Question about Dual Car Audio & Video
I'm trying to put an aftermarket stereo into my 2002 chevy blazer but can't figure out the wiring. I can't get it to power up. Does anyone have any ideas?
  • 655 Answers
Hello dusashbrax,
The wiring color code for the 2002 Blazer is here. Just match up the function of each wire on the aftermarket receiver with the appropriate color wire from the vehicle.
A better solution is to purchase a vehicle specific wiring harness. Then you just match it up with the receiver harness color for color.
Hope this helps.
Posted on Jul 26, 2009
99 Chevy blazer wiring trying to hook up stereo
use a test meter to find the feeds and the earth and little pp9 battery to locate the speaker wires simply by connecting across the battery and blip will be heard from the appropiate speaker
Aug 04, 2012 | Chevrolet Cars & Trucks
I had bought a dual xd1222 aftermarket stereo. i bought a gm2000 harness for it to hook up in my 2002 chevy cavalier. i have all the wires connected but when i hook it up in the carit will not work. what...
check the fuse behind the stereo and in your fuse box first off and make sure the power wire/ignition wires are on the correct pin. do this with a test light for verification. also check the ground wire. after you test and connect these 3 wires, the stereo should turn on. Your wiring harness may not be done correctly so visual verification with a test light would be the best thing before starting a car install. If this still does not work and the stereo you took out did, it is a malfunctioning unit.
Sep 11, 2010 | Dual Car Audio & Video
Which color wires go together in a 2002 chevy impala stereo to make it turn on?
If its an aftermarket stereo, the Yellow wire will be 12v all the time. Red is when ignition is turned on, and black is ground. The rest are speaker wires. Mike. Rate 100% please.
Sep 19, 2009 | 2002 Chevrolet Impala
I put an aftermarket cd playeer in my 01 chevy blazer. On the steering wheel there are volume controls etc. The wires do not hook into the new stereo. how do i hook these wire into the new stereo when it...
in order to use the streering wheel controls you have to have a stereo with a remote control. you can the purchase a part that will connect to your steering wheel controls and send a signal to your stereo. i do not know what the name of the part it is, but if you check with a local electronics store I'm sure they can help you.
Jun 09, 2009 | 2001 Chevrolet Blazer
I can't figure out how to set the clock on my aftermarket delco loc-ii compact disc car stereo
I don't know how my question got posted under a 1993 Chevy k1500 truck. My problem was trying to figure out how to set a clock on an aftermarket Delco loc-II am/fm cd car stereo. And NO, I still have not found my answer.
Feb 18, 2009 | 1993 Chevrolet K1500
2002 CHEVY BLAZER
Can purchased an adapter kit at Best Buy or Circuit City that is color cordinated with the factory wires for about 12.00. This will go right into the factory plug.
Radio 12v orange + radio harness
Radio Ground black - radio harness
Radio Ignition dk. green + radio harness
Radio Illumination gray (dimmer) + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- tan - gray +,- radio harness
RF Speaker +/- lt. green - dk. green +,- radio harness
LR Speaker +/- brown - yellow +,- radio harness
RR Speaker +/- dk. blue - lt. blue +,- radio harness
Immobilizer Bypass Module: Required: Yes Type: Passlock 2 Part #: 457G, 555L, or 555T
Notes: The Passlock 2 wire colors are yellow, orange/black, and red/white (not used).
Sep 21, 2008 | 2002 Chevrolet Blazer
2002 chevy blazer
have you tried to jump start the truck?
Aug 20, 2008 | 2002 Chevrolet Blazer
2002 Chevy Blazer
you could be draining the alternator and battery with the new stereo..depending on how you hooked it up you might try charging the battery back up.you were supposed to take off the pos cable not the negative
Car Audio & Video Logo
205 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
