Question about X2Gen MW22U Monitor
How do I reset the refresh rate? - X2Gen MW22U Monitor
  • 164 Answers
Right click on the screen, select properties..settings..advanced..adapter..list all modes
Posted on Jul 26, 2009
I want to refresh the nokia 1200 can you tell me the method????
Hi, Refresh menas reset your mobile to the default factory settings. Follow the steps below:
First remove the sim card from your mobile, and to hard-reset your samsung mobile use this codes:
*2767*2878# or *2767*3855#
After hard resetting your mobile using the code above insert the sim card into your mobile and restart your mobile. Done : )
If this solution was helpful please rate, thanks!
Jul 04, 2011 | Cell Phones
Tip
How to adjust or change a monitor's refresh rate.
If you've ever used a CRT monitor, you know that fine-tuning your refresh rate is essential. The refresh rate of a display is measured in Hertz (abbreviated Hz) and specifies the number of times per second that a display is illuminated.<br /> <br /> Setting the refresh rate to 60 Hz - a common default value - tells the monitor to redraw itself 60 times per second. For most people, that setting on a CRT monitor is too slow, resulting in an annoying flicker that can cause headaches, eyestrain, and fatigue. Bumping the refresh rate to a higher number can reduce that flicker, as long as the monitor itself can handle the faster rate.<br /> <br /> If you're using an LCD monitor then a safe refresh rate lies in the 60Hz-75Hz range. A greater refresh rate when it comes to LCD's means greater performance.<br /><br /> <b><u>How to adjust the refresh rate</u></b><br /> Firstly you will need to right click on your desktop background and select <b>Properties</b>.<br /> <img src="slasher_x_72.JPG" /> <br /> This will display the <b>Display Properties</b> window as show below.<br /> <img src="slasher_x_73.jpg" /> <br /> You will need to click the <b>Settings</b> tab.<br /> <img src="slasher_x_74.JPG" /> <br /> Once in the <b>Settings</b> tab you will need to click on the <b>Advanced</b> button.<br /> <img src="slasher_x_75.JPG" /> <br /> Then click on the <b>Monitor</b> tab.<br /> <img src="slasher_x_76.JPG" /> <br /> Here you can change the screen's refresh rate. Make sure the box next to <b>Hide modes that this monitor cannot display</b> is ticked. After you have selected the refresh rate you wish click <b>OK</b>. It would be a very good idea if you have the user's manual for the monitor handy just so that you can see what the manufacturer suggests the refresh rate should be set to.
on May 31, 2011 | Computers & Internet
I got a new tv 52" sanyo i was pretty good at the cod games and now everything feels delayed i reset my tv..... then when i looked in the tv menu it said on tv if you have this problem go to console...
This will probably be due to the refresh rate of your new screen, plug your PS3 into your old screen if you don't experience this delay effect it is due to your TV. There is no way to fix this on your TV so I would take it back to the store and buy a TV of a refresh rate of at least 60Hz 120Hz would be best though.
Mar 08, 2011 | Sony Playstation 3 (PS3) Console
*#7780# is not working how can i reset my phone
You will have to go on your phone settings go on to reset and go on reset that will just turn off your phone and give it a refresh or you can MASTER reset which will turn off your phone give a good refresh and delete all you stuff games music i don't know about your contacts and text messages so good luck :) and please rate this solution...
Jun 06, 2010 | Nokia 1661 Cell Phone
On booting up, screen stays black. When I switch it off and on, picture appears briefly. I need to do this several times before the picture finally "catches" - and then stays stable.
this could happen when there is a missmatch in the operating frequency (refresh rate) between both VGA card and screen, try to reset your screen settings to default, and set the refresh rate on your vga card settings to 60 HZ
Feb 19, 2010 | Acer AL1711 17" LCD Monitor
Operating at a slower than recommended refresh rate
The refresh rate can be configured in Windows in the display properties. It does require that your monitor has been identified or configured, otherwise it can limit the refresh rate.
You can overrule the setting to not limit the refresh rate to compatible devices only, but be careful to not configure it too high as it can break your monitor!
May 25, 2009 | NEC MultiSync FE700 17" CRT Monitor
Problem with my LG monitor L194WT
First change the referesh rate for your monitor. If that works, then you dont have to change the resolution. If that does not work, try increasing the rate again. Once you can get the game, then try to change the resolution from within the game options, if necessary..
May 27, 2008 | Computers & Internet
Sony vaio pcg k315s laptop. when i power it up the sony logo come up but soon as windows xp loads the sreen gose black. it works fine on another screen. please can you help. thanks. nilesh nilesh...
This sounds like the resolution or the refresh rate may be out of the monitor have you reset this lately? Try changing the refresh rate and resolution to something that this monitor without question able to handle.
Mar 12, 2008 | Computers & Internet
Monitor into TV
The monitor may not be compatible with your TV box. Basically if the monitor can't handle the refresh rate or resolution a blank screen like this will result. There should be a way to change the refresh rate or a standard refresh rate listed in the manual. What brand/,model of tv box is it?
Dec 12, 2007 | LaCie Electron 22" CRT Monitor
Likom Futura LDF770
There may wrong setting of refresh rate. Most monitors work at 60 to 70 Hz refresh rate. Above that they tunned blank screen or out 0f range message displayed. Also check the output video signal. Please confirm technical specifications from the documentatation of the monitor.
Aug 15, 2007 | Likom Futura LD7 17" CRT Monitor
X2Gen MW22U Monitor Logo
49 people viewed this question
Top X2Gen Computers & Internet Experts
Sandy Moore
Sandy Moore
William Alequin
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
