I have a very bad odor coming fron m my GE Zoneline 2100 ac unit. What can i do to get rid of the smell?
  • 614 Answers
You have what they call dirty sock oder. You need to clean the coil. Use bleach 50-50 mix and spay the coil let it set a few minutes and spray water on it to rinse. Russ
Posted on Jul 26, 2009
Bad smell coming from ac
Weird Car Air Conditioner Smell: What It Means and How to ...
www.carsdirect.com > Car Maintenance > Interior Car Maintenance
This causes an unpleasant odor coming out the air conditioner unit. Also ... This can result in a bad smell every time you turn on your air conditioner. You can ..
Sep 30, 2015 | AC Cars & Trucks
Why is there a ***** smell?
I worked extensively on GE Zoneline AZ Air Conditioners and Heat Pumps while a Maintenance Superintendent at a Senior Citizen's Apartment Complex. Not knowing what type of smell to which you are referring, I can assure you that other than "burnt electrical" smells, the only smell that could possibly be produced would be that from within the INDOOR SPACE. Perhaps something has made its way into the INDOOR AIR FILTER? Perhaps that INDOOR AIR FILTER needs to be cleaned. To clean the INDOOR AIR FILTER, simply lift both of the filters from the front cover, take to your clean bath tub. Run EXTREMELY HOT WATER from the back of the filter to the front of the filter. Then, fill your bathtub 1/4 way with EXTREMELY HOT WATER. Add 1 cup of Hydrogen Peroxide and 1 cup of Real Lemon Juice. Set both filters in this solution for 30 minutes; then rinse with clear water. Set filters up to dry for at least 2 hours in the sun or an air breeze. Replace filters into the GE Zoneline.
Also, not knowing how OLD your GE Zoneline system is, the COILS may need to be cleaned. To do this, simply turn OFF your GE Zoneline unit and remove the front COVER of the unit. Next, mix in a spray bottle 4 packets of LEMON flavored KOOL-AID (without SUGAR) and water. Shake well. Spray the INDOOR COILS of your GE Zoneline unit with the entire contents of this mixture. Let set for at least 10 minutes. Then turn your GE Zoneline to the COOL position. The citric acid in the lemon kool-aid will be forced through the coils to continue to remove any dirt, dust, debris and effectively CLEAN those coils. This will also provide you a LEMONLY odor within your room. Simple and cheap.
Enjoy your GE Zoneline unit.
Aug 30, 2014 | GE Zoneline AZ55H07D Air Conditioner
My model AZ22E15 zoneline not turning on
those are the specs. It is possible that the transformer is out.
Oct 27, 2009 | GE Zoneline AZ22E15E Air Conditioner
MY AC IS GIVING BAD SMELL WHEN I ON IT
Is this a burning smell. AC units sometimes have what they call dirty sock syndrome. The evap. coil has bacteria that puts of an odor. You have to have the coil chemically cleaned and sanitized to get rid of the odor. Rus
Oct 04, 2009 | Heating & Cooling
Compressor keep running in off position
you could have a relay or contactor inside the unit welded closed, therefore compressor will keep operating when unit is off. replace compressor contactor.
Feb 09, 2009 | GE Zoneline AZ55H07D Air Conditioner
Cold Air Penetrating from around & thru GE Zoneline 2100 Unit
There is a baffle/damper that allows outside fresh air to flow through the unit. This is only supposed to be open in cooling mode when the outside temp is moderate, or whenever you want just fresh air and fan operation.
Find the lever that controlls the baffle.
Some units have a switch in the control panel for this.
Jan 19, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Filters needed for Old GE Zoneline 2100
My name is brian pfeiffer . I run a ptac business in griffin ga. I have many parts and filters for most all types of ptac units. Please feel free to contact me at brian@dreamgreenservices.com. Nobody can beat my prices!!!! Or call me at 770-233-9987
Sep 03, 2008 | GE Zoneline AZ38H12DAD Split System Air...
The clothes smell if left in the washer wet overnight
Wet clothes should not be left in the washer over night as mold will develop and cause a moldy odor. You could run the load through a rinse cycle with fabric softener or baking soda to get rid of the odors.
Jun 07, 2008 | GE WHRE5260E Top Load Washer
GE Zoneline 2100 heater/ac won't heat/doesn't shut off
well, it's been almost 4 years since this was posted, but it's the selector knob. these things are HORRIBLY designed (the selector knobs) very easy to break if someone pushes it to the side too hard.
ASSUMING when you cleaned it, you didn't get the controller knob wet, which could cause heat and ac to come on at the same time. If after a few days, it's still the same, it's the selector. I've replaced a million of them (ok, not really a million, but, a lot.)
Jan 22, 2008 | Heating & Cooling
I WANT TO BUY THE UNIT WHICH CHANGE HEATING AND COOLING AND TEMPERATURE UNIT FOR GE ZONELINE
WITH ANY OF THESE UNITS YOU CAN WIRE AN EXTERNAL THERMOSTAT WICH WILL ACOMPLISH THIS, JUST MAKE SURE YOU PURCHASE A T-STAT WITH A HEAT / COOL AUTO CHANGE OVER.
Jan 10, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
264 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
