Condensor shuts down after two hrs - Heating & Cooling
  • 6,784 Answers
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your unit may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean your coils once a year.
Posted on Jul 26, 2009
The outside unit will work only briefly and bring the temp. down about 1 degree in 2 hours of running. Then the outside unit turns off for at least 2 to 3 hours.
Does the outside unit completley shutoff or does the
condensor fan keep on operating? If this is the case
the compressor could be overheating and shutting down. Try washing the condensor from inside out.
If you can read electrical diagram on the back of the
condensor electrical panel check to see if it has a
high pressure switch, if this is the case it probably
is cycling off this switch. Wash the Condensor and make sure the fan is operating.
If the big insulated line does not feel cool after 15 min. of operation you could be low on freon.
Jun 12, 2010 | Carrier 38CKC042 Air Conditioner
Food compartment cools ok; bottom freezer doesn't.
the problem when a fridge needs a condensor fan is that it causes the unit to work harder there is a good chance that it cooked the sealed systm also might want to check the condensor for a clogg or dirty condensor.the temp around the unit ideally these are to be used in rooms of 65 to 96 degrees so if in garage can be hard to work well
Jun 03, 2010 | GE PDS22MBR Bottom Freezer Refrigerator
Compressor overheated and shut down.
Pleas put setting in the middle and give it 24 hrs and check temps
freezer would be good at 0 to 10 f
I thing you have the damper door closed.
May 24, 2010 | Whirlpool GS6NBEXR Side by Side...
Freezer not freezing, and the panel between the fridge and the freezer gets very hot
The condensor fan motor is probably not running. The condensor fan keeps the compresor cooled, if the compresor gets to hot, it shuts down until it cools off and tuns back on, but will not keep temp. Heat exchange lines go in the panel between the doors to serve as a heater so the doors dont freeze shut, but when the compresor overheats, so do those lines. That would be why that panel gets so hot. Both problems will be resolved with a new condensor fan motor ( located by the compresor).
Oct 16, 2009 | Estate TS25AFXK Side by Side Refrigerator
Condenser shuts down after a couple of hours.
check capacitors, make sure the condensor coil is clean. sounds like the compressor is overheating. is the condensor fan motor still turning when it stops cooling. if not check low voltage wires to condensor, furnace and t-stat
Aug 19, 2009 | Amana Haier AP125HD Air Conditioner
71122 ac model starts but the fan does not blow any air .shuts off within seconds.
which fan shuts down? Outside condensor fan? Or blower inside? If its the outside condensor fan motor you probably have a bad run capacitor or a bad condensor fan motor
Jul 26, 2009 | Heating & Cooling
My mitsubishi 52725 shuts itself off after acouple hrs
Its most likely the thermal fuse which is causing the problem. It gets up to operating temp then shuts down.
Jun 17, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
