Question about Mitsubishi WS-55819 55" Rear Projection Television
Mitsubishi WS 55819 with a convergence
I have a Mitsubishi WS 55819 with a convergence problem. I have replaced both of the STK392-570 ICs.
Now the blue Convergence will adjust but the red is still bowed at both ends and will not adjust. Is one of the STK chips for the red and one for the blue. If so which one is the Red. If not what other problems do I have.
  • 5 more comments
  • Kaf0007 Dec 16, 2007
    Where do I find the convergence ic's in my Mitsubishi ws 55819 tv?  Opened tv and did not know where to look.  Help please
  • Anonymous Dec 27, 2007
    when first turn on tv, have "happy face" curve at top and "sad face" curve at bottom of screen, with double image in red and green. After a minute or so disappears. After two weeks of this, now getting full screen green background then changes to red background, also lots of "bleeding".
  • cem0201 Aug 05, 2008
    Thanks for the help. The IC's did the trick. I replaced both IC's but one of the replacements was bad. I ordered a new one. and replaced one at a time. I got lucky on the first try.
    Thanks
    cem
  • mike boyd Feb 07, 2009
    I have a convergence problem. My red is out of whack with the other colors on about 3 out of 4 corners..bows down away from the others. The convergence adjustment for red does nothiing..help.....is the convergence ic's something i can replace on my own?
    do they solder in or plug-in?
    thanks...mb
    I have a color convergence problem with the red on my mitsu ws-55819
    I have been told that it might be a convergence ic problem
    is that something a guy can replace himself at home...do they plugin or solder in place?
    thanks
  • Santa22 May 09, 2009
    "fish eye" convergance issue. How do I locate and replace STK-392's? Had repaired profesionally 2 years ago - doing it again and I need to try to fix myself this time.
  • Anonymous Mar 27, 2014
    mitsubishi ws-65711 red convergence problem green light front panel flashing
  • 39 Answers
CEM-NO, BOTH ICS' WORK ALL 3 CRT YOKES.YOU EITHER NEED TO REALIGN THE RED IN FACTORY CONVERGENCE MODE OR YOU HAVE A RESISTOR THAT HAS FAILED.THE LATTER YOU MAY ACTUALLY BE ABLE TO SEE IF YOU LOOK CLOSELY.OH, ALWAYS DOUBLE CK. YOUR SOLDER CONNCETIONS.GOOD LUCK. JOE TV
Posted on Nov 29, 2007
How do I fix the 2,2 error on the ws-55819?
install the convergence repair kit for your model. The 22 error is almost always caused by shorted Convergence ICs and blown picos. You can get the convergence repair kit for your model at www.tvrepairworld.com
Aug 05, 2011 | Mitsubishi WS-55819 55" Rear Projection...
I have a Mitsubishi WS-55819 and the screen is curved and looks 3d. The colors are also blurry. When it warms up it looks better. Any suggestions?
It could just be the solder on the convergence ICs which needs to be reflowed. If that doesnt help then the ICs will need replacement. Your model uses 2 of the STK392-570 ICs. If you need further assistance please let me know.
Thanks
Sonny
Jun 09, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Can not align red even though convergence board WS-55819
Did you replace the center board with the STK-392-570 chips or the Digital convergence board mounted on it?
98% of the time if you have a convergence problem it is on the center board---the small board on the left under the metal shield box stores and controls the convergence of this set.
WHICH DID YOU REPLACE?
I am here to help----I have fixed hundreds of Mitsubishi sets with convergence troubles.
Regards, SD TECH
Oct 28, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Colors are bleeding and picture blurred. Can't adjust convergence settings.
Replace the two Convergence amp ICs they are both STK392-570 Ics you can get replacements at the following link with free instructions on how to remove the old and replace the new ones.
http://servicemanuals.vstore.ca/
May 23, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55819 Won't turn on
If F9A04 and F9A05 are open the convergence ICs will need to be replaced as well as the two pico fuses. You will need two STK392-570 Convergence ICs and two 5 amp pico fuses. You ca get the replacement parts at the following link with free installation instructions. heres thelink.
Jan 22, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Convergence
best place to get them with instalation instructions included is the following link. you need two STK392-570 ICs
Jun 17, 2008 | Mitsubishi WS-55819 55" Rear Projection...
WS-55819 Mitsubishi Rear projection TV Picture goes blurry
Convergence ICs are bad need to be replaced. You will need to replace both of them also check the resistors right next to the IC often 1 or 2 of them burn out when the IC goes.
Feb 26, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Convergence Problems
GREEN-YOU HAVE TWO STK392570 CONVERGENCE ICS' GETTING READY TO FAIL.SOME FOLKS HAVE REPLACED THEM ON THEIR OWN,OR YOU CAN GET A REPAIR TECH TO DO IT FOR AROUND 300.00$.JOE TV
Oct 29, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Convergence problems WS-55807
On this model if the fuses that protect the convergence circuit would open up, then the set would not come on. The convergence ICs probably have a cracked solder joint on the foil side of the circuit board.Re-flowing the the solder would help. I will always replace the convergence ICs when doing this job. The labor remains the same and you will have to pay a few extra bucks for the parts. Hope this helps.
May 12, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55819 55" Rear Projection Television Logo
435 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
