SOURCE: Emerson Research Clock modelSmartSet
The problem is most likely the frequency of the A/C power there. In the US our power runs at 60 cycles p/second and the alarm clock uses this to set the time. Sounds like India is running 50 cycles like Europe does. Most likely there is a jumper in the clock because the Ckt board on mine shows a 50/60 hertz setting but with out the board schematics I wouldn't have a clue how to fix it. Sorry not to help more...
SOURCE: Emerson Smartset Radio Model CKS2288
The Daylight Saving dates appear to be hard-coded per the manual:
• Start of Daylight Saving Time:
At 1:59.59 AM on the first Sunday in April, the clock will automatically advance to 3:00 AM.
• End of Daylight Saving Time:
At 2:59.59 AM on the last Sunday in October, the clock will automatically reset to 2:00 AM.
So the easiest thing to do is to change your time zone up or down one for the period between the new DST date and the old -- or you can buy a new SmartSet for about $15. The newer ones do not have the same problem.
SOURCE: Emerson Research SmartSet Clock Radio
There is a solution for this already. You can reprogram the clock to use the new DST settings.
See http://www.fixya.com/support/t137304-daylight_saving_time_issues
Hello everyone,
I finally found a manual that I hope that it will help you as much as it helped me. It took long enough. Here goes; try this site:
http://www.emersonradio.com/owners/SmartSet%20Series/
These clocks actually was designed to be adjusted to change at the new times too.
I adjusted mine since 07 and it changes like 'clock work' as normal at the new dates.
To program it you have to follow these instruction
I will post the solution shortly
