Question about ASUS P4S533 Motherboard
Argh...this is a toughy!!
Ok, I have this computer that when turns on.....everything powers on but the video. There are also no posts sounds. I've already done all the basic stuff......HOWEVER, the hard drive said invalid system disk or something when I tried to boot it in another computer. BUT, I can access the hard drive as a slave. Anyway....I tried a windows xp cd....but got the blue screen trying to do a clean format....but that probably has something to do with the I would have to totally format that as a slave I guess.
Furthermore, on the other problem.....I'm sure it's probably the motherboard...but is there a sure fire way of telling if it's the MB or CPU? I took the fan and heatsink of the CPU and powered on briefly (couple of seconds).... the processor got really that makes me think that it's the motherboard...or bios. Any comments? Thanks,
  • Provigilken Nov 22, 2007
    Actually that was the second thing I did...nope doesn't work. I've done everything....even taken the motherboard out and booted on the bench. I think it's either the motherboard itself mostly.....but I don't think it's the processor.
  • rodneywerden May 06, 2008
    no beep no video, I tried all suggestions including reseating ram, powering on bench, using curcial ballistix pc 2 8500 ddr 2 1066 cl5 5 5 15 240 pin. thanks
  • ASUS Master
  • 3,051 Answers
Hi i want you to try this out if you have a computer that is recoognizing the harddrive right ,,,and this one will not you may want to look at the harddrive ribboin and verrify that it is connectiong to the drive the correct way some drives the ribbon will connect both ways but only 1 way will work also look at the ribbon and make sure that it is in good condition i have seen a lot of people bend the pins on the harddrive when they put it back in or they screw up the ribbon and they get a harddrive error now before you power everything up try this ok go ahead and unplug the powersupply then unplug the powersupply connections to the motherboard then press in the power button and hold it there for 15 seconds to discharge any esd then hook up the motherboard powercords and the powersupply after this is all done try to boot and see what happnes ok i really hope that this is helpfull please keep me posted ok best of luck mike
Posted on Aug 27, 2008
  • 298 Answers
Usually when that happens its
the ram reseat the dimms and
try to boot again(when the video dont come up)and
no beeps reseat the ram
Posted on Nov 22, 2007
Pioneer VSX-517-K Home Theater Receiver power does not turn off and everything freezes,the display lights up but no function,does anyone knows whats the problem is
ok you might be in the overload zone disconnect everything but power an try unit an functions no speakers nothing just power!Will keep an eye on this post ok!
Nov 16, 2015 | Pioneer Audio Players & Recorders
Dell 1800fp dead
Each monitor has a different response to "no activity" from the system. So for the monitor, if you get a chance, try your monitor on another machine that you know does function. At work, neighbour, or other.
For the computer, does the it (beep) or POST (Power On Selft Test) when you turn it on, do you see and hear what you would if the monitor was connected?
If it sounds normal, then everything should be fine and luck might have it, your backup monitor is not working either, try another one from the same friend or neighbour above.
If it doesn't POST, you could have a video or other card or ribbon connection loose in the computer. Either you or a friend, or the service center, whichever feels comfortable reseating all the external and internal equipment, bearing in mind static electricity and proper handling measures for the computer.
Nov 26, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
My Westinghouse TV LCD has no sound but has picture please help? 42 LED westinghouse..I CAN PLUG IN THE DVD PLAYER AND IT HAS SOUND! please help!
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Nov 06, 2014 | Westinghouse Televison & Video
My ASUS K50IJ sound comes from only one speaker. I've tryed everything and the balance seems ok
One of the speakers failed or it has a bad connection.Most likely the non working speaker will need to be replaced.
Mar 29, 2013 | ASUS K50IJ-C1 Notebook
Heard a pop while running ps3 then went dead. Have no red light or anything when turning it on. I've tried everything.
Unfortunately that sounds like your PSU (power supply) shorted, contact Sony to see about warranty replacement if it's still available...
Aug 23, 2011 | Sony Playstation 3 (PS3) Console
FPD 2485W .I replaced the bad capaitors in the inverter board, I hear the sound but can not see the gateway logo. I hook it up to the computer a d I do not see any video. Replace the inverter board, power...
Sounds like you've replaced everything but the backlight itself!
If you have another working unit, connect this LCD panel to the working unit and see if it works. If it's still dark, you need to replace the FL tube (backlight(s) ).
Jul 31, 2011 | Gateway FPD1950
I installed everything the CPU, RAM, and everything else. Connected all switches at the right places and the BIOS is on normal operation. I turn on the computer and its a blank screen nothing shows up....
ok, looking at the specifications All I can recommend is the following. double check the Video card to make sure it is properly seated and that it does not exceed the capabilities of the motherboard. 2 Disconnect everything from the motherboard except the CPU and case wiring/power supply and turn the computer on. If the system completes the post test, you will hear at least 1 beep and should hear several for the video card not being connected, then start installing components 1 at a time till you find the one causing the problem. Start with the Video card and then the ram as these are most likely where your problem is unless you have a faulty power supply which will be the problem if you don't get a completed post with nothing else connected.
Jun 18, 2010 | Abit IS7-V2 Motherboard
No display shows up on ps3
toughie check the cables for any frays then if that doesnt work check you tv and make sure the cables arent scattered if so fix it check if the ps3 turnes on when you press the power button
Jul 21, 2009 | Sony Playstation 3 (PS3) Console
Amilo xa series
The fan speed is controlled by the processor and BIOS. It is on full speed when it starts, but the processor turns it down again as soon as it starts to run.
Could be loose memory modules or the processor heatsink has come loose. Try taking off the back compartments and check everything is fitted OK.
Jul 27, 2008 | Fujitsu Siemens AMILO Pro V7010 Notebook
Flatbed scanner
take a volt meter and check the power at the end of the power adapter, sounds like it may be a power issue. if all is ok on that end does it still work on the old system? you may have to hook it back up to a working system and see if there is a firmware upgrade for it. Best of luck
Dec 29, 2007 | Mustek TwainScan 600 III EP Plus Flatbed...
ASUS P4S533 Motherboard Logo
113 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
