Question about Garden
I thought that maybe drive belt needed to be changed and put new one on. still having problems going up low grade hills. all pulleys look alright. have about 100 hours on tractor. model lgt2654 (96045000701) product no. 960 45 00-07 drive
  • hercoraar Jul 26, 2009
    I've did what the procedure said and still has problems pulling slight hills
    I've changed the drive belt and purged the transmission and still has problems pulling slight upward grades.
  • 3,037 Answers
Sounds like the governor needs to be readjusted as it isn't giving you more power to make it up hills. Take it back to the dealer you bought it from and they should do this for free if you just bought it, otherwise it shouldn't cost so much. Let me know how this turns out.
Benjamin
Posted on Jul 26, 2009
  • 339 Answers
Sounds like the transmission needs to be purged of air. The procedure for doing this is on page 16 of your user manual. If you don't have it handy, it can be downloaded here: http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2006/HOUS2006_O0602065.pdf
Yth2248 loses speed on slightest grade. new drive belt not helpful
Roy if it is the correct belt and fairly new, check your manual for belt adjustment, if it shows that there is no adjustment the pulleys may be worn out, on a lot of mowers the pulleys are ware items and changed more often to correct slipping issues. The other thing to check is the belt tensioner if equipped, it could be seized, weak or missing spring or it may even be adjustable by cable end being threaded or slotted bolt holes on tensioner arm.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Drive Pulley Replacement On Craftsman Lawn Tractor
Mower Engine Pulley Replacement Craftsman Riding Lawn Mower Repair Part...
Cub Cadet LT1045 Transmission Drive Belt Replacement
husqvarna LGT24k54 drive belt install
Apr 22, 2016 | Garden
Hydrostatic trans getting weak going forward. Won't lug engine and have to go to low gear to pull hills it used to pull in B. Reverse is still strong. 380 hours, have change filter, oil looks good
The big pulley on top of the hydro axle is driven by a rubber belt.
V Drive belts pull from the two sides of the belt, as they wear down the bottom of the belt gets lower in the pulley making it loose and narrower then original. There is a idler pulley mounted on a arm with a big spring that pulls it tight to make belt not slip
Mar 14, 2016 | Garden
1999 ford explorer SOCH 4.0 ltr
Alway pick the thermostat with "fail-safe" relief. Look for a float like pressure relief port.
The low tech method to prevent trap air pocket is to drive the car onto an oil ramp (or hill) then fill coolant slowly.
Jan 11, 2014 | Cars & Trucks
My jonway 49cc moped loses power too easily going uphill. Does it need new rings?
It needs a bigger engine. 50 cc or less will max out at 25 MPH on level ground with a load of 150 lbs. Add an uphill grade or more weight and you're fighting a losing battle.
Sep 08, 2012 | Motorcycles
My craftsman tractor wont pull itself up a hill. Runs fine but just comes to a stop when trying to go up a hill. Maby the ground drive belt is slipping????
Sounds like your drive belt is slipping alright. Need to tighten your clutch rod. One end of rod adjust. Have someone help you, move the clutch petal and your helper watch and see rod moves.
Nov 14, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Hello. I am having constant problems with my 1997 chevy cavalier serpentine belt. My old wrecked belt was working fine but when it started wearing too thin i got a new one. As soon as the new one was put...
has anyone checked the tensioner and pulley.th etensioner should operate smooth and without any side play. if the belt is too long, the tensioner will not be able to pull out the "slack" in the belt. the tensioner will have a mark of where it should be with the correct length belt on it.
Oct 10, 2009 | Chevrolet Cavalier Cars & Trucks
Huskee supreme slt 4600 2007 model no 13ax775h730 serial no 1b087b70102 if i am on flat ground it seams to go just fine but up a small hill does not want to go all belts are new need help just bought it...
Perhaps, there is a problem with the tensioner pulleys.
Or as I have recently discovered, when changing drive belts/cutter belts,
They're ever so slightly, not the right length.
Or even, not the right thickness.
But if you can check the tensioner pulley springs, to make sure they tighten up correctly, that might give you a clue as to the problem.
Have fun.
Jul 22, 2009 | Mtd Garden
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
