Question about Pix FUJIFILM Fine S1500fd Digital Camera
Fujifilm S1500 broken battery door
My daughter dropped my camera and broke off the lugs that hold the battery compartment closed. Is there any way to replace these?
    Problem Solver:
  • 5 Answers
Yes, but you would most likely (don't quote me) have to send it back to the manufacture to get it fixed. That means $$$, is there a way for you to tape it on? You really only need the metal piece/plate touching the batteries.
Posted on Jul 26, 2009
Do you have an instruction book for the finepix S1500
Here's the link for the instruction book/manual for Finepix S1500
http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/s/finepix_s1500_manual_01.pdf
Hope this helps. Rate if it works. Thanks
Apr 14, 2011 | FUJIFILM S1500 Digital Camera
Fujifilm S1500. Batter compart doesn't close
If you can't return the camera for service, my advice would be to close the battery compartment with tape. Not pretty but better than buying a new camera, I've done it a few times on old cameras and apart from cosmetics, works fine. Just make sure to use enough tape so the batteries won't fly out when using it.
Jul 14, 2010 | Pix FUJIFILM Fine S1500fd Digital Camera
Battery door retaining lugs broken,also the plastic lugs on the main body that the battery door needs to latch onto are broken off ,cannot use camera as unable to secure batteries in the camera ,door will...
KODAK doesn't sell battery doors for any of their models.
A repair for this fault is 24,47 pounds + shipping to the repair centre.
If you already have the battery door; I suggest you will have a local camera TECH to attach the door to the unit.
Feb 04, 2010 | Kodak EasyShare C340 Digital Camera
I have Fujifilm Finepix S1000. The battery door does not close. Is there a place on-line I can purchase a battery door? Thank you.
I know this is an old question, but when I had this problem I came across several forums that had the "tape it" or "drill a hole and screw it shut" solutions. Some even gave step by step instructions on taking the camera apart and replacing the battery compartment with one from a camera bought for parts. I even contacted Fujifilm for an estimate. All were either expensive, ineffective or damaging. The solution I came up with was to go to the Camera Exchange and buy a Quick Release plate used for tripods. One that was long enough to cover the battery door. It screws into the tripod mount on the back and holds the door closed. No damage, no hole drilling and it works. Also only cost me $8. Win!
Jan 18, 2010 | Fuji FinePix S1000FD Digital Camera
Fujifilm finepix s700 is not turning on
OK
First check the battery door to make sure that it is closed properly. If you have a media door (the door which covers where the media cards are inserted) make sure that is closed properly. If this is the case then check that there is no plastic broken off. The doors contact with microswitches which allow the camera to turn on.
On the camera there is also a playback button. (green triangle) If you hold this and the camera turns on then your power switch is faulty.
Failing all of this then put some power into the camera via an adapter. If the camera turns on then it is likelly to be a battery fuse.
In all instances you will need to send the camera to be repaired at the fujifilm service centre. Web address below.
http://www.fujifilm.co.uk/technical/camera_repair/
Dec 17, 2008 | Fuji FinePix S700 Digital Camera
Broken battery compartment door switch
The switch is a micro switch that is depressed(and not sad :)) by a plastic tag moulded on the battery cover. Once the cover is moved into position and closed, the tag presses on the micro switch closing the switch and thus removing the error message. As with any switch, a switch is simply open or closed, Open = high resistance or O/L, while closed = 0 ohms reistance. You can use a small wire to overcome the switch by soldering the wire to both tags of the switch so it is permenantly 0 ohms. This will send a message to the microprocessor that cover is closed and camera ready for use. Hope this helps.
Twitcha
Sep 28, 2008 | Olympus FE-140 Digital Camera
Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
Pix FUJIFILM Fine S1500fd Digital Camera Logo
689 people viewed this question
Top Pix Cameras Experts
JonSnell Electronic
JonSnell Electronic
Mister Danger
Are you a Pix Camera Expert? Answer questions, earn points and help others
