Question about HP PSC 1350 All-In-One Thermal Printer
"Printer Cartrige Error" message and "Check Printer Cartridge" light
I get a message box appearing on my desktop simply saying "Printer Cartridge Error" and the "Check Printer Cartidge" light flashes on my printer. The printer also shows an "E" referring to error.
Any ideas on what is causing the problem and how to fix it?
Thanks,
AV
  • 1 more comment
  • Anonymous Nov 24, 2007
    I do have the same problem, but I change both cartridges with new and the message is still there
  • Anonymous Nov 28, 2007
    Same problem. Fitted two new cartridges ... no joy. Cleaned the contacts with coffee filter paper (as recommended by hp) ... still no good.
    zedaxis
    Same problem. Fitted two new cartridges ... no joy. Cleaned contacts with coffee filter paper (as recommended by hp) ... still no good.
    Sergeant:
    Champion:
  • 298 Answers
Usually means out of ink
Posted on Nov 22, 2007
Black Cartrige Missing
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
May 02, 2017 | Dell AllinOne Multifunctional (v515w)...
Cartrige error for cartrige lc39/985
what exact problem you are getting??
common solution for cartridge error.....
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
7. If no error appears, reinsert the other cartridge. Close the printer cover.
8. Replace whichever cartridge is causing the error to appear with a new genuine cartridge. Try to print a document again to verify that the problem is fixed.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 25, 2013 | Brother DCPJ125 All-In-One Inkjet Printer
Lexmark x6675, saying missing color cartrige
Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Dec 30, 2011 | Lexmark X6675 All-In-One InkJet Printer
Lexmark c534dn unsupported cartrige
This error message appears on the printer screen when the printer thinks the wrong toner cartridge is installed. To clear it or identify a service requirement, follow the steps below. NOTE: If you succeed in resolving the problem at any stage during the procedure, you not need to perform the remaining steps.
  1. Open the top front cover of the printer. If the display DOES NOT read Close cover or Insert cartridge, the 32 error is not caused by the toner cartridge and printer service will be required to fix the problem.
  2. Make sure the correct toner cartridge is installed for this printer model.
    1. Check Lexmark for a list of compatible cartridges for your printer.
    2. If the wrong toner cartridge is installed, remove it and install the correct one.
  3. If the correct toner cartridge is installed, it may not be seated correctly. To ensure that this is not the cause of the error, do the following:
    1. Turn off the printer.
    2. Reseat the toner cartridge.
    3. Close the lid.
    4. Power the printer back on and check the display.
  4. If reseating the toner cartridge does not clear the error message and the error started as soon as you installed this particular toner cartridge, the cartridge may be broken. You can check this as follows:
    1. Power off the printer and then reinstall the old cartridge. (You can also try a different new cartridge to see if that clears the error.)
    2. If the error does disappear, the problem may lie with this cartridge. Please contact the point of purchase, especially if the cartridge is brand new out of the box.
  5. If the error cannot be cleared by putting in a new toner cartridge or one that is known to be working, the printer may require service to fix the problem.
Feb 15, 2011 | Lexmark C534dn Laser Printer
Message says Remove and check color cartridge. We
The cartridge cavity in the printer may need cleaning.... perhaps a colorful "spit wad" is lodged in the cavity.
If the printer will allow, run a "clean nozzle" utility from the printer or computer.
Hope this helps!
Sep 08, 2009 | HP Officejet 7210 All-In-One InkJet...
Black Cartridge
Hi - If you are saying that the right side cartridge is the black cartrige that you have replaced, then I have two suggestions that may help. If the cartrige is a new HP genuine product I would take it back. If not, I would return the cartrige you have and buy a genuine HP for the printer. Though an expensive solution, there is always a chance of defects from either party. The remanufactured or refilled cartrige will have a date on it. The circuit board on these can wear out and then not be recognizable over time. Second suggestion if you have not already done this, a cotton swab or Q tip dipped in distilled water(damp only) to wipe down the circut board on the printer where the cartrige will connect to it, may help. Turn off the printer to do this. Make sure it is dry when you turn it on and reinstall the new cartrige. Hope this helps.
Jul 07, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Unable to resolve 'cartridge has been changed' error message
turns out the wrong paper size was selected in the print setup. I set it to Postcard (4x6) and it began working perfectly again. Hooray.
Jun 01, 2009 | Canon SELPHY ES30 Thermal Photo Printer
Printer error message ''Cartridge error''
just check the no. of the cartrige & is it org. or compatiabe
Nov 14, 2008 | HP OfficeJet 4255 All-In-One InkJet...
6150 Lexmark
is printer Cartridge new? if now try to purchase new cartridge. If it doesnt work your print cartrige is the problem.
Jan 17, 2008 | Office Equipment & Supplies
Printer is not working
Hold set-up button and , still while holding set-up button, press the option button, should be ready to go now!
Nov 07, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 1350 All-In-One Thermal Printer Logo
240 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
