Question about Dishwashers
Not washing I have a jetwash apprx 10 years old and i get a grinding noise and it does not wash at all.
  • 6,784 Answers
Hi, there is a circulation motor that has an impeller attached to it. this is called the wash motor. it is located under the sump area. this wash impeller has become damaged and, you will need to replace it asap. this is causing the grinding noise. the impeller may be stripped or, it has slipped off the shaft. replacing this damaged impeller will fix this issue.
Posted on Jul 26, 2009
When doing laundry, it sounds like my washers gears are grinding very loudly. What would that be?
I think you are correct, I would suggest replacing it especialy if it is over 7 years old or has a lot of use. If you have oil in the wash you seal failed.
Jan 11, 2015 | Whirlpool WTW6400SW Cabrio Washer
My Maytag PAV2300 Top Load Washer is nine years old. It just started making this LOUD grinding noise when it's washing, rinsing and spinning. What could it be?
I have the same type washer and it is about the same age makes the same grinding noise as the above mentioned one. Did this person ever find a solution?
Aug 31, 2010 | Maytag PAV2300 Top Load Washer
Making clunking noise when washing an grinding noise when spinning
If it is more then 5 years old, most likly the transmision, parts are high, within $150 of buying a new one.
Jan 29, 2010 | Washing Machines
When washer is started make loud grinding noise
Very likely the bearings in the motor have begun to fail. You can replace the motor, but for a 15 year old DW, sometimes it makes better sense to just buy a new one. Depends on the features the old DW has, vs new, vs motor replacement cost.
Reply back and we can you more.
Dec 13, 2009 | Dishwashers
Maytag Performa top loader is making grinding noises
The agitators are a pop-on fit. Make sure that the agitator is firmly seated on the shaft. Lift it up and if it moves easily adjust it to the splines on the shaft and press it back into place.
Jul 29, 2009 | Maytag Performa PAV3200
Noisy wash cycle
if it's 10 year old it's not worth repairing if the transmission is bad.  However, if it's only the $20 coupler that connects the motor to the transmission.  Fix it.
Mar 29, 2009 | Kenmore 24032\24036 Top Load Washer
My 10 yr old kichenaid dishwasher is making a grinding noise do y
Well a grinding noise could come from any moving part. It could be the wash arm, motor, or pump. Remove the wash arm and clean all that you can reach with a nylon brush. If that doesn't do it, call the repairman.
Mar 20, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
