Question about LG VX8300 Cellular Phone
Speaker does not work well....
I just received my new Vx 8300, and the speaker does not work well. The sound is all crackily and I can't hear well. If the phone is on speaker phone, I can hear fine. I didn't know if there is anything I can do.
  • 77 Answers
Trying turning down the volume a notch ...If the soundfiles are "home made" files then it's possible you made them too loud for the speakers on the phone to handle.
Posted on Dec 22, 2007
Why does only center channel speaker work?
Try running a sound test. You should have a test mode that will play a sound through each speaker to see if you have them hooked up correctly. If you still only hear it from the center, unhook the center and connect it to another speaker output, say right front. Run the test again. If you hear something from that center speaker, its the speakers. If not, try each speaker output to make sure the results are the same. If so, you may have an internal board problem.
Good Luck!
Nov 05, 2015 | Denon Avr-1910 Receiver
Hooked it up to my receiver which works perfectly for other devices. Cycled through every setting on the receiver...none work. I just have the red and white hooked into the back properly. I am pretty tech...
The modern computers are set up like an amp with different speaker sets. Windows allows for this under normal circumstances, but when you plug in this turntable the computer fails to find the correct speakers.
- Goto the windows start button - Control panel - Sound - Playback - you will see a number of speaker options and at least one meter that is moving up and down with the sound which you can't hear at the moment. You can do one of two options to fix this.
1) Easiest option, but may cause trouble should you change or add to your physical speakers in the future. - Double click on the speaker with the moving meter, and disable it. A new speaker is then chosen, and if that isn't the right one then do the same thing until the right speaker combo is selected.
2) The best option, as it won't cause future conflict problems. - Ignore the speaker with the working meter. Go to another speaker and double click on it. - Click advanced Tab - Click Test - If you don't hear anything, then move onto the next speaker. If you do hear a sound, then this is the right speaker configuration for your computer. You may have more than one sound card, and likely more than one input. - Once you find the correct speaker, then go back to the main speaker window and single click the speaker to highlight it. - Near the bottom of the window is a pull down menu to make that speaker your default. Do this, and all sound will work.
I can't help you with the amp question, as my ION recorder doesn't have the red/white output jacks for the stereo amp. The only thing I can suggest is it might be the setting on your amp where you choose your input mode.
Dec 26, 2010 | ION Audio Vinyl Recording Turntable
I have a BBRY 8300 Curve and I cannot hear anything in my phone's speaker
then you should take the phone and have the speaker replaced or the pcb main board looked at.
Oct 24, 2009 | AT&T Blackberry Curve 8300 Smartphone
Acer aspire netbook sound distorted
need to bios update. its acer's well known  problem. you should go to service  they will do it under warranty
May 28, 2009 | Acer Aspire 5720 Notebook
No sound from Bluetooth
sound as in you can not hear the person speaker or the phone ringing on your end....if these are the problems maybe the BT headset is faulty
Mar 04, 2009 | AT&T Blackberry Curve 8300 Smartphone
Kenwood VR6070 speaker/amp problems
unit needs repair. Look at the b speakers. Conect a speaker or two to the B position. If you have no sound than your surrond sound is ok and the unit is bad. Sound comes directly into the b speaker and not threw the surrond system. My 6070 has a cold start up problem. no sound. time to purchase a new one. to costly to repair.
Dec 30, 2008 | Kenwood VR-6070 Receiver
Cant get mic to work on webcam vx3000
check that pc sound proteries are set to usb camera and not your computers own sound card . can be check via properties on speaker in task bar. Right click speaker and sellect adjust audio properties and make sure usb camera is selected for voice recording.
Sep 03, 2008 | Microsoft LifeCam VX-3000 Web Camera
Im only hearing static from my new speakers
The problem of your speaker that you can hear a static sound is your speaker is near to be busted.You better resolder the ends of windings of your speaker so it will good again.
Jun 17, 2008 | Audio Players & Recorders
Center speaker will not work
If you had the Speakers Set to A (not B) and no headphones connected when you pressed the TEST TONE button on the Onkyo HT-R540 (also known as the HTS-790) remote, and you had no sound from the Center Speaker then try the following steps. 1) Check the Center Speaker wiring at both ends under a bright light and make sure that there is not a strand of wire touching the Receiver Chassis or another speaker post. Check both + and - . If that looks okay, 2) unscrew the Center Speaker Post connections on the Receiver and verify that the bare stripped wire is making contact. Often, the insulation is too far into the connector. When screwed down, the wire's insulation is crushed and keeps the bare wire from making contact. If this looks okay and the unit is under Warranty, your last test is to: 3) temporarily swap the wires from the Center Speaker with the Right Front Speaker. Turn the volume down low and try the TEST TONE button again. If you now hear sound from the Center Speaker box itself and none from the Right Speaker box, then the Receiver is the problem. If you still do not hear sound from the Center Speaker box, then the Center speaker itself is defective.
Sep 25, 2007 | Televison & Video
Sound problem
dear replace the speaker of ur phone in k300 the speaker and ringer are the same if u not have new speaker then short both point of the speaker to gather will be ok.
Mar 18, 2007 | Sony Ericsson K300
LG VX8300 Cellular Phone Logo
114 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
