Gas weedeater wont start
assuming weedeater brand weed eater, the carb. has a filter screen, that blocks and does not allow the pump to push sufficient fuel. A phillips head screw on the side of the carburettor secures a square plate, remove the screw and plate and gently brush the screen clean, dirt collects on the visible side.
Dirty foam filters if fitted change the fuel mixture and make it too rich to run.
and the fuel mixture knob, although secured by a tension spring, moves and may need to be readjusted
