Question about RCA RCU300 Remote Control
Can't program Comcast remote to controlEmerson LCD TV LC195EM82
Have a similar issue. I have tried all of the codes listed on the Comcast website for the Emerson LC195EM82 HD tv and nothing allows the remote control the tv. The Comcast tech who was here to install the cable box for this tv couldn't get it programmed either. Since the TV is made by Funai I even tried the codes listed for that manufacturer (most were the same as Emerson but some were different) and these didn't work either.
PyroMan6x9x9
  • 150 Answers
SOURCE: Emerson Remote code
Get back to me with model and make of the remotes themselves, I'll see what I can find. Or you can check out http://www.xdiv.com/remotes/ Good Luck
Posted on Sep 14, 2007
SOURCE: i need a remote code for a emerson lcd lc195em82
1. Manually turn on the component you want the remote to
control (TV, VCR, DVD, satellite receiver or cable box).
Note: If you press an invalid key during the Auto Code
Search, the remote does not respond and the illuminated
ON•OFF key does not blink. If you do not press a valid
Auto Code Search key (TV, VCR•DVD, SAT•CBL, ON•OFF,
GO BACK, PLAY, REVERSE, STOP), the search times out
after two minutes. When the search times out, the illuminated
ON•OFF key blinks four times and turns off. The last
programmed code under that component key is retained.
2. If you are programming your TV or satellite receiver, go
directly to step 4.
3. To program the remote to control a VCR or DVD. The
VCR•DVD key can control only one component, either your
VCR or your DVD. To program your remote to control
either your DVD or your VCR, you must first put the
remote in the proper programming mode. Follow these
directions before proceeding to step 4.
a. Press and hold the VCR•DVD key.
The illuminated ON•OFF key
turns on.
b.While holding down the
VCR•DVD key, press and release
the number 2 key on the keypad to
control a VCR or the number 3 key
to control a DVD. The illuminated
ON•OFF key blinks, and then turns
back on.
c.Release the VCR•DVD key.
blinks four times and then turns
off. Your remote is now either in
VCR or DVD Programming Mode,
depending on which you chose.
Proceed to step 4.
4. Press and hold the component key
(TV, VCR•DVD, SAT•CBL) you wish
to program. The illuminated ON•OFF
key turns on and remains on.
5. While holding the component key
down, press and hold the ON•OFF
key. The illuminated ON•OFF key
turns off.
6. After holding down both keys for
three seconds, the illuminated
ON•OFF key turns back on.
7. Release both keys. The illuminated
ON•OFF key remains on.
VCR•DVD
VCR•DVD
VCR•DVD
ON•OFF
(BLINK)
ON•OFF
(BLINK)
ON•OFF
ON•OFF
(BLINK)
SAT•CBL
VCR•DVD
TV
TIP: Throughout the programming of each key, be sure to
keep the remote pointed at the IR sensor of the component you
are currently programming the remote to control.
8. Press and release the PLAY key,
then wait five seconds to see if
your component turns off. If your
component does not respond,
continue to press the PLAY key
every five seconds until your
component turns off. Each time you
press the PLAY key, the illuminated
ON•OFF key blinks and a block of
10 codes are sent to your component.
This process continues until all of
the codes in the Code Lists have
been searched. (If your component
has not turned off after all codes have
been searched, the illuminated
turns off. The Auto Code Search
Entry method is exited.)
PLAY
ON•OFF
(BLINK)
10
11. To confirm that the component key is programmed with the
correct code for maximum functionality, test the component.
Attempt to control a variety of the component’s functions
with the remote. If some of the features of your components
do not work, try programming the remote with a different
code in the list until you find the code that allows the remote
to control the majority of your component’s functions.
Different codes can provide different levels of functionality.
Posted on Mar 26, 2009
SOURCE: Sylvania lc370ss9 remote problem, comcast
you have to turn off the power save setting
Posted on Apr 17, 2009
SOURCE: RCA Universal Remote RCR4258
ive got the same problem.
Did you ever solve it
Posted on Jun 02, 2009
gopakumarg43
  • 75386 Answers
SOURCE: have emerson jumbo universal remote and need code
Hello
Your question is not clear to understand. Yet I'l give you some codes to check with Emerson TV.
Setup codes with One For All URC 3021 remote control with Emerson TV are:
0154, 0236, 0463, 0180, 0178,
0171, 0623
Three digit universal remote codes to check with Emersont TV are:
004/ 009/ 014/ 023/ 024/ 025/ 026/ 027/ 030/ 032/ 033/ 034/ 035/ 036/ 037/ 038/ 039/ 040/ 041/ 042/ 043/ 045/ 046/ 049/ 053/ 116/ 135/ 147/ 177/ 179
Four digit codes are
0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
OK.
Posted on Oct 05, 2011
What is the digital code used by this remote to operate functions of an Emerson LCD Model LC320EM8A
Universal remote codes for Emerson Brand TVs are: 0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
Aug 20, 2012 | Emerson Used Original NF015UD Remote...
Need a universal remote code for Ario tv
From the Ario Website, this worked for me!!!!
"Cable and Satellite content providers control the remote codes, and we apologize for any confusion during the remote programming. Please try the following codes 10019, 0178, 10178, 0030, 10030, 0835, 10835, or for Dish Network try 627, 659 or 505. For Fios TV (Verizon), try the code 3264. These codes may not work on some universal remotes. If there is another code listed for ARIO in your universal remote control guide, please try that code. Refer to the Remote Control Guide under your TV's model number for more information".
Sep 30, 2011 | Televison & Video
Use Comcast and I cannot program my remote. the
The signal is comcast,U have a comcast box right use the comcast remote.Try this website 1-800-Rmotes Factory original.For replacement,less trouble than with the universal remote,cost less the the tv company trying to sell u a new remote.
Nov 18, 2009 | Olevia LT42HVi 42 in. LCD Television
Comcast Remote Control Code
It sounds like you either have a signal issue or a bad converter box, possibly both
Apr 23, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Need code for comcast remote control
HI,
Could you kindly give the exact model of the comcast remote that you are using.
Thanks
Proton
Jan 03, 2009 | Philips 47PFL7403D 47 in. LCD TV
Remote Codes for Comcast remote
Here is where the comcast remote codes (3 in 1) silver are listed:
http://www.comcast.com/remotes/tvcodes.html
Just to be sure, here are the different Comcast remote devices listed on their website. Click on one of them, and a 2-page PDF will open. It will explain how to load your code, and on the second page, list all the codes for your different electronic equipment.
https://www.comcast.com/corporate/customers/customer_support/remotes.html
Merry Christmas.
SJCounterT
Dec 25, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
TRU TECH TV CODES
try code 10030 (comcast remote), or codes for daewoo.
Mar 28, 2008 | TruTech PLV16190 Television
Comcast remote code for 42in sharp aquos lcd
the 10093 code worked perfectly!!! YOU ROCK! the codes in the comcast manual dont work. i don't have an aqquos, but a regular sharp hdtv... purchased in nov '07
Dec 14, 2007 | Televison & Video
RCA RCU300 Remote Control Logo
398 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
