Question about Refrigerators
DOMETIC RM 1350 FRIDGE GET HOT AND COLD
I too have the same problem. We have an 2009 Keystone Everest 5th Wheel which we keep at a campgound when we are not traveling.
The refrigerator on from April though Oct., except while traveling
The freezer seems to stay cold but the refrigerator's temperature ranges at times from 52 to 37 dregrees. This has happened on two occassions. When we go down the next weekend might be ok and it might not
I have tried everything I know what to do. What is strange is that this is not constant problem.
3 Suggested Answers
SOURCE: DOMETIC RM 1350 FRIDGE GET HOT AND COLD
Ok, I realize I'm a little late on chiming in here, is this unit located in a slideout, and/or the top outside vent is in the wall not a roof located vent?
If so then the issue is that there are fans that are necessary to circulate air thru the hot coils. And there is probably a malfuntioning thermostat to turn these fans on/off. I had this issue with same fridge in a Gulfstream motorhome, and the temporary fix was to pull the faston connectors off the thermostat and tied them together with a 12V fuse, and taped it up with electrical tape to keep it from shorting on fridge chassis and parts. Replace the thermostat at your conveniance, as these fans are now running whenever fridge is on, and will run your batteries down if not plugged into shore power.
Posted on Aug 24, 2009
ginko
  • 19396 Answers
SOURCE: not cooling as normal 2008
It sounds like a problem with the defrost system that had gone worse in time.
If defrost fan was not working then the fan should have been tested by energizing fan motor. If fan was working, then test the defrost thermostat that start the fan. If fan motor was blown , you should have replaced the fan with original replacement, not with an external fan.
The situation surely put under stress the compressor motor. Probably now the compressor is gone too.
Try defrosting completely the fridge, by leaving it disconnected for two days. If when you restart the fridge, you find that it is cooling again, then it is still defrost system. In this case the fridge will stop cooling after a couple of days or weeks. If it still does not cool at all, check the compressor.
Posted on Sep 22, 2009
2009 Luxury by Design 5th wheel. Where can I get an owner's manual?
PDF]RBD Owners Manual (PDF) - Recreation by Design
www.recreationbydesign.us/downloads/RBD_owners_manual.pdf
Also, please review all component manufacturer's owners manuals ... Call our factory and obtain authorization for repairs BEFORE attempting the repair yourself ...... If thefifth wheel is hitched up with the front too high, too much weight will be.
Owner's Manual - Keystone RV
www.keystonerv.com/customer-service/owners-manual
Download the Keystone Owners Manual Revision 4/01/2015 · Download the KeystoneOwners Manual Revision 4/1/14 · Download the Keystone Owners ...
2009 luxury by design 5th wheel rv owners manual - Fixya
www.fixya.com/.../t26003542-2009_luxury_design_5th_wheel_rv_own...
5 hours ago - I have been told it is the circuit board. Can I replace this part myself. Thermostat is Duo-Therm by Domestic. In 1998 Aljo RV 5th wheel. Appears ...
Luxury By Design Travel Trailers - PPL Motor Homes
Dec 11, 2015 | RVs
I have an Innsbruck 5th wheel, my refrigerator won't run
check back see if chimney is hot on electric or LP see if lit if hot unplug the thermistor from the back board let run if gets cold replace if not bad board or cooling unit
Jul 07, 2014 | Dometic RM2652 Refrigerator
It was working fine it was unplugged to be moved now it wont work on electric or gas its a rm 760 gas or electric domestic
When operating on Electric, if the rear of the cooling coils get warm and the fridge is level, but the refrigerator does not get cold then it is more then likely your cooling unit that has failed. Visit ArctiCold Refrigeration We keep it cold for info on replacement cooling units.... I have also attached a video with tips on diagnosing the RV fridge,
Arcticold New replacement cooling units can be purchased from Ebay Dometic RM760 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Sep 16, 2013 | Dometic Refrigerators
Dometic RM 4224 won't cool on gas or electric. The stack in the back gets super hot, the fridge is not cool at all.
First ensure that the fridge is level. If the fridge is level and still not cooling while there is heat on the rear of the fridge, then you will require a replacement cooling unit. Give Arcticold a call 1-888-782-6665 Web site: ArctiCold Refrigeration We keep it cold
Online Store: http://www.rvfridgerepair.com/
Aug 22, 2013 | Dometic Refrigerators
I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Thanks
Jan 23, 2011 | Dometic Refrigerators
Having trubble with hot water. It won't run up the sinks or shower only cold water. I own a 2008 keystone everest
Check to see if it has a hot water heater bypass installed,if so the valve is likely in the bypass position...
Dec 17, 2010 | Water Heaters
Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Jul 06, 2009 | Dometic RM2620 Refrigerator
Mar 31, 2009 | Refrigerators
Refrigerators Logo
225 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
