Question about Hitachi Televison & Video
TV shuts off 15 seconds after turning it on and no picture. How do i fix this problem?
  • 10,594 Answers
Please intimate exact model number of your Hitachi TV to find out reason of problem and its possible solution.
Thanks.
Posted on Jul 26, 2009
Why does my Philips 40" flat screen tv shut off 15 seconds after I turn it on?
The symptom you describe suggests power supply failure. It is still working but fading fast
Mar 24, 2013 | Philips 40pfl3706/f7 Lcd Flat Panel Tv
My Sharp LC-42SB45U takes 15 min to an hour to turn on. Also, sometimes picture blacks out for 10-15 seconds. Any suggestions? Pat Courson
Have same problem. Not the proper fix though I found that taking the back off and heating it up with a heat gun for 30 seconds to 1 minute and tv works fine till you shut it off over night.Maybe someone can offer a solution with that in mind. Pretty strange
Sep 17, 2012 | Sharp LC42SB45U 42 in. LCD TV
Set is connected to a DirectV satellite box. When the system is turned on, the TV starts up normally but then shuts off after 12-15 seconds. The pilot light on the front stays on, but there is no picture...
your technician indicated there was a problem in the "horizontal deflection circuit" and that a local TV terch s/b able to fix it. I have a tech visit scheduled for Thursday.
Oct 05, 2009 | Televison & Video
Tv won't stay on
The first thing I would do is to check the solder connections on the flyback transformer. This is a common problem with this set
Dec 05, 2008 | RCA HD52W59 HDTV Projection Television
Power
  • Sorry but it can't be fixed without knowing how a tv works on the inside. The problem is on the inside possibly in the horizontal section and should be taken to a repair shop
Dec 31, 2007 | JVC AV-32730 TV
TV pops and shuts off
Its two maybe three issues that your having trouble with. First thing is the convergence. That problem could be a cold solder connection on the convergence IC's or the Ic's have a thermal problem, as after they heat up they go bad. The second is the popping. This could be an issue with the rear channel Audio output Ic intermittanly shorting and shutting down the set, or it could be a bad ground around the picture tubes, or a leaky hi voltage block, or a second anode lead going to the picture tubes could be split. The other common problem with this set is the STR#### regulator IC in the power supply. Now unless your a tech you shouldnt attempt any of these repairs as there is very high voltage in this set and could cause great harm to you. seek the help of an authorized repair shop for Toshiba. Try this # if you cant find one in your area 800-457-7777 Good Luck
Jun 09, 2006 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
43 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
