First we need to know what brand we dealing with and usually the light flush so many times and repeats it self again count how many times it flashes that would be your error code message
CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a "dead" keypad/console)
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing. If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
