Question about Microwave Ovens
My mongram ZE1038 oven wont heat on convection bake setting.Th fan comes on but no heat. It works on the other settings ,both elements heat heat up but on convection bake setting nothing but the fan blows,no heat and elements dont come on.Whats my solution?
  • mensamex2005 Jul 27, 2009
    Thanks, I will try this solution and see if it works and get back to you,Joseph
  • 601 Answers
Hi....
This could be due to more than one cause selector switch is faulty or
elements faulty. however this would mean both elements gone - there is one at the top and one at the bottom.
also worth while looking at the wiring to the convection elements and the thermostat.
These are the only possibality that is see of.
Thanks
Smith
Posted on Jul 26, 2009
What is convection cookong
A convection microwave is a combination of a standard microwave oven and a convection oven. It allows food cooked in the convection microwave to be cooked quickly, yet come out browned or crisped as in a convection oven. However, most cakes cannot be baked in a microwave oven - only those without an open grain structure, such as brownies. There are microwaves which contain electric browning baking elements. A true convection microwave has a high velocity forced air fan to circulate the hot air uniformly.
more about Convection microwave
May 28, 2016 | Microwave Ovens
I need the manual of my haas microwave oven HMW 43 W I want to know can i bake in my oven or not
m/w do not bake they heat up water molecules in the items that you put in them . unless it is a m/w, convection oven that has a heating element and a convection fan in addition to m/w components in it usually a metal fan visible protruding from back of inside the cavity. also m/w , convection ovens are ether over the range or together with convection oven in the wall combos and cost quite a bit more then counter top. $250 +
Jan 22, 2015 | In Microwave Ovens
Microwave not heating
In all likelihood the Magnetron, or Power Diode has failed, or perhaps even the Power Supply. You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 26, 2010 | GE Microwave Ovens
GE Profile PK916, Convc. elements stays on high
he is right in what he says the heating element is feed from the main control board
Oct 24, 2009 | GE Advantium 120 Convection/Microwave Oven
Ge convection micro combination has a problem with convection fan . fan runs for about 5 seconds, rattles, then stops. heat element gets red hot but little heat inide oven. replace fan motor or maybe more?...
I would say the convection fan blade is loose on the shaft.
If this is the case, it would try to run, but no cooling would take place, so the heat from the heating element would get very high but it would not be distributed through the oven.
The thermistor would then detect the extra high heat and stop it, I assume.
You may be able to use super glue or JB Weld to fix the blade on the shaft, as long as they are clean and dry and it is allowed to set overnight.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Accessing these components for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Jul 11, 2009 | GE Monogram ZE2160SF Convection /...
Wont heat
Hi!
Here are two instances when this happens---
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
If you find this solution helpful then do rate this solution.
Thanks
Rylee
Feb 05, 2009 | Kenmore Brew 'n Wave 63992/63999 Microwave...
Convection baking only one one side
I'm not familiar with this specific model, but I would assume it has two convection heating elments and one elment is burned out or there is a problem in one side of the wiring that powers the convection elements.
Aug 09, 2006 | KitchenAid KHMC107BT Convection/Microwave...
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
