Question about Canon PIXMA MP150 All-In-One InkJet Printer
E5 error I now have E5 flashing - having put in new cartridges.
  • 92 Answers
HI ...
This error comes in when the cartridge is not installed correct ... I would suggest you remove and then re-install the cartridge using the below steps:
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
    Note: Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
Installing ink cartridges:
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
  2. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot
  3. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  4. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  5. Fold the scanning unit support and close the scanning unit (printer cover).
  6. Wait until the preparatory operation is complete; it takes about one to two minutes.
Please vote if this helps ... Cheers :)
Posted on Jul 27, 2009
    President:
  • 2,306 Answers
E5 is just saying the cartridge is the wrong type, or not installed properly. Your store should exchange a defective cartridge, If the carriage is damaged, you may need a shop repair.
4 Suggested Answers
clusterfx
  • 67 Answers
SOURCE: canon mp160 printer E5 flashing error?
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button 4 times.
The above will get you to Service Mode (and clear the Waste Ink Counter if you wish) and is supposed to work for MP160 also.
Caution if your waste ink pad is full you could overflow if ignored.
Some of the new carts reportedly have fuses which blow if the ink gets too low, denying any further refilling.
To use refills, you will probably have to turn off your Status Monitor.
Go to your printer's Maintenance section.
Posted on Feb 23, 2008
SASSYBEAR
  • 148 Answers
SOURCE: Ink Cartridge Refill Error E5
press and hold (stop/reset) for at least 5 seconds, then release it. It will tell the printer that refilled ink tanks are installed. Therefore, allowing printing to continue.
Posted on Mar 15, 2008
SOURCE: Error code E5 on LCD Canon Pixma MP160
Yo tambien tengo una canon pixma mp160 y me da el mismo error por culpa de los cartuchos. La solucion simple y llanamente pasaría por comprar cartuchos nuevos originales, pero a veces te sigue dando el mismo problema incluso con ellos. Asi pues, lo que yo recomendaría es no comprar esta impresora.
Ah! se me olvidaba, que piden que escriba en ingles, porque dicen que "esto es america", no amigos, esto no es america, esto es internet. El mundo globalizado, irse acostumbrando a usar mas de un idioma.
Posted on Feb 20, 2009
My canon MP 145 printer displayed E5. How can I solve my problem?
E5 means your cartridge error. May I know are you using original ink cartridge or yours has been modified before?
I assume you to refill your ink cartridge before because E5 error won't appear after replacing new cartridge.
So, you need to take out both of your ink cartridge and then use a clean cloth to wipe them. After that, slowly put in back into the printer. If the error is still there after wiping it, try to do it till the error is gone.
I had tested this way with my own printer and it works again without needed to buy a new ink cartridge.
All the best and good luck =)
May 20, 2011 | Computers & Internet
How to error e5 how to go to service mode
Hum....e5 error.
The truth is...there is no solution for e5 error.
U may see some solutions through web, however, non of them works..
The only way you can get out of e5 error, replace with new cartridge..
or...
prevent it...before you face it!!
How?
Whenever you take out the cartridge from printer, make sure unplug the power code first..
and then take and refill or whatever...
And then when you put it back....do it when power code is unplugged as well.
Personally, I refilled and used CL831 more than 8 times..
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 19, 2011 | Canon PIXMA MP150 All-In-One InkJet...
My printer is reading error E5... what does this mean?
May 15, 2011 | Canon PIXMA MP210 InkJet Printer
Colored refill ink cannot be recognized
It is called e5 error.
For Canon cartridges, after 4~5 refills, the color cartridge cannot be recognized by printer.
In this case...there is no solution so far...just replace with new cartridge.. that's it.
(To avoid e5 error, you need to make sure "plug out" the power, before take out your cartridge for refill. Yes... "plug out" the power cords!!!!
May 06, 2011 | Canon PIXMA iP1300 Printer
I changed my ink to new ink ,and the lights are flashing what could be the matter ,i have a error message E5 ,can you give some tips as i have lost my manuel . Amanda
This could indicate that one or both cartridges aren't completely installed or the tape is still over the nozzles. With the printer on, lift the scanner unit and wait for the cartridges to move to the replacement location. Remove the cartridges one at a time, remove the protective tape (if present) and reseat them. Make sure that they click into place. Then close the scanner unit.
You can try installing new Canon cartridges (to check if the error is from bad cartridges). Make sure that you have the cartridges in the correct slot and are using the correct cartridges for the printer (PG40, PG50, CL41, CL51).
The printer may require service if the cartridges are OK.
The manual for the printer is available here: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp150?selectedName=BrochuresAndManuals .
I hope this helps.
May 05, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Printer continually says put in cartridge even though I have (twice). I have checked over and over that the cartridge is firmly installed. Is there a sensor somewhere which needs cleaning or resetting?
Did you used refilled cartridge?
Sometimes for Canon printer, when u used refilled cartridges, they are not readable.
It's called E5 error.
In this case, you need to replace the cartridge with new one.
Apr 19, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Canon mp160 printer E5 flashing error
E5 mean: The Fine cartridge may not be installed properly,or the Cartridge may not be compatible with this machine.Install the appropriate Fine cartridge.If lines are misaligned or the resulting out put is not satisfactory,carry out the Fine cartridge Alignment.
Dec 22, 2009 | Canon PIXMA MP160 All-In-One InkJet...
First take a smooth cloth or cotton
take a cleaning liquid like spirit, thinner etc., (note - not cleaners)
clean the golden chip with out giving much presser
in the same way clean the other side of the printer also
now test it
90% Problem will solve
Thanku
Take care
Bye
Apr 04, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
493 people viewed this question
old marine
old marine
