Question about Nintendo Wii Console
No power console power light will not go on and unit is plugged in
    President:
  • 1,188 Answers
Check power cable preferably with a multimeter to detect high resistance. If resistance is negligible then it may be the internal fuse. See owner's manual to see how to check for fuse. I have assumed that you have a socket delivering correct voltage to your console.
Posted on Jul 26, 2009
I have 3 red lights on my x-box 360 RROD .Can this be fixed
  • Turn off your console.
  • Disconnect the power cord from the back of your console. Unplug the power cord from the electrical outlet and the power supply unit.
  • Reconnect the power cord to the console. Then plug the power cord back into the electrical outlet and the power supply unit.
  • Turn your console back on.
  • Jun 26, 2011 | Video Game Consoles & Games
    My power supply is blinking orange when i put it in the xbox 360 what do this mean.
    Hello.An orange light is illuminated on the power supply for one of the following reasons:
    a The console is turned off.
    b The power supply is disconnected from the console.
    c The power supply cord is not fully inserted into the power socket of the console.
    d The power supply is faulty.
    e The console is faulty. (The console might be faulty if it does not turn on when the power supply light is orange.)
    The power supply has several built-in safeguards to help prevent damage to either your Xbox 360 console or the power supply itself. The power supply will automatically turn off if either the current flow, the voltage, or the temperature is too high. When the power supply turns off for any of these reasons, the light on the power supply will turn from green (normal) to orange or to red, or the light will turn off. When the power supply light is green, the power supply is working correctly. What you are experiencing is an over heating issue, that may have damaged the supply.
    With that being said, i would try to reset the supply by disconnecting the unit form the console, and unplugging the power supply unit form the wall socket for 5 minutes. Once the 5 minutes have passed, reconnect the unit to the console, and plug the power supply into the wall socket. If the console dose not power up, and the supply unit is still showing an orange illuminated operating light, this will confirm that the power supply unit will need to be replaced. Contact Microsoft for the correct replacement parts needed(power supply unit)
    TIPS FOR PREVENTING OVERHEATING ISSUES
    1 Do not block any ventilation openings in the power supply.
    2 Do not put the power supply on a bed, on a sofa, or on any other soft surface that might block ventilation openings.
    3 Do not put the power supply in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
    4 Do not put the power supply on a stereo speaker, an amplifier, or a heat source such as a radiator or a heat register.
    5 Do not use an unlicensed accessory, such as a replacement power supply that was not manufactured by Microsoft, or any accessory that plugs in between the Xbox 360 console and the power supply.
    6 Plug the power supply directly into a working wall outlet. You may have problems with the power supply if you use an extension cord or a power strip if the extension cord or the power strip is faulty or cannot supply the required power to the console.
    7 If you are not sure about the reliability of an AC power outlet, power circuit, or power cabling, do not use it. Contact an electrician.
    Apr 15, 2011 | Microsoft Xbox 360 Console
    Orange light 3 flashing
    Check your power supply cables Your power supply cables may not be fully secured. Let's unplug and reconnect your power supply
    1. Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and the power supply unit.
      Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit
    2. Make sure that all three connections are firmly secured.
    3. Turn your console back on.
    Check the light on the power supply. If this solution worked, your power supply light will be green
    Dec 29, 2010 | Microsoft Xbox 360 Console
    My xbox has a three light red ring
      Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit.
      Check the light on the power supply. If this solution worked, your power supply light will be green and the power button will look like this:
    My older xbox 360 has 3 segments of the red ring appearing. Can this be fixed? My son thought this could be fixed by microsoft at no cost to me. Is this true? If so, how can I accomplish this?
    2. Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit.
    3. Make sure that all three connections are firmly secured.
    4. Turn your console back on.
    Check the light on the power supply. If this solution worked, your power supply light will be green and the power button will look like this: xboxconsolevertical.jpg
    Dec 28, 2010 | Microsoft Xbox 360 Console
    Xbox 360 not powering up at all. power supply light blinks orange
    * The console is turned off.
    * The power supply is disconnected from the console.
    * The power supply cord is not fully inserted into the power socket of the console.
    * The power supply is faulty.
    * The console is faulty. (The console might be faulty if it does not turn on when the power supply light is orange.)
    With that being said, i would try to reset the supply by disconnecting the unit from the console, and unplugging the power supply unit from the wall socket for 5 minutes. Once the 5 minutes have passed, reconnect the unit to the console, and plug the power supply into the wall socket. If the console dose not power up, and the supply unit is still showing an orange illuminated operating light, this will confirm that the power supply unit will need to be replaced. Contact Microsoft for the correct replacement parts needed(power supply unit)
    * Do not block any ventilation openings in the power supply.
    * Do not put the power supply on a bed, on a sofa, or on any other soft surface that might block ventilation openings.
    * Do not put the power supply in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
    * Do not put the power supply on a stereo speaker, an amplifier, or a heat source such as a radiator or a heat register.
    * Do not use an unlicensed accessory, such as a replacement power supply that was not manufactured by Microsoft, or any accessory that plugs in between the Xbox 360 console and the power supply.
    * Plug the power supply directly into a working wall outlet. You may have problems with the power supply if you use an extension cord or a power strip if the extension cord or the power strip is faulty or cannot supply the required power to the console.
    * If you are not sure about the reliability of an AC power outlet, power circuit, or power cabling, do not use it. Contact an electrician.
    Oct 26, 2009 | Microsoft Xbox 360 Console
    Console does not light up after plugging unit in
    Check the power cord for rips of loosness where it enters the unit. if the power cored is fine, this will usually be the result of a power supply board failure. you should replace the power board in this case. the original board is unable to process the AC current at this time.
    May 28, 2009 | Fedders A7DH45B2A Dehumidifier
    Xbox 360:When i turn the console on the light turns red instead of green. when the screen turns on it says system error.
    Hi nomo..power off unit.. unplug av cable then power up unit.. after a couple minutes unit will automatically shutoff.. then plug in av cable and power up.. Good luck..
    Jun 30, 2008 | Video Game Consoles & Games
    XBox 360 power problem
    The power brick has most likely died.
    Dec 14, 2007 | Microsoft Xbox 360 Console
    Nintendo Wii Console Logo
    166 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
