Question about Sharp LC52SB55U LCD TV
Sharp Flat Screen LCD - flashing power and OCP lights, can't get TV to turn on
  • 208 Answers
SOURCE: lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Posted on Feb 05, 2008
  • 103 Answers
SOURCE: Sharp 42" flat screen LCD T.V.
You have a bad buffer ic,which is part of the lcd panel.Definiately call sharp to get it repaired.If it doesn't have a warranty,persistence through sharp will get you results.
Posted on Mar 07, 2008
  • 53 Answers
SOURCE: No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Posted on Mar 16, 2008
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
  • 7 Answers
SOURCE: 26" Samsung flatscreen LCD doesn't power up
Just to be a little more detailed, since I just fixed this problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp lc 37sb24u both power and ocp are blinking. power power power and ocp power and ocp power and ocp repeat forever.
I have the same problem. I can get the video by pushing the power button on top of the TV after using the remote and getting the power and ocp light dance.
Nov 16, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Sharp 42 in LCD TV - POWER LIGHT IS FLASHING RED, REMOTE WILL NOT TURN IT ON OR OFF. The side power button turns it on and then it turns its self of in a couple of sections and you don't see anything on...
if your remote is good the problem of your TV is maybe a defective remote sensor and regarding with your problem of turning it on and it off automatically there is a problem in the power supply of your TV.
Nov 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Set up only visible for 2 seconds, then black - Aquous lc-37d43u
Unfortunately I can promise you that you CANNOT repair this. Your power and opc lights coming on, but the tv is not coming on. That is a issue within the tv. Give sharp a call and they will have somebody come fix your tv free of charge, if they cant fix it, they will replace it for free. That is the only thing you can do. Sorry bro
Dec 10, 2008 | Sharp LC-37D4U 37 in. LCD Television
OPC/DL light flashing Same problem of black screen and green lights flashing at power and OPC Help....
WHEN FLAT SCREEN SHARP LCD IS ON .. BLIKNING ON BOTTOM OF SCREEN SAYS OPC
Dec 08, 2008 | Televison & Video
No POWER
2x = Power Supply
3x = Main Unit
Mar 13, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Sharp LC52SB55U LCD TV Logo
508 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
