Question about Bosch Dishwashers
How to tighten handle on bosch dishwasher - Bosch Dishwashers
  • 601 Answers
Hi...
With the door to the dishwasher open, unscrew (using apropriate sized allen wrench) the screws surrounding the outer perimeter of the door. As you do, be careful, as the outer shell of the door will begin to fall. Once you take off this outer shell, you can easily tighten the handle, then screw the shell back into place.
Very annoying design flaw. Let me know if that worked.
Thanks and Rate
Smith
Posted on Jul 26, 2009
My bosch dishwasher (SHX46A05UC) has 2 problems:
there is not a manual for that kind of troubles,,,about the propeller is atached to the upper rack wout tools,,remove the plastic frame is in the lower of the upper rack and assembled backusing only your hands...theouter handle ...inside around the door have scrws remove thoes,you can see the loose srews of the handle,,
Feb 06, 2013 | Bosch 24 in. SHX36L05UC Stainless Steel...
How do I tighten the door handle on my Bosch dishwasher model SHY56A 05UC/14?
Remove front panel then you can access the handle screws. Open the door and remove the 'torx' screws surrounding the perimeter of the door.
Oct 06, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
Door handle need to be re tightened. Do you hav...
if its just the handle itself it sounds like the fixing clips have come adrift or broken off,the handle strip will need replacing if its the whole console thats loose remove the outer door cover this will give you access to panel screws and may allow you to see more of the handle fitting inside.
May 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Front handle is loose on my bosch dishwasher.., how do I tighten it?
remove srews that hold inside panel should give you acsess to handke tighten and replace screws
Dec 06, 2009 | Bosch SHX43M05UC Built-in Dishwasher
Loose door handle on bosch integra ltd. dishwasher
you can loosen the inside of the door with a small torx screwdriver and lift it up far enough to get to the screw that holds the handle from the inside. I did this with mine about 1 year ago.
Aug 30, 2009 | Bosch Integra® 500 SHX46L Built-in...
Hi,I have a Bosch dishwasher SHY 66C02 UC and the handle is loose. What do I need to remove to get access to the front panel? Thanks, Will
u have to remove the torx screws on lhs and rhs of the door and a also at the top of the door.once u remove them the front panel will come out and u can tighten the handle screws.good luck.
Aug 18, 2009 | Bosch Dishwashers
My bosch dishwasher handle is loose
Hi rsouthwick,
I'm Harvey the Master Plumber.
You want to know how to tighten a bosh d/w handle?
Easy! open the door and look around the perimiter. You'll see screws on the right and left, they hold the front panel on. Simply remove them. The front panel is off and you can tighten away!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 12, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Door Handle: Loose
I had the same problem with my Bosch dishwasher.I came to this web site to find out how to get the door off.I took the experts advice,placed 4 pillows on the floor in fromt,opened the door,took out the screws and the front panel dropped down.It was so easy,the plastic spacers stayed in place.I put a little J B weld on the handle screws and tighted the handle and put everything back together,12 minutes tops.Thanks for the help,thankful in Georgia
Jun 09, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Loose door handle
Here is the link to the installation manual; http://www.bshextranet.com/files/techtoolbox/SHV46C13-SHX43Cii.pdf pages 14 and 9 of the manual (16 and 11 of the pdf) describe how to remove the toe panel, and the door facia panel. You should then be able to access where the handle is attached. Hope this helps :)
Jul 15, 2007 | Bosch SHV46C03 Built-in Dishwasher
Dishwashers Logo
56 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
