Kenmore 63942 Dryer
Dryer won't stay on. I press the start button and it won't work unless I keep the button depressed manually
Hi, your start push button is malfunctioning. simply replacing this start switch will fix your issue.
May 20, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 63942 Dryer Logo
175 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
