Question about McCulloch FH160G Pressure Washer
I need a switch fo a Mcculloch FH140A or rocker parts
I need a swich fo a Mcculloch FH140A or parts gsm100@juno.com
  • 2,176 Answers
The switch number I found is 7022140A02 and list is 2.84. You can go to McCullochpower.com and find a dealer near you or order the part online. You can follo the links to look at the same breakdown I found for other parts
Posted on Jul 27, 2009
I am looking for the owners manual. Do you know where I can get one?
Go to the McCulloch web site you can down load and or print your manual.
May 30, 2011 | McCulloch 1400 Psi Electric Pressure...
Mc Culloch power washer FH140A The "on/off"
easiest way to fix it, buy a new switch at a home improvement center, the two metal piece go on the bottom and the springs are on top of them, when the switch is in the off position the metal pieces are up off the contacts on the bottom and when on the on position the metal pieces make contact. Hope this helps Tim
May 28, 2011 | McCulloch 1400 Psi Electric Pressure...
NEED AN ON OFF SWICH FOR A TWINSTAR ELECTRIC FIREPLACE HEATER SWITCH PART NUMKBER IS SR22N
If your On-Off is not working ? Go to GRAINGER and get Light Rocker Switch SPST,3 connections 2VLN1 or the Light Rocker Switch SPST, connections 1A824
both will do the job.
Nov 12, 2010 | Leisure HOMEPRIDE Electric Fireplace...
No pressure with detergent bottle on
you wont get pressure with detergent bottle on.it only sprays low pressure .just take off first section of wand,and plug it in
Jul 05, 2010 | McCulloch FH140A Electric Pressure Washer
Mcculloch power washer fh140A 1400 PSI help
the unit will only **** up solution when the pressure is low, thats how they all work so you cant use pressure at the same time. You will notice that the pressure drops when using the solution ****..
soap 1st the pressure wash.
Jul 02, 2010 | McCulloch FH140A Electric Pressure Washer
McCulloch FH160G has weak spray
There isn't much in the owners manual in the way of repairing this issue, asside from just replacing the gun. Most of the time it's as simple as an o ring, but because of their design it's easier just to replace the gun. But here's a link. http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2008/MOUS2008-FH160G-6096160G04-966989801.pdf
Apr 21, 2010 | McCulloch 1400 Psi Electric Pressure...
Removing lance from gun on McCulloch FH140A pressure washer
The Karcher is the same, and possible made the Mac. It's likely the sealing 'O' ring has deteriorated and stuck the two parts together. Try a little petrol around the joint to soften the 'O' ring. Perhaps it will come apart then. You will need a new o-ring however.
Apr 20, 2010 | McCulloch 1400 Psi Electric Pressure...
Kenmore series 90 electric dryer does not heat and shuts off after several minutes of use. Heating element is at 9 ohms, spec is 7-11.5 , thermal limit switch was open. I replaced thermal switch and...
Make sure the vent is clear.
Does the motor humm when it starts?
If it humms then the motor is bad. Make sure the rollers are not stuck or that the blower has obstructions inside.
http://www.pdxappliance.com
Feb 27, 2010 | Dryers
I need a McCulloch FH140A pressure washer spray nozzle
you will have to replace the wand which you can purchase from a reputable hardware store
Apr 08, 2009 | McCulloch 1400 Psi Electric Pressure...
McCulloch FH160G Pressure Washer Logo
256 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
