Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
No spark at plug i cleaned fly wheel and points and mag. i need help it is a 8 hp briggs older model engine
    Scholar:
  • 173 Answers
You need a new magneto:)
Posted on Jul 26, 2009
Troy bilt 5550 generator has no spark
you can clean the fly wheel where the magnets are an see if that helps . you might need a NEW mag.
Mar 30, 2013 | Briggs & Stratton Power Products 5,550...
How do i get the flywheel off to get to the points i have no spark
use a three prong pulley puller and pull it off before this are you sure you have points chek blad brake is disengaging befor pull fly wheel
May 13, 2012 | Briggs & Stratton Briggs Stratton...
This is a Briggs and Stratton Rototiller, Model 130292-1636-02. I think my Armature might be bad. This is a Briggs and Stratton part # 397358 with electronic trigger (starter). After cleaning my fly-wheel...
the fly wheel is touche you need no more than 5 thousands clearance between the
fly wheel and the coil for the best spark
now on the other hand if you have points on this unit its best to put in new points
and condenser and set the points the same settings as the coil
this will get spark for you
hope this helps you
good luck
bob
May 08, 2011 | Ford Mustang Cars & Trucks
Would 1988 and up points work for a 1950 something engine? and i have no spark no matter what would that maybe just be the points?
check your flywheel gat to mag I use a machbook (paper) should be fimne as far as the points they should work fine mmine has on the older engens of corse check your gap and kill switches
good luck
Oct 24, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
No spark on 2hp briggs&stratton engine after washing engine
Sounds like an old points engine. To do the drying right you should probably pull the cover then pull the fly wheel then remove the points cover and clean out any water. other then then cleaning the points you might let it sit out in the sun till it dries out and then give it a go. A few hours in the hot sun should warm it enough to do the trick.
Jul 22, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
This engine is an old 8horse on a snowblower. it has no spark and the plug is good. so is the coil bad and is the coil the piece that sits above fly wheel,and does the fly wheel need to come off to connect...
doesn't mean coil is bad, may just need points and condensor. They get old and wear, old b/s part no. 299061 , these are under flywheel , and points cover. either replace points and condensor or try cleaning them with flex file.(temp. repair) points gap is .020. not sure of air gap of coil to flywheel. coil can be tested at most shops, You will be able to see if points are burnt visually. hope this helps.
Jan 13, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
r/David
Dec 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
24 horse brigs with 100 hrs has no fire. Help
You can take the engine shroud off and clean the magnets on the fly wheel. Also clean the two little prongs that are close to the fly wheel. They will rust up and you won't get the pulse needed for the spark plug. With the shroud off check any wires that might be damaged. Mice like to make nests in the engines and love to chew on the wires. When cleaning the fly wheel magnets use emery cloth or fine sand paper. Also check the connector that attaches to the spark plug. In you didn't replace spark plug I would suggest doing so.
Good luck. Let me know if this helps.
roundo4
Aug 15, 2009 | Briggs & Stratton Garden
No spark
if you have no spark and a good plug then you have a bad magnito it is what your plug wire comes from and it is mounted next to your fly wheel or fan the part that the pull cord is attached to it creates the spark every time the maganets on the flywheel pass it it could also be out of adjustment also it needs to be very close to wheel without touching it i would try and adjust it first loosen the screws on the magnito and slide a piece of high quality printer paper between the wheel and magnito then tighten it down then pull your paper out if you can not then you need to move magnito back more you want the paper snug in there but able to pull it out now after doing this spin the whell around and make sure there is no touching between parts now check for spark oh make sure magnito is not to far away if you can slip a buisness card between the two you are to far apart if you still have no spark replace magnito but check the plug wire first make sure it is good good luck briggs are good motors you should be able to get part s without trouble also
Jun 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Not firing
After you check the key and key way,Check the coil wire to see if it has any breaks in it,If no breaks are present,Replace the coil.
Jun 02, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
79 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
