SOURCE: replacing a conventional defrost timer with adaptive defrost assembly 61005988
This is a diagram of that model #... says has adaptive defrost should help ya out
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0165000&brandID=3048&modelDesc=MAYTAG%20REFRIGERATION&modelNumber=MSD2758GEW&documentID=M0312518&documentTypeID=PLDM&documentClassCode=PV&titleType=WIRING%20INFORMATION&titleID=00012&
SOURCE: Kenmore C978-66792-1 fridge: defrost ices and stops fan
It should just be your ice maker wires and wouldn't be the issue with this fridge
SOURCE: Frigidare refrigerator FRS26ZTH FREEZER FREEZING UP/FRIG NOT COOL
also check defrost timer,defrost thermostat. In
most newer models the timer has been replaced by an electronic control board.
If the heater and thermostat are ok it’ll be the control.
SOURCE: Kenmore won't cool down.
I you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
