Question about eMachines W4620 Notebook
My Emachine laptop model W4620 puts itself into standby before it even loads the sign on screen; it won't even let me strike F2 to enter the BIOS or F10 for setup. I pulled the battery out for a minute & it worked fine-once, and now that doesn't work either. What can I do to fix this?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 381 Answers
Into the bios and set you all, clock, hdd, DVD and other set when i can then save and exit, if after use and close the unit and is again able to use some time lapsed and this is the same still only one message means that your damaged battery and need to replace its battery, good luck and hopefully I helped you
Posted on Jul 29, 2009
Reset bios
  • Restart the system. Click on "Start," "Turn off Computer" and "Restart."
  • At the Dell loading screen Tap "F2" to enter the BIOS. "Entering Setup" will appear. Certain models may use a different key. The key will be displayed during the boot process. For most Dell models, the key is "F2."
  • Once loaded, depending on BIOS version and type, you can reset the defaults by using "F9" key to Load Defaults, the "Load defaults" button on screen, or the "Alt" + "F" key combination to load factory defaults.
  • Press "Esc" on your keyboard and select save and exit.
  • Choose the "Enter" key to save all changes and exit the BIOS screen. Allow your system to restart for the BIOS settings to reset.
Aug 30, 2013 | Dell Inspiron Computers & Internet
Tip
Emachine e4264 bios update
There is an updated version of the BIOS for emachine model e4264 that fixes some hardware compatibility issues as well as other things for windows vista.
There is a read file you can download here
As well as the driver here
To install the driver download then follow these steps
1. Use CDRW burning software to Burn Disc Image of the C:\Cabs\4GC3110E\4GC3110E.iso file to a blank CD. 2. After creating the bootable CD, place the CD in the CD/DVD drive, and then restart the computer. 3. At the Menu, select 1 for eMachines BIOS 4GC3110E. The BIOS flash process runs automatically. Do not press any keys or turn off the computer during this process. 4. When complete, the message "Flashing Complete" flashes. Remove boot media used and press the F1 key. 5. Press the F2 key to enter the BIOS Setup Utility. 6. In the BIOS Setup Utility, select Load Optimized Defaults, and then press the ENTER key. 7. Press the Y key, and then to select Load Optimized Defaults, press ENTER. 8. In the BIOS Setup Utility, select Save and Exit Setup, and then press ENTER. 9. Press Y, and then press ENTER to Save and EXIT.
on Dec 30, 2008 | E-Machines eMachines Desktop PC
How do I get past theYour pc will restart in 2 days to finish installing important updatesIt won't let me enter my password to unlock the pc
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
This will set the boot order
If this fails you might try some of these
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Jun 23, 2013 | Acer Computers & Internet
Default boot order for emachine laptop 732
Step 1:
All computer systems go through a set of instructions called the Basic Input/Output System (BIOS) when they are turned on. The BIOS checks all of the hardware and software installed on the computer to make sure they are working properly before loading the operating system. You may need to access the BIOS menu periodically to find out the current version of the BIOS you have if there are upgrades available. The command you use to access the BIOS settings on an Emachines computer will vary depending on the specific model you have.
Access the Start menu and click "Shut Down." Select the "Restart" option. Wait for the Emachines logo to appear on the screen as the computer begins booting up again. Press the "Tab" key when the logo appears and see if the computer switches to the BIOS menu. Press the "Escape," "Delete," or "F2" keys if the "Tab" key doesn't take you to the BIOS menu screen. Use the right arrow key to highlight the "Main" entry and press Enter. Scroll down to the heading labeled "BIOS version." Check the long string of numbers and letters under the "BIOS version" heading to locate the current BIOS version your Emachines is using. Press the "F10" key to exit the BIOS menu screen and finish booting up the computer's operating system.
Access/Enter Motherboard BIOS http://michaelstevenstech.com/bios_manufacturer.htm
Feb 22, 2013 | eMachines Computers & Internet
Remove toshiba password from bios satellite 3000-x4
The Basic Input/Output System (BIOS) password is not set by default on Toshiba laptops. When set, the BIOS password must be entered every time you turn on your Toshiba or wake your system from Standby mode. If you forget the password, you cannot boot your system. Prevent having to enter a password or the results of forgetting the password by removing the BIOS password from your Toshiba laptop. Other types of passwords can be set, such as a Windows password, to prevent unauthorized access to your machine.
1. Turn off your Toshiba laptop.
2. Wait 30 seconds and turn your laptop back on.
3. Press "F2" repeatedly as soon your Toshiba laptop begins booting until the BIOS menu screen appears.
4. Enter your existing BIOS password and press "Enter."
5. Press "F2" again to enter the BIOS, if prompted.
6. Use your arrow keys to select the "Security" tab in the BIOS menu.
7. Use the arrow keys to select "Set User Password."
8. Press either "F5" or "F6," depending on your Toshiba laptop model, to open the Password section.
9. Enter the current password into the "Old Password" prompt and press "Enter."
10. Press "Enter" when the "New Password" prompt appears. Do not enter any text in this box.
11. Press "Enter" again to confirm the new password.
12. Press "F10" to save your changes and exit.
I hope you find it very helpful. Best regards.
Aug 16, 2011 | Computers & Internet
How do i reset my laptops cmos battery i have a dell inspirion 5100
The Basic Input Output System (BIOS) on a Dell laptop is used to help hardware communicate with the operating system. You can change many different aspects of your Dell laptop's BIOS such as boot order, BIOS time, set a system password, and change certain aspects of how your hardware works. If you want to reset your Dell laptop BIOS to its original settings, you can do so by changing only one setting. This setting restores your BIOS to its default settings, no matter what settings you may have changed.
1. Restart your Dell laptop. Click on "Start," "Turn off Computer" and "Restart." 2. Press "F2" during the boot process to enter the BIOS. Press "F2" before the Windows loading screen. Certain models may use a different key. The key will be displayed during the boot process. For most Dell models, the key is "F2." 3. Use the "Alt" + "F" key combination to load defaults. 4. Press "Esc" on your Dell laptop keyboard to save and exit. 5. Choose the "Enter" key to save all changes and exit the BIOS screen. Allow your laptop to restart for BIOS settings to reset.
I hope that these steps help you.
Please rate me.
Thanks.
Aug 09, 2011 | Dell Computers & Internet
I had lost my Dell Latitude D600 Bios passowrd. So I removed the comos battery (behind main battery) and reinstalled it. But now my laptop is giving this message on bootup "invalid system...
  1. Set the BIOS to defaults:
  2. Restart your Dell laptop. Click on "Start," "Turn off Computer" and "Restart."
  3. Press "F2" during the boot process to enter the BIOS. Press "F2" before the Windows loading screen. Certain models may use a different key. The key will be displayed during the boot process. For most Dell models, the key is "F2."
  4. Use the "Alt" + "F" key combination to load defaults.
  5. Press "Esc" on your Dell laptop keyboard to save and exit.
  6. Choose the "Enter" key to save all changes and exit the BIOS screen. Allow your laptop to restart for BIOS settings to reset.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 22, 2011 | Computers & Internet
How to reset bios my dell vostro 1500 . (11R50G1-595B)
To reset the BIOS please follow the below steps.
1 . Restart your Dell laptop. Click on "Start," "Turn off Computer" and "Restart."
2 . Press "F2" during the boot process to enter the BIOS. Press "F2" before the Windows loading screen. Certain models may use a different key. The key will be displayed during the boot process. For most Dell models, the key is "F2."
3 . Use the "Alt" + "F" key combination to load defaults.
4 . Press "Esc" on your Dell laptop keyboard to save and exit.
5 . Choose the "Enter" key to save all changes and exit the BIOS screen. Allow your laptop to restart for BIOS settings to reset.
Thanks. Have a great day.
Dec 30, 2010 | Dell Vostro 1500 Notebook
Although Windows xp service pack 3 is loaded, I have no usb 2 function.
You have not stated your PC model and make. However, most of the PC when entering a BIOS after switching on, press F2 or DEL. Try to go to main then scroll by pressing arrow right if looking for components. Look for USB boot then click enable so that the system will detect your USB then strike F10 to save and exit. Wait to boot by itself.
Thanks
Nov 29, 2009 | Microsoft Windows XP Professional for PC
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
eMachines W4620 Notebook Logo
186 people viewed this question
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
