Question about iRobot 5800 Scooba Vacuum
My iRobot scooba won't turn on after a full charge
When I press the power button, the light won't come on. When I pressed the power button on low battery, the power button lit up red. So later on I charged it. During the charge the power button was green, so the problem isn't a burned out light.
    Champion:
  • 363 Answers
Do you have the charger terminal, or do you have the charger that you have to take out the battery and charge. Because I have found that my base terminal charger works better than the battery charger that needs the battery to be removed to charge.If you have the terminal charger and the power light is green when it is in the charger I would start from the terminal
Posted on Jul 27, 2009
Have Scooba 340 that won't power on after battery fully charged!
No repair services anywhere, unfortunately. It does sound like you might need a new battery, but the issue could also be the power button. I suggest giving us a call at 1-877-855-8593 so that we can more accurately determine what the problem might be and how we can most efficiently help you to solve it.
Fembot
iRobot Tech Support
Aug 15, 2009 | iRobot 5800 Scooba Vacuum
Scooba battery light turns red as soon as irobot starts
Do you leave the battery on charge long enough? Try 4-hours up to overnight. If so, then the battery is probably at the end of it's useful life. Getting a new battery depends on cost versus life expectancy of the robot and whether it does the job you want it to do.
Jul 19, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Scooba now stops sooner and isn't finished cleaning :-(
I had this problem and contacted irobot. An important fact was left out of the early edition user manual to not leave the battery charging for an extended amount of time. Because of this ommision, they sent me a new battery and a software upgrade for the scooba. I just followed the directions and attached the little device they sent to do the upgrade the scooba and it fixed the battery problem.
Hope this helps.
Jul 17, 2009 | iRobot 5800 Scooba Vacuum
Scooba says check tank and won't move.
Rinse the four ports on the underside of the tank with warm water, particularly the round opening that covers your Scooba's vacuum port and the curved one that matches the filter. Odds are, there's a clog in there and your Scooba knows it. Rinse the two oval ports as well, as thoroughly as you can.
Also, try priming the pump with water. The iRobot website shows how to do this under the Scooba troubleshooting section.
Then run the unit with water and vinegar (in place of the Clorox Cleaning Solution) if possible.
May 10, 2009 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
Scooba won't turn on
It sounds like you've got a finicky power button. Not a lot that can be done about that, but you may want to try getting your hands on the old-style Roomba remote, the black one. The power button from that will power on a Scooba, though you can't start a cleaning cycle that way. This might allow you to bypass the Scooba's power button altogether.
May 08, 2009 | iRobot 5800 Scooba Vacuum
Scooba in diagnostic mode
This is a common issue :)
his morning, I turned on my Scooba and it started beeping a scale of tones and blinking all its lights in sequence. After an hour or so of resetting, cleaning, disassembling, researching, and scratching my head, I stumbled across the solution on Roomba Review. But, for me at least, it was even easier than all of that. I don't have any of my own pictures for this procedure, but it's pretty straight forward.
  • Remove the battery and power.
  • Remove the two screws holding the bumper shell in place and remove it.
  • Carefully peel up the sticker with the control buttons on it. This sticker is actually the control panel. There is a data cable attached to it just below the "Clean" button. Be careful not to break it!
  • Clean the surface under the sticker with some isopropyl alcohol. (I didn't actually have to do this, but I'm sure it doesn't hurt.)
  • Gently replace the "sticker" (i.e. control panel) and make sure it's completely flat.
  • Check to see if it works again. If not, repeat.
  • Replace the bumper shell and screws....
thnx.
Jan 23, 2009 | iRobot 5800 Scooba Vacuum
Stuck on check tank indicator
If your Scooba's Green Check Tank light is coming on immediately on startup, please try the following steps:
1. Remove and reseat Scooba's battery, ensuring that you hear it click into place.
2. Remove and reseat the brush head
3. Remove and reseat the vacuum port and filter. When replacing the filter, be sure to press firmly into the hole. There is a magnet on the filter that must connect with the magnet on the Scooba.
4. Fill Scooba’s Clean Tank with approximately 1 cup of cold water, shake vigorously, and empty it to remove any debris in the tank.
5. Empty the Dirty Tank, refill with water, and slosh it around to pick up any sediment. Empty the Dirty Tank again.
6. Refill Scooba’s Clean Tank with water, adding a pinch or two of table salt. Run the Scooba. If the issue persists, please follow the steps below:
With the tank removed, press the Power button and then the Clean button.
If the robot tries to start a cleaning cycle, power off the robot and repeat, pressing the Power button first and then the Clean button. If the pump makes a “whirring” or squirting sound and the robot does not start a cleaning cycle (Check Tank indicator will light), this indicates that the pump is working. Replace the tank and try starting a new cleaning cycle with the tank on.
If Scooba does begin a cleaning cycle the second time you press the Power and then the Clean button with the tank removed, the pump valve could be blocked with debris. Using a turkey baster, straw or sports bottle, force water through Scooba’s solution valve. Confirm that the baster, straw or sports bottle fits snugly over Scooba’s solution valve, push water through the system at least three times, and then try re-starting Scooba.
Below is a link to a diagram of these steps for visual reference:
Title: Scooba is not putting down cleaning solution
http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/std_adp.php?p_faqid=322&p_created=1167154849
Nov 01, 2007 | iRobot 5800 Scooba Vacuum
Scooba 5800 Power button Red Blinking (Continued)
As for which one has the problem, I would say it has to be the battery. Rechargeable batteries of all types are known to have similar characteristics, one of which is discharging the batteries to maintain good rechargeablility. At least one person has demonstrated this for the Scooba battery in the roombareview.com forums when he brought a "dead" battery back to life. He allowed the battery to slowly and completely discharge using a 12-volt automobile bulb, followed by recharging the battery on the Scooba external charger. This procedure brought his "dead" battery back to a full charge! However, other forum members have reported that many have experienced problems with Scooba battery life, and that as a consequence of this iRobot will replace your battery if you call them and report a short-life battery problem. You can contact iRobot at (800) 727-9077 if you would like to report a battery problem and request a replacement.
Aug 07, 2007 | iRobot 5800 Scooba Vacuum
iRobot 5800 Scooba Vacuum Logo
1,834 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
