Question about Philips bSure SV2 Multimedia Projector
Philips LC3132 runs 5 minutes and red lamp flashes/goes standby
The projector works fine for 6.5 minutes and then the red "lamp" button flashes and the projector switches into standby mode. After shutting down it will power up again and works for the 6 (or so) minutes before repeating the same problem.
SOURCE: Philips bsure SV1 , LCD multimedia projector
Pl try M. R. nterprises Mumbai +91 22 23802513/23856204
Posted on Nov 25, 2007
Gigatech
  • 259 Answers
SOURCE: Status light blinking red
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Posted on Feb 27, 2008
  • 5 Answers
SOURCE: sanyo plc xu 40 lcd projector problem
not only reset the timer is good enough
u must use serive cable to disable the shut off function
and technically reset the system
Posted on Jul 10, 2008
SOURCE: Philips Hopper SV20 Impact Multimedia Projector doesnt power up
hi the power supply of your unit is burnt refer service personnel
shyam
+919867355202
Posted on Feb 08, 2009
  • 1341 Answers
SOURCE: the projector does not operate the
either it's overheated or needs a replacement bulb.Do not cover this unit with anything as it will prevent cooling down..
Posted on Jul 27, 2009
Viewsonic projector Pro 8200 will not start / get out of standby mode
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 03, 2014 | ViewSonic Office Equipment & Supplies
NEC vt800 projector troubleshooting
That is a problem with the lamp. Replace it with a known good one.
Feb 27, 2013 | NEC VT800 LCD Projector
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
Lamp light flashing
hi during my investigating i found that the eletrorode surge arrester was causing the problem epcos component 800 083 number i found a device from a projection tv and it worked i also checked epcos web site but could not the accurute device number . they will ask u to use a ruler to measure the device size of the component thanks
Jan 10, 2009 | Philips LCA3123 Projector Lamp for Bsure...
Projector problems
Hi David IB
I've had teh same experience with a BenQ MP720 ( just the XGA version of your Projector )
I queried this with BenQ Engineer in Dubai and he said that it sometimes works exactly like a short on the machine.
If I could give you a tip , If it happens again don't put back the metal cover of the Mainboard it solves the problem 100%
Nov 19, 2007 | Office Equipment & Supplies
Philips bSure SV2 Multimedia Projector Logo
273 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
