Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
Where can I get a new motor for an Intex pump model 637 or 12R
I have two Intex pool pumps and both have a blown motor. Looks like water settled in the motor and the magnet got rusted and broke. I would like to replace just the motor or just the magnet attachement if possible. Seems silly to keep buying new pumps every year for the same probelm.
  • 297 Answers
First off water should not be getting to the armature area. be carefull with how you are taking care of your pump.
secondly a 1500 gallon pump is very weak I would advise at least 2500 or even the intex 4000
the most important part of pool maintenance is circulation.
if you have time check into electric motor rebuilding in your area
but sometimes that is more expensive than buying new
also if you have a valid receipt and the pump is less than 90 days old call intex and they will send out a new one within 24 hours
good luck
Posted on Jul 27, 2009
Why the intex pool 2500 pump stops water flow after 3 hours
bad pump motor replace pump its overheating
Jun 23, 2014 | Intex Pool & Spa
No water flow e90 fault code intex pure spa
Unplug the unit. The E90 code on the intex spa is due to a dirty water flow sensor. Remove the control panel and all the screw holding the casing on. In the white plastic piece on the discharge, top hose, you will see a silver nut with a black wire coming from it. That's the sensor. The black wire is plugged into a white wire, carefully unplug it and unscrew the sensor. Clean it good and blow out the hole it goes in. This will fix the code and you will be back in business!
Sep 27, 2013 | Intex 10x30" Metal Frame Pool w GFCI
SWIMMING POOL
Just drain some of the water and add water to water down the algee guard.
Jun 24, 2012 | INTEX RECREATION G 12x30 Pool SetPump
My wife and i bought a 16 by 48 in. ultra frame intex pool. we had profesionals level the ground, we have a sandy base, and after filling our pool with water and the legs settled, the pool is approx. 2 in....
There won't be any structural problems and you will notice the difference more than anyone else. If you redo the pool next year it will help to set each leg on a patio brick so it won't settle.
May 10, 2011 | Intex Ultra Metal Frame Pool w/ Upgraded...
Need Intex Pump model #635 impeller
You know, I have made some amazing repairs on plastic items using nothing more than a soldiering iron! If you have the piece that broke off, you can carefully melt it back together. You can add more to the weld if you match the type of plastic but not too much or you imbalance it. In this case it looks like PVC. To repair it without the missing piece, form it out of epoxy putty, roughly shape it just before it sets up solid, & sand to finish.
Aug 30, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Is the intex 4000 pump any good.... do you lots filters...
I have the new 4000GPH pump and its awesome! The pump itself needs modifying just a bit. As for your pool, get rid of the plunger valves. They restrict the flow by about 1000GPH or more. There is a plastic grate in the inlet side of the pump. I just took a small file and sharpened the leading and trailing edges to smooth things up. The biggest thing is with the plunger valves. I modified some PVC fittings so I can use 1.5 inch ball valves. When my pump starts up, you see the water moving. I no longer have problems with **** settling to the bottom of my pool. Oh, and it will run an automatic cleaner with ease.
I dont recommend using the 400GPH pump with hoses smaller than 1.5 inches as there will be too much pressure and is likely to cause problems.
Mar 07, 2009 | Intex 4000 GPH Filter Pump
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
891 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
