Roger Lundeen Posted on Jun 28, 2017
I am not able to log in - In Office Equipment & Supplies
tip
The Log function!!
I calculators you can't change or set the base of 'log' is default 10 so you need to know these:
log x (base y) = log x / log y
when log x it's automatic log x (base 10) here some examples:
log 8 (base 2) = log 8 / log 2
log 27 (base 3) = log 27 / log 3
and the base it's default 10 again, and that is how you need to use it in calculators(no bases), and here the explanation to this:
log x (base y) = log x (base 10) / log y (base 10) = (log x / log 10) / (log y / log 10) = (log x / log 10) * (log 10 / log y) = log x / log y
here so other stuff about 'log' :
log (x*y) = log x + log y
log (x/y) = log x - log y
Hope it's helped
2log(base4)x + log(base4)3=log(base4)x-log(base4)2
It is easier to use the rules for logarithms to clean this equation before trying to solve it. And the calculator is no help here.
Let me represent the logs as follows log b in base a = log(a,b). The first argument is the base.
2*log(4,x) - log(4,3)= log(4,x)- log(4,2)
Here you have two similar terms 2*log(4,x) on the left and log(4,x) on the right. Gather them both on the same side, say the left. You have
2*log(4,x) -log(4,x) +log(4,3) = log(4,x)-log(4,x) -log(4,2)
which is equivalent to log(4,x) +log(4,3) = -log(4,2)
Gather the constant terms on the right, and use log(a) +log(b)=log(a*b)
log(4,x) = -log(4,2) -log(4,3) = - { log(4,2)+log(4,3)} = -log(4,2*3)
You get log(4,x)= -log(4,6).
Take the constant term to the left, while changing its sign in the process. On the right remains 0, which is also the log of 1 in any base So log(4,x)+log(4,6) =0 =log(4,1)
Use the rule log(a) +log(b) = log(a*b) valid in any base, to obtain
log(4,6x)=log(4,1) which is equivalent to 6x=1. The solution is x=1/6
There are a few other shortcuts to get the solution but I preferred to take a pedestrian, step by step, approach.
Hope it helps.
10helpful
2answers
I need help with a change of base formula problem.
It's simple here some logs:
log x base y = log x / log y
you just need to know that the default base of log in calculators is 10, so log x mean
log x base 10 = log x / log 10,
so write log x / log y for log x base y example:
log 8 base 2 = log 8 / log 2 that is how you write it on calculator, hope it was helpful
7helpful
2answers
How do you input a logarithm base into the ti83 plus?
You can't it's default 10 so learn this logs:
so just divide the logs
hope it helps
4helpful
How to calculate
It's very simple: the calculators have a default base 10 so that log x it's log x base 10 so here is some logs:
Hope it's helped
To solve the problem using log
Look the calculators has a default base 10 and you can't change it but you may learn this:
so instead input log 8 base 2 you need to input log 8 / log 2
your example answer is about 0.919... if i get right what did you write.
Glad to help :)
Find log(1-.2)
I don't get it but here some help with logs:
log x base y = log x / log y (when log x is default base 10 in calculators) and
the bases is default 10
hope it's helped
2helpful
Logarithmic functions
All calculators it's the same:
the default base in all the calculators is 10 so instead of writing log 4 base 2 you simply need to write log 4 / log 2
Hope you understand :)
1helpful
Using logs
Here something that would help you:
so log 24 base 2 it's log 24 / log 2 etc.
and if i get right what you wrote x= 10 ^ ( 3 * (log 5) ) if no inverse it it's easy really Hope it's helped you.
Top In Office Equipment & Supplies Experts
Paul Carew
vince
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
