I have callus on my big toe it begin to turn black i been using a simply foot callus remover tool i don't know did the dark spot on my toe come from using the tool or not what is the best thing i can use to remove the callus?
Pain and swelling that occur without an injury and with redness, red streaking,tenderness, heat, fever, or pus may be caused by an infection. Infections can occur without a known injury to the affected area. Pain, swelling, redness, and warmth that develop suddenly in a big toe joint may be caused by gout.20 Nov 2015
Number of tips for finding shoes for ageing feet: 1. Ensure the toes don't touch the end of the shoe, allow a 1cm gap from the longest toe. 2.Shoes should not need "breaking in" they should fit comfortably from the start. 3. Ensure the toes don't touch the end of the shoe, allow a 1cm gap from the longest toe. 4.Ensure the toes don't touch the end of the shoe, allow a 1cm gap from the longest toe. 5.Ensure shoes are wide and deep enough to prevent heel slip. 6.Lace up, buckles or Velcro should hold the heel in place Velcro straps can be easier for arthritic hands.7. Slip on shoes can encourage the toes to 'claw' at the shoe to keep it on leading to discomfort, corns and calluses.
Here are some of the effective shin splints stretches:
1) In a kneeling position, point your toes out behind and gently sit back on your heels pressing the tops of the feet towards the ground.
2) Standing arm length from a wall, put your hands on the wall while keeping your feet and knees straight, then lean forward as far as possible.
3) Standing with your feet flat, bend your knees forward as far as possible keeping your heels on the floor.
4) Put feet flat on the ground and have a partner hold them down. Partner applies resistance to your toes and you lift them up against the pressure.
5) Sitting with your left ankle on right knee, apply pressure to inside of your foot (near big toe) with hand, then and turn your foot up and in, using the leg muscles.
6) In the same position as above, put pressure to the outside of the foot (near little toe) with your hand, and turn foot down and out using the leg muscles.
7) In the same position as above, put pressure to the top of foot (near toes) with your hand, and lift the foot using leg muscles. Repeat these with the right ankle on the left knee.
8) Sit on a table or chair attach a weight (a bucket filled with stones or sand works well) around the foot. Without bending your knee move your foot up and down from the ankle - Start light and work up.
9) Attach one end of a stretching exercise elastic band to the leg of a table or sofa and loop it around the end of the foot. Move your foot up and down and side to side against the bands resistance. Try to draw the letters of the alphabet in the air with your big toe.
10) Stand erect and raise up and down onto your toes several times. You can make it harder by doing it while standing on a step and allowing your calves to stretch over the edge of the step.
11) While sitting lower and raise your feet with the heels on the ground as high and quickly as possible for 60 seconds. This is a great one to do during work days while sitting at your desk.
I would be concerned about that. Why did the calluses develop and why did they come off? Contact a doctor, pedorthist or podiatrist to make sure all is well. This counts at least twice as important if you have a major systemic disease like diabetes, rheumatoid arthritis or marfan syndeome! Until the toes have healed, you should put a bandage on them with something like tea tree oil as a moisturizer and antibiotic.
Salicylic acid. Additionally, your doctor may apply a patch containing 40 percent salicylic acid (Curad Mediplast, Dr. Scholl's Corn Removers, others), which is available without a prescription. He or she will let you know how often you need to replace this patch, and may recommend that you use a pumice stone or a metal nail file to smooth away the dead skin before applying a new patch. Salicylic acid is also available in a topical form by prescription for large areas.
Antibiotic medication. Your doctor may also suggest applying an antibiotic ointment to reduce the risk of infection.
Shoe inserts. If you have an underlying foot deformity, your doctor may prescribe custom-made padded shoe inserts (orthotics) to prevent recurring corns or calluses.
Surgery. In rare instances, your doctor may recommend surgery to correct the alignment of the bone causing the friction.
A bunionectomy is a surgery that removes all the swollen tissue from the area of the big toe joint. Your big toe will be straightened by taking away part of the bone. The long bone between the back of your foot and big toe will be realigned so the big toe joint will become straight. This joins the affected joint bones together permanenetly.
If you're healthy, you need treatment for corns and calluses only if
they cause discomfort. For most people, simply eliminating the source of
friction or pressure makes corns and calluses disappear.
Corns and calluses are thick, hardened layers of skin that develop when
your skin tries to protect itself against friction and pressure. They
most often develop on the feet and toes or hands and fingers. Corns and
calluses can be unsightly.
