Mouse and keyboard conflict when have two systems
I have two identical systems located on opposite sides of a 10 foot desktop. Periodically one mouse will start jerking or stop working when both are in use. Additionally, the keyboards also act screwy (typing only part of the letters or needing to press the key several times to get a response) when both are in use.
Obviously there is something sending conflicting signals to the mouse or keyboard when this happens. How can I fix this?
P.S. The office is built in place and moving the computers is not an option.
  • aa1Consult May 11, 2010
    wireless devices?
    New Friend:
    Problem Solver:
  • 11 Answers
Use kvm... stands for keyboard video and mouse.. thi is available in vomputer store.. this device combine 2 computers in to one kebaord and mouse also video
Posted on May 08, 2017
SOURCE: acer cordless keyboard
How to activate Acer cordless itouch keyboard CE06781 ?
Posted on Jan 16, 2008
SOURCE: keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Posted on Jun 26, 2008
  • 207 Answers
SOURCE: Microsoft wireless optical desktop 2000 - keyboard and mouse
There are a number of things that may be causing your problem.
The first thing I would check would be the batteries, with these units having a wireless connection if the batteries become weak they will transmit a weaker signal and thus make it harder for the unit to read. Battery life is variable depending on how often you use your keyboard and mouse, and how far away from the transmitter the keyboard and mouse sit.
Also because the units are wireless there may be interference coming from other wireless devices in your household. Some possible guilty devices maybe cordless phones, Wifi adapters, and even some remotes.
Also Have you installed the intellitype and Intellipoint software for your Mouse & Keyboard. If so you can use it to check your battery life/ signal strenth and set you mouse sensitivity and type repeat rate.
On the bottom of your keyboard & Mouse and on the top of the wireless transponder there are reset buttons. Pushing the transponder 1st and then either or both the mouse and keyboards buttons should resysnc them without the need for a reboot.
Hope this helps
Posted on Nov 06, 2008
  • 8637 Answers
SOURCE: Keyboard is messed up
Try looking here to see if any of the keys are set wrong.
Normal 0 If you are then go to Control Panel.
1. Click on PRINTERS.
2. When the Printer Properties come up, CLICK on KEY SETTINGS.
3. Then set up the keys by selecting the key to be setup.
Hope this helps. Bud
Posted on Jan 17, 2009
  • 547 Answers
SOURCE: keyboard keys that have purple numbers are locked. Can't type.
Your "Num Lock" is on.
Look for the num lock key (it's similar to the "caps lock" key in function)
If the "num lock" is blue, you may have to hold a blue "fn" key when you press num lock
There's is probably a light at the top of the keyboard that'll tell you when num lock is on.
Posted on Sep 20, 2009
Will other Logitech mouse work with Logitech EasyCall Desktop?
Hi Warp you can not use any other mouse with your Logitech Easycall Desktop receiver, but with the additionnal mouse's receiver connected you should not meet any conflict using both at the same time. Thanks and have a nice day. Crenshow
Jun 06, 2010 | Logitech MX 600 097855036162
Keyboerd failer when starting
try to change the mouse or keyboard from serial connection to usb, or likewise, might be both of them are conflicting..if both are usb...also update the drivers, try it.,,
Nov 10, 2009 | Dell Dimension 2400 PC Desktop
Every now and then it frozes. I have noticed that
It was quite simple. It was due to a conflict between the wireless router and the wireless receiver of the mouse, I just relocate the mouse receiver using a USB extension -that by the way came with it- to the opposite side of the router which seats at the left of my computer -the mouse receiver is now at the right of it- and the problem was solved.
Sep 30, 2009 | Logitech Cordless Desktop MX3200 Laser...
Dell Studio 15 laptop mouse does not work at start up.
It sounds to me like the mouse buillt into your laptop is conflicting with the Dell external mouse. If you go into control panel and click on mouse, you can disable your built-in mouse. Restart your computer with the USB mouse plugged in and see if that does the trick. I would be surprised if it does not. On the off chance it doesn't work, you will have to enable your built-in mouse and we can check to see if there are any additional conflicts happening through your hardware profiles in the system area of control panel.
Jun 21, 2009 | Dell U0636 Mouse
Irq dma err
IRQ's (Interrupt Request) LinesIRQ's are hotlines to the main computer (CPU) that allow devices connected to the computer to signal the CPU that they need immediate attention. If you're a Batman fan, think of IRQ's as the Batphone - getting his attention immediately.
Not all devices require IRQ lines, which is good news because in modern (post IBM XT) computers, we only have 16 of them. Of those, 3 are already dedicated to the main system board itself - the system timer, keyboard, and memory parity error signal. That leaves only 13 for all the other devices connected to your computer. This is why IRQ conflicts are probably the #1 problem faced by computer users when they add hardware to their computer.
Its a general rule for ISA-type systems (the standard computer architecture used in most IBM compatible systems) that IRQ lines CANNOT by shared with multiple devices except under special circumstances. For this reason, a good understanding of what IRQ's are assigned to what devices is essential in avoiding conflicts. The table below is a general outline for standard IRQ assignments.IRQ DEVICE USED in AT, 386, 486, and Pentium Computers
0 System Timer
1 Keyboard Controller
2 Tied to IRQs 8-15
3 COM 2
4 COM 1
5 LPT2 or Sound Card
6 Floppy Diskette Controller
7 LPT 1
8 Real Time Clock
9 Substitutes for IRQ 2
10 Not Assigned
11 Not Assigned
12 PS/2 Mouse Port
13 NPU (Numerical Processing Unit)
14 Primary Hard Disk Controller
15 Secondary Hard Disk Controller
Depending on the computer's configuration, add-in devices such as SCSI controllers, sound cards, modems, cd-roms, etc. will want an IRQ line that is already used by another device, and thus we have what is commonly referred to as an IRQ Conflict.
The most common IRQ conflicts seem to be between two COM ports, generally a mouse and modem conflict that ends up freezing the mouse whenever the modem is activated. The table below explains each IRQ and the most common devices each may use.
Oct 18, 2008 | Computers & Internet
    1. Check your Keyboard-Video-Mouse (KVM) switch. If the system is connected to a monitor, mouse, and keyboard through a Keyboard-Video-Mouse (KVM) switch, or console selector switch, then disconnect the switch and connect monitor, mouse, and keyboard directly to the system. If this solves the issue, please contact your switch manufacturer for support and compatibility on the switch. Some switches can have a firmware update applied to resolve common problems.
      Note: BladeCenter Telco chassis - The KVM module contains keyboard port, mouse port, Power LED, Location LED, Critical Telco Alarm LED, Major Telco Alarm LED, Minor Telco Alarm LED and a video port. The PS2 keyboard and mouse connectors are standard 6-pin Mini Din. The Telco alarms mirror the Telco alarms located on the front panel of the media tray because they use the same signal lines. The KVM module allows the connection of a VGA monitor for system maintenance and control. The video connector is a standard 15-pin VGA. The KVM module is hot-swappable. It is docked into an edge card connector located on the backplane:
    2. If you have your system daisy chained for KVM capabilities using the C2T port (e.g. xSeries 330),
      then you must flash the C2T firmware after flashing the system BIOS, in order for the mouse and keyboard to work. Otherwise, after a BIOS flash, you will lose keyboard/mouse capabilities unless you walk up to each machine and push the select button.
    • If you are using NetBAY Advanced Connectivity Technology (ACT) CAT5 cabling in your rack server, instead of KVM cabling, click here for ACT information.
    1. Check for POST/startup errors. If you are getting a POST/startup error on the keyboard and/or mouse:
    2. Verify that all items are firmly connected to the correct ports, and that the cables are undamaged with no bent pins. The PS/2 style mouse and keyboard ports look identical, but are not interchangeable. The mouse and keyboard must be attached to the correct ports in order to be recognized by the system and to function correctly.
    3. Swap each item for known good units. If a new item works where the original did not, then the original component must be faulty.
    4. If the keyboard works during the POST/BIOS screens, but not in the operating system, check software logs for device driver errors. Contact your software vendor for more support in configuring the I/O devices.
    5. Check the F1 Setup error logs for system component failures or errors. These are found under Event/Error Logs. Troubleshoot suspect components further to determine if the hardware is faulty. If an IBM component is determined to be faulty, please contact your local IBM Support Center for warranty replacement of the part(s). Please have the Field Replacement Unit (FRU) / Customer Replacement Unit (CRU) part number and Machine Type, model and serial number ready.
    1. Run hardware diagnostics. Replace any parts found defective.
    Download the latest diagnostics for your system
    1. If you can down the system, check the keyboard cable connector on the system unit for proper voltage.
    2. Power off the system.
    3. Disconect the keyboard cable form the system unit.
    4. Power on the system and check the keyboard cable connector on the system unit for the voltages shown:
      PIN Voltage (Vdc) 1 +5.0 2 Not used 3 Ground 4 +5.0 5 +5.0 6 Not used
    5. If the voltages are not correct, replace the system board. Otherwise, replace the keyboard.
    6. If these steps have not solved your problem:
    Jun 30, 2008 | IBM NetVista PC Desktop
    Screensaver will not activate...
    I would remove the software for your keyboard. This will hand control of the screen saver back over to windows. Some keyboards come with third party software that conflicts with windows. If you want a functional set of "extra stuff" on your keyboard, then your best bet is to try one from another manufacturer.
    Jun 16, 2007 | Logitech Cordless Laser Desktop MX 3000...
    Computers & Internet Logo
    256 people viewed this question
    David Payne
    David Payne
