Question about HP OfficeJet 6110xi All-In-One Thermal Printer
I now have a message on my 6110xi printer which says "remove and check cartridge". When I remove and check, they both seem fine - when I reinstall, the message remains.
  • 628 Answers
Try another cartridge. Sometimes they go bad. If the message goes away, then your cartridge is bad. Otherwise, try cleaning off the contacts where the cartridge goes in.
Posted on Jul 27, 2009
  • JOHN LAPIER Oct 21, 2010
    my problem is more like the motor for the scaner even with power butten in off mode there is still power to it im not sure if this is normal but what it dose is after inital start up motor dosn;t stop at rest pistition it more or less cycles not back and forth bet in the same deriction mabey 1/4 of a turn for about 60 sec then reads scaner falluer i use just as a copier and moved it from compuiter to other room but had no surge protection i don;t know if the motor has any interanil curectery or its mabey the controler for the motor on the mother board
Cartridge Error - see user manual
It seems that you have tried most of the troubleshooting steps to identify and fix the problem. But try to replace your black cartridge with a new genuine Lexmark cartridge to determine if it's a faulty cartridge issue.
You may also contact Lexmark Technical Support Center for additional assistance.
Jan 24, 2012 | Lexmark X4650 InkJet Printer
My hp officejet 6110xi all in one says remove and check cartridge but the ink is new
You have to disconnect power to the printer and also disconnect the printer serial or usb cord,
reconnect it, when it reboots, it will see the new cartridge and the error will go away. good luck!
Jul 12, 2011 | HP OfficeJet 6110 All-In-One InkJet...
My Canon IP 90V printer says that I need to install a black cartridge. I have installed a new cartridge and the same error message is displayed
Seems , you are not fit the cartridge properly in its place. Please remove then reinstall it. Check also for new cartridge for its compatibility for your printer
Jan 09, 2011 | Canon PIXMA iP90v Printer
Remove and check cartridge
Step 1: Remove, inspect, and reset the problem cartridge
Step 2: Clean the problem cartridge contacts
Step 3: Repeat repeating and cleaning steps
Step 4. CONTACT TO HP SUPPORT
Step : Remove, inspect, and reseat the problem cartridge and Clean the problem cartridge contacts..
a) Make sure the printer is on. Press the Power button if it is not lit.
b) Open the printer cover, then wait until the print cartridge carriage is idle and silent
c) Press down lightly on the end of the problem cartridge to release it.
d) Slide the cartridge out and inspect it:
* Check the Copper electrical contacts (the Copper Part which touch the Connector inside)
* Clean it with the pirit or wet cotton)
* Check the Nozzles - Clean it with the worm wet cotton
* Wait for 2 to 5 min befour you connect them back
* Clean the contacts in the carriage, inside the product (Printer)
* Reinstall the cartridge.
* Reconnect the product to the electrical outlet.
* Close the product cover.
NOTE : you can also check the print cartridge label and make sure it iscompatible with your printer. Compatible print cartridges are listed inthe Printer Reference Guide supplied with your printer.
Note : If the cartridge is compatible, reinstall it in the printer:
* Cartridges marked with a triangle go into the left carriage slot.
* Cartridges marked with a square or pentagon go into the right carriage slot.
If issue not resolves Repeat repeating and cleaning steps
Jan 04, 2010 | HP OfficeJet 6110 All-In-One InkJet...
6110xi keeps giving error message to remove and check cartridge. After doing so many times and resetting machine, error still exist. Can you help me? Thank you.
You probably just need a new cartridge, they have an expiration date after which they dont work, and many of the generic refills don't work. HP says to clean the contacts on the cart. with alcohol and also the pins in the carriage where it goes. After that it's just a new cartridge.
Aug 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp 2210 error message after cartridge replacement
hi
It seems that the cartridge which you are trying is not ment for this printer can help you but for that you have to visit----http://tinyurl.com/ng46w9
Jun 22, 2009 | HP PSC 1610 All-In-One InkJet Printer
Remove and check color cartridge [it dosnot work]
i went to the hp website and they acknowledge this problem they have a page on this http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02180&cc=us&lc=en&dlc=en&product=59273
it appears that there may be dirty contacts in the printer as well, i changed the black cartridge and it started working, just luck i guess
Oct 14, 2008 | Office Equipment & Supplies
I receive a consistent message that alignment of cartridges failed.
Ensure you are using original HP cartridges. Using refilled/generic inks can cause this problem.
If you are using original inks, try cleaning the contacts of the cartridges gently with isopropyl alcohol. Should it still fail, get them replaced.
The above solution was Comment by IrishDruid, posted on Jun 01, 2008. I tried it on my HP officeject 6110xi (using alcohol swabs). It worked perfectly.
Jul 10, 2008 | HP OfficeJet 6110xi All-In-One Thermal...
Remove & Check Cartridge message
Hi Scallag,
Please check with the ink cartridge numbers given below.
HP Officejet 6100 series All-in-One model Black cartridge Color cartridge Photo cartridge HP Officejet 6110, HP Officejet 6110xi, HP Officejet 6110v HP 56 HP 57 HP 58
Click on the web link given below and perform the steps carefully.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01299067&cc=us&lc=en&dlc=en&product=79477
Here is the other web link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01300415&cc=us&lc=en&dlc=en&product=79477
Have a great day!
Mar 20, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110xi All-In-One Thermal Printer Logo
121 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
