Question about Sony VRD-MC5 DVD Recorder
The eject button on my VRDMC5 DVD recorder does not work at all.
Pushing it does not open or close the drawer. It also won't recognize that a disk is present. If I power up the unit with the drawer open, the bootup sofware closes the drawer smoothly, so it doesn't appear to be a hardware problem. After bootup, the unit displays "insert disk", but the eject button does not open the drawer.
Also, if I manually open the drawer, put in a disk and close it, the unit does not recognize it, it just displays the "insert disk" measage again.
Is there perhaps a firmware update that I could do to fix this? If not, who can repair it?
    Top Expert:
  • Sony Master
  • 12,962 Answers
When idsk is not recognized it is because the laser mechanism can no longer focus on the disk. If this happens with all disks then the unit is fubar and it is time to go shopping since repair is not cost effective.
Posted on Apr 24, 2017
philipp
  • 217 Answers
SOURCE: Problem dubbing from VHS to DVD
Try different brands of disk, most dvd-r recorder are disk sensitive, buy only one disk per brand, find the brand compatible to your recorder by just inserting the disk and wait for confirmation that it is ready for recording session. I have tried around five brands, sony and maxell as well as verbatim are good dvd-r disk.
Posted on Aug 23, 2007
SOURCE: Display says "LOCKED", won't eject disk, all other functions work. Need unlock procedure.
How I got my DVD from ”lock” condition
My DVD (Panasonic m: DMR-ES10) had gone to ”locked” condition without any warning.
Perhaps the reason was that I transfered the machine when it was on and recording was going…
Guidebook didn´t help to resolve the problem, neither Internet. Finally I managed to solve the promlem . This is how i did step by step:
1) Power on
2) Hello
3) read
4) no disc
5) functions
6) to others
7) setup
8) select down arrow
9) disc
10) select right arrow
11) setings for playback
12) enter
13) ratings (level8)
14) enter
15) No limit
16) enter
17) ”The Recorder is now unlocked” (picture of open lock)
18) enter
19) return
20) return
After this DVD works normally.
Jalmari
Posted on Dec 13, 2007
  • 70 Answers
SOURCE: DVD stuck in player SONY RDR-VX 515
Take the lid off by taking the 2 to 4 screws out of the sides of the unit to get the disc out.
Posted on Feb 19, 2008
SOURCE: sony dvd player cant eject disk
Actually if all you want is the dvd, there is a plastic cover on the underside of the dvd player below the dvd tray. Open it from the tab like a door and inside the slot you'll see a little black lever that you have to move with a small screwdriver or something like that....then slide the lever over towards the power button. If you don't feel comfortable doing this next step please bring it to some one that is familiar withit or a repair shop !!!!!!!!PLEASE UNPLUG BEFORE MOVING ON!!!!!!!!! Now if ya wanna fix the "LOCKED" error and unplugging it doesn't help, you have to take the top case of the dvd player (six screws and slide it back.....the case might get caught on the plug on the back so slightly lift it above it. Then once you have the cover off, with the front of the dvd player facing you...unplug the connector that is on the left hand side of the dvd tray that connects to the circuit board with firm and straight up pressure.....pull (it is ok to pull from the wires, just grab in the middle). Now you might have to plug in the power for the dvd player with that connector unplugged but do so with caution!!!!!......if ya want just put the cover back on without the screws on and just press power a couple of times.....then remove the power cord from the wall, take your case off, reattach the connector.......you'll here it kinda snap back in, make sure you put the connect back on the same way, it really only goes in one way, the prongs are more to one side. then slide your cover back on making sure you lift the back of the cover over the power cord on the back and the put your screws back in and your done.......this should solve both your problems. I think my kid was messing around with mine too!!
Posted on Oct 27, 2008
uplug then replug then press eject
Posted on Oct 05, 2011
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Jvc dvd player won't open
when you hit the eject button try tapping the top above the disk drive. it may be somewhat stuck. if that doesnt fix it you might have a broken belt or a belt may have come off in it. the belt controls the movement of the drive in and out
Mar 21, 2012 | JVC DVD Recorder - VCR Combos: DVD...
Dvd drawer won't open
stick tip of pencil in tiny hole just under the drawer
Dec 30, 2011 | Sony RDR-VX560 DVD Recorder/VCR
DVD DRAWER won't open
OK.
I assume the display does not say 'locked' when you press eject.
A DVD drawer is run by a small rubber belt on most of these old machines. This belt can be worn out (Very common)
The DVD drawer position is detected by a switch that can be pressed in or out to detect the drawer is closed or open. This switch can cause the drawer to stay in if it thinks the drawer is not yet closed. Cleaning the switch (Take the DVD drive out and remove and clean or replace the switch) can usually fix this.
A fault with the DVD process cicuit board can also cause this. I would recommend a new machine if this is the case.
Testing:
Bad belt - the DVD drawer shifts a bit when the eject button is pressed.
Bad switch - a whirring sound can always be heard when the DVD is first powered on. May give an error in the display.
Bad process board - Generally, says open forever or close forever and will not change back to normal display. You cannot get any other functions to work after you press eject. Unplug the machine, its normal until you press eject again. (just a generic common thing)
Mar 22, 2010 | Sansui VRDVD5000 DVD Recorder/VCR
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Remote Buttons
Press the VCR button first then press open/close
Nov 22, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Akai DVD recorder tray will not open
I am pursuing the exact problem above. I have found a not so hi tech solution. I firmly rap on the top above the disc drawer. This is while Close is being displayed and the drawer is in. If you hear some spinning and load displays it should now work. It may be back to cycling again on the next ejection though.
Technically I figure it may be a sticky magnetic reed switch or what ever they use to detect the drawer position. Mine displays either open or close when it starts to cycle.
Aug 08, 2006 | Akai DVDRW120 DVD Recorder
Sony VRD-MC5 DVD Recorder Logo
153 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
