Question about Samsung Televison & Video
My samsung ws32z409t tv picture seens zoomed in and distorted,looks a bit better if i change ratio to 4:3 but unable to change it playing xbox on hd settings,is it worth repairing?
  • Anonymous Mar 22, 2014
    The brightness settings are set to low for me to see and I don't have the remote either. Plese Help
Do you have comcast on the remote is a hd zoom try that
Posted on Nov 15, 2009
I have purchased a Samsung Led 50 inches tv in USA, The picture is not displayed full on the screen. Can you please suggest?
These are generic instructions for all TV's and all Remotes:
1. Press 'Menu' key on Remote (or 'Setup' key).
2. Go to Setup, View, or Picture tab (whichever one you've got in your Remote's Menu or Setup)
3. Change your Zoom or View aspect.
NOTE: Depending on the dimensions of your TV, you simply may not be able to view the entire picture using a correct aspect ratio (NOT stretched). On my 42" RCA is use a 4:3 Zoom setting to fill my screen but, it chops a little bit off the top & bottom. It's the best I can do with my current setup.
Dec 17, 2014 | Samsung UN50H5203 - 50-Inch Full HD 60Hz...
Cannot get full screen picture. seems like I still have a 36 inch tv. It is a 42 inch LG plasma hdtv
It seems like you're expecting a 16:9 ratio picture. If you're sending a 4:3 ratio signal to the TV, you'll get a 4:3 ratio picture. An option would be to use the remote and set the TV to a 16:9 ratio picture, but that'll stretch the picture and make everything look fat. Another option would be to use the remote and zoom in, but that'll chop off the top/bottom of the picture a bit. Either case would be annoying. Some make matters even more annoying, some programs are broadcasted in a 16:9 ratio signal, but the actual picture is really 4:3 ratio. So...... as long as the pictures don't look skinny, fat, or chopped off, just accept it. If you're really that picky, just watch new Blu Ray movies only.
Jul 22, 2011 | LG Televison & Video
I have a Hyundai rear television HY5111W.I noticed that picture became distorted then disappeared. Can you help me fix it
Hello
Watching standard cable on an HDTV can be quite a shock; the images are likely to be in a smaller aspect ratio, and have grainy or pixelated distortions. Additionally, the use of non-HD compatible devices, such as a DVD player, VCR, or older gaming system, will produce a less than stellar picture.
If you've changed the aspect ratio or your television, or have changed the zoom in or out, you may be encountering distortion that would otherwise not be noticeable. Setting the picture to a 1:1 ratio and turning off any overscan can help ensure a better quality image.
If you're using a system that supports HD, such as a Blu-ray player or an HD-compliant gaming system without the use of an HDMI cable, the image may be distorted. HDMI cables transmit both HD quality digital images and sound over one cable, and provide the best possible picture A/V signals.
Apr 11, 2011 | Televison & Video
LG 50" the pitcher is off the screen each side by
Ok, first make sure you or someone in family didn't hit the "HD Zoom" on your cable remote or whatever kind of remote you have. On ours - Cable- if you hit it once it is in "Normal" picture which on ours has black around edges on a non Hd channel. Then if you hit it again it Zooms once makes pix very large and if you hit button a third time brings it into a wide screen Zoom that fills the Tv screen. If we are viewing HD channels I put it on Normal which will fill the screen and give you the best HD pix. If we are viewing a NON HD channel, then normal will have black on sides, so I hit the Zoom a couple times to fill in the screen. My brother in law had this problem and couldn't figure out why his Sports channel Scores were always half cut off the screen! it was zoomed in too much for that channel. His sports channel was in HD so needed to be on normal instead of zoomed in.
if it is not the Cable remote then this is a second possible cause:
The other thing that happened to me was - we hardly ever use our original TV remote that came with the TV. but one day our picture looked weird and the cable remote didn't adjust it. One of us had hit the "P SIZE" button on the TV remote. this changes your pix from - 4:3 ratio to 16:9 ratio and vice versa. I put clicked that button and on the TV it shows whether it is at 4:3 or 16:9. For newer wide screen TVs you want that set at 16:9 ratio.
All cable company remotes probably are a bit different so check with your company ... to find out where the zoom control is on their remote.
Feb 27, 2011 | LG Televison & Video
How to zoom in on info
When TVs first appeared, they had an picture ratio of 4:3, which matched that of most movie screens at the time. Terrified of losing their business, movie studios struck back with "widescreen" films using 1.85:1 or 2.35:1 ratios. When widescreen TVs started appearing, they emulated those same ratios, but many TV shows (and some movies) were still in 4:3---and we were eventually left with a bit of a mess. Canny manufacturers, including LG, have solved the problem by allowing you to adjust the picture ratio on the TV to fit the program you're watching. If it's not set properly, however, your image will look distorted or cut off. A quick bit of troubleshooting can fix the problem easily.
  1. Press the "Menu" button on the remote and scroll down to the "Option" title (it should be second from the bottom ). Then select "Aspect Ratio." You should see a list of ratio options. You simply need to pick the one which fits the show you're watching.
  2. Choose the 4:3 ratio for older movies and TV programs. You should see a pair of bars on the left and right side of the screen. (That's okay: the bars keep the program in the same proportion in which it was filmed.)
  3. Select the 16:9 ratio for widescreen movies and for more recent shows to match their longer width. For some movies, you may see black bars and the top and bottom of the screen. Again, that allows the movie to be shown in the manner it was filmed.
  4. Pick "Set By Program" to automatically switch the LG TV between 4:3 and 16:9 to match whatever show is on at the time.
  5. Select "Horizon" to horizontally expand the image onscreen. It will fill the whole screen---eliminating the black bars to the left and the right---but it may look distorted.
  6. Use the "Zoom 1" option to zoom the image forward. That will eliminate the black bars at the top or the bottom of the screen, though you will cut off the edges of the image.
  7. Pick the "Zoom 2" button to select a midway point between "Horizon" and "Zoom 1." The picture is stretched, but not as much as with "Horizon," and fills the screen, but doesn't cut off as much as "Zoom 1."
  8. Use the "Cinema Zoom" button to enlarge the picture to fit the screen. This option allows you to adjust the proportion to your liking, rather than use the set proportions of the other aspect options.
  9. Exit the menu when you are done and watch your programming normally.
Feb 04, 2011 | LG Televison & Video
How can I get full screen image without distortion on tv viewing? I only get 4:3, zoom, full and justified. Full looks stretched horizontally with tv, looks ok with dvd.
Hello
Most of the telivision transmissions are comes at an aspect ratio of 4:3. Wide aspect ratio is 16:9. If you try to see a picture with aspect ratio 4:3 to wide 16:9, it will look like stretched. it is not the fault of the tv. Most DVD recording have the aspect ratio of 16:9 [Wide]. This aspect ratio will be displayed correctly when your tv is also set to wide mode. If you select normal mode at this condition, the picture will be displayed elongated. Ok Your Tv has no probelm.
Oct 19, 2010 | Panasonic Televison & Video
Picture stretched on samsung ws32z409t tv
Sometimes on a remote theirs a zoom button or HD zoom if you pressed that the tv will do what you describe if you press it again it will go back to normal view.
Jul 27, 2009 | Samsung WS32Z308P 32" TV
Xbox picture gets cut off on the sides
try fiddling with the tv menu. most tvs have the zoom function now and also the ratio function. try testing those configurations starting from the default. make sure you have the zoom function set at 0 before fiddling with the ratio aspect.
Aug 14, 2008 | Samsung TX-R3075WH 30" TV
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
The picture has shrunk - maybe 720P vs 480P?
make sure your hd cable connection from your cable box is going to an hd connection to your tv.[via hdmi, dvi,or componant.] if you have a different hook up such as rca out or coax out, these are not hd connections and you are probably streching out the picture.look at the rear of the tv & cable box and see how the connections are.the hd hook up to the hd input should make the picture the right size only if it's set on the hd input channel.hook up the dvd player to a aux/line in or video/source input and try changing the picture size. you may have to play around with it till you get it the way you want.
hope this helps.
wg
Feb 06, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
614 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
