Question about Cyberhome DVR 1600 DVD Recorder
Recording from vhs to dvd with a dvr
I would like to connect vcr to record to dvd. I can't figure out what to connect to where to record. I have a vcr, separate dvr, and a satelite hooked to my tv. I'm not sure what to disconnect and where to reconnect it.
You can get a standard audio/video cable from any Radio Shack or audio equipment store. It will most likely come as a single 3-part cable with a yellow (video), white (audio left), and red (audio right) set of connectors on each end. Most equipment that's not too old will have matching color-coded sockets marked input/output. Simply plug the video/audio cable into the vcr output and the other end into the dvr input. then connect a second cord from the vcr output to the tv input. Then with everything turned you will be seeing the final signal on the tv and you can start the dvr when you are ready to start recording.
Posted on Feb 29, 2008
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
I have the Zenith XBV443. I'm trying to copy saved programs from my dvr on my tv to dvd discs. My neighbor has a simular model yet we can't find out why I'm unable to do the same. What do you think is the...
The Zenith player/recorder will be able to record to DVD from an external input such as a PVR. The most likely reasons you are unable to record successfully are:
1. The TV / DVR is not connected to the Zenith recorder correctly. You need a separate cable for recording. You cannot record using the cable that is connected for playback of DVD discs.
2. The TV / DVR does not have "VIDEO OUT" sockets
3. You have not selected the correct external input on the Zenith recorder
If you can let me know the brand and model number of your TV / DVR and how it is connected to the Zenith DVD recorder, I can let you know why it isn't working, how to make it work, and even draw you a setup diagram, if required. It's very difficult to give you the correct answer without these details.
You Zenith DVD recorder will record from the DVR - the real question is, can the DVR send video to the Zenith DVD recorder . . . ?
Feb 17, 2011 | GoVideo Go Video DVD/VCR Combo
I have a Toshiba VCR w522 and would like to record a program previously recorded from a DVR. Is it possible?
If the vcr has two scarts connect the DVR player to one and select that imput. Watch the program using the the other scart connected to the TV. Press record on the vcr and then start the DVR player going. If it doesn't have two scarts use the front panel jacks to connect the DVR player.
The only time you won't be able to record a program is if somekind of anti-copy system is employed.
Aug 31, 2010 | Toshiba W522 VHS VCR
Trying to dub from dvr to vhs vcr
Is L2 for composite video (yellow) or S-Video? Try watching a video on L2 with the composite video plugged into the back of your TV, if it works, then do the same with the DVR, if that works, then run the DVR composite video into a receiver, then the L2 from the VCR to the video out on your receiver. It's possible that the VCR won't record anything that isn't an applified signal. That's what the receiver does.
Oct 01, 2009 | Sony RDR-VX555
Recording from dvr to vhs
Check/replace the cable from DVR VIDEO OUT to VCR VIDEO IN
Apr 06, 2008 | Sony RDR-VX555
Pioneer dvr 225 recorder
the dvd recorder has to be set to monitor the program your watching! you can not copy vhs tapes to dvd this way because the tapes that are prerecorded have a copy protect feature and will nut copy right!
Dec 15, 2007 | Pioneer DVR-225 DVD Recorder
PioneerDVR-225 recorder
A lot of the functionality you are wanting is tied to the remote that you have misplaced. You can go to the Pioneer support site and order a new remote, though it is like $30.
As for wiring options to record, it depends on the inputs and outputs that are available on your television.
- Ideally, connect VCR to TV input "1", connect DVR output to TV input "2", and conect TV output to DVR. This will help you avoid any copy protection issues you run into, but not all TV sets have both audio and video output.
- If you don't have TV outputs, connect VCR out to DVR in, and then DVR out to TV in. This will definitely work, but you will have to have the DVR turned on to watch a VCR tape.
Nov 24, 2007 | Pioneer DVR-225 DVD Recorder
How Do I hook up my Sanyo DVW -7000 To my Dishnetwork Box to record?
Connect the "Out to TV"video and audio on the DVR box to the "Video in and Audio In" on the VCR ...unless it's a single screw type connector on the DVR then hook THAT to the "In from ANT/cable" on the VCR
Sep 08, 2007 | Sanyo DVW-7000 DVD Player/VCR
Hooking up (properly) a vcr to dvd recorder and recording
could be cause there is a copy write protect on the vhs
Sep 02, 2007 | Ricoh (5125a) DVD±RW Burner
HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Feb 08, 2007 | Sylvania (SRDD495) DVD Player/VCR
Cyberhome DVR 1600 DVD Recorder Logo
109 people viewed this question
Top Cyberhome Televison & Video Experts
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
