SOURCE: re: Maytag dishwasher
does the timer advance the control knob? check to see that nothing is in the way of the center spray tower. does it sound like any water is spraying around inside?
SOURCE: Dishwasher not spraying
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Good luck!
SOURCE: kenmore elite dishwasher noise
I had the same problem where rubber gasket that seals the motor bearings leaked water into the bearing and rusted out the bearing.
I scrapped the motor into every little pieces and extracted the bearing and just replace it. Now it is quiet as a mouse.
You need a bearing puller to get the bearing out for about $20 and the bearing is $6.
During the repair i slightly bent the shaft and i didn't straightened it properly so it wobbles a bit. But it works and if really quiet.
SOURCE: Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
SOURCE: dishwasher motor makes like a grinding noise on start up
Hi. This grinding or hum can be associated with internal electric motor failure. the grinding and humming sounds are warning signs that will ultimately, lead to total failure.The actual term we in the industry use is A.C. hum. This will occur when the internal electric motor windings begin to break apart from the center housing inside the motor casing. this will disrupt the current flow, causing over heating. the grinding is because of the alignment that has been disturbed as well. The solution is to prepare for the replacement of the electrical motor or, you can repair it.
please rate and have a great day.
