I am getting a message that says 'Elevation Error' The treadmill runs fine but cannot incline.
SOURCE: my treadmill is stuck on elevation error. I tried
Hi ewalker99, did you ever find a solution to this problem. My Sole is doing the same thing. Thanks!
SOURCE: I have a Sole F63
Test the flexible cable from keypanel vs display board and tigh the connector from display board vs main controll motor board. Test the relais if there are. Test for open and close, and clean the contact with spray for clean contact. Watch the videos. Finally the display board can be faulty b) main motor board too faulty.
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnesshttp://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=relatedgood luck , sincerely God bless you.
E.CUADRA
MANAGUA, NICARAGUA
E7-
1) Alternative Elevation Motor
1)Cause:
Elevation Motor not moving Solution:Check
Elevation Motor connection
2)Cause:
Elevation Elevation Motor screw binding Solution:
Clean screw and lubricate
3)Cause:
Elevation Motor Motor out of Range Solution:
Check motor out of elevation
4)Cause:
E-Motor Potentiometer: Solution:
Replace Elevation Motor
2)Alternative:
Display
Doesn't Light Up:
a)Cause:
On/Off switch Solution:
Test unit is turned on b)Cause:
Insufficient Power Source Solution:
Plug
dedicated120V, 20Amp Outlet
c)
Cause:
Line
Cord Damaged Solution:
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
ERROR
CODE # 7
E7-
1)Cause:
2)Cause:
3)Cause:
4)Cause:
2)Alternative:
Display
Doesn't Light Up:
a)Cause:
Plug
c)
Cause:
Line
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
ERROR
CODE # 7
E7-
1)Cause:
2)Cause:
3)Cause:
4)Cause:
2)Alternative:
Display
Doesn't Light Up:
a)Cause:
Plug
c)
Cause:
Line
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
