Question about Apple iPhone 3GS Black (16 GB)
The iPhone does not ring, only vibrates
It does not ring, only vibrates
  • 39 Answers
There's a switch on the left side at the top of the iphone that turns the ringer on and off. Make sure this is towards the front of the phone to enable the ringer
Posted on Aug 06, 2009
  • 17 Answers
Sometimes, the phone for some reason will not recognize that you switched the sound back on with the switch on the top left side. Try silencing it again and then turning to back to volume. If this doesn't work, simply turn the phone off and back on.
Posted on Aug 19, 2009
2 Suggested Answers
SOURCE: iphone doesnt vibrate
I had the same problem: my phone wouldn't vibrate at all... I read a lot on other forums and found the following solution: If you turn the phone face down, and hit it on the metal side a couple of times (I hit it with just enough force not to cause it any damage) the vibrate will come back on. I almost didn't believe this, until I tried it.
Good luck to you all.
Posted on Mar 20, 2009
How to removed or turn off the vibration on the phone?
What phone you have would be useful to know but for
Android : How to Turn off Sound and Vibration in Androids Keyboard
Iphone: If you set the iPhone to vibrate in silent mode, it still makes an audible buzzing sound that may bother or disrupt others. If you need your iPhone to stay completely quiet, temporarily disable vibration. You can turn off vibration when silent mode is on, off or both. Tap the button next to "Vibrate on Ring."
Blackberry:
Turning vibration on my mobile phone on or off
  1. Find "Notifications" Slide your finger down the display starting from the top edge of your mobile phone. ...
  2. Turn vibration on or off. Tap the indicator next to Vibrate to turn the function on or off.
  3. Exit.
Nov 09, 2015 | Cell Phones
Iphone 3g no ring no vibrate when keypad lock and screen off, but when i unlock and screen on i got ringtone and vibrate for calls
Hello, I also meet this error about my iphone, I get many help from this forum, and also bought many DIY repair tools from china supplier, and vipprogrammer help me fix this error. maybe you can try it. or contact they WhatsApp:+ 8615986801289
Link: http://www.vipprogrammer.com.
hope can help you!
Aug 04, 2017 | Apple iPhone 3G
My iPhone incoming calls ring but do not vibrate, but all other notifications vibrate correctly.
Strange. I would try resetting your iPhone. Hold down the home and power buttons until it powers off. It should start up automatically but if not just press the power button. This has worked for me in the past when my iPhone has acted strangely.
Don't worry about a reset or hard reboot. You won't lose any data or settings.
Aug 06, 2012 | Apple iPhone 3GS Black (16 GB)
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
Aug 02, 2012 | Apple iPhone 3G
I PHONE WILL NOT RING BUT VIBRATES
There is a small knob on the left of the iphone. If you can see small tiny red dot there, then your phone is on vibrate mode. Switch that on. Your phone will get back into ringing mode..
Cheers!!
Guru..
Dec 30, 2010 | Apple iPhone Smartphone
My iphone doesn't ring or vibrate, but does with earplugs on.
hey bro,
i fix more problem like your's. by change the flex up. with volume+vibrat button+headphone.
change this and all your problem will be good.
memeh Fixphone
Mar 29, 2010 | Apple iPhone 3G
I would try a system restore, plug your iPhone into iTunes and click restore, it will delete everything but once its done it will restore it to when your last sync was.
Mar 29, 2010 | Apple iPhone Smartphone
Iphone doesnt ring
Is the volume up fully (click on the volume buttons on the side)
Is it on vibrate? Very easy to inadvertently knock the sound switch to vibrate, which is located next to the volume buttons.
Hope this helps. Let me know if it doesn't.
BReady
Mar 25, 2010 | Apple iPhone Smartphone
İPhone not ringing
you can actually move the button , on the top left hand side of your iphone, over the ringer volume, you will see a red or orange dot, this means the switch has you iphone in silent mode, I was stuck on this, until I found it is a actual switch, look at it closely, you can move it. So where you see the red dot, put your finger on it and move it the opposite way, and I do not mean press the button, I mean, flip the switch on it, then your phone will not be in silent mode anymore,,, this was very annoying, I hope it helps anyone that has the same problem.
cheers!
Nov 15, 2007 | Apple iPhone Smartphone
Apple iPhone 3GS Black (16 GB) Logo
5,859 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
