SOURCE: ADMIN PASSWORD RESET FOR NORTEL T7316E SYSTEM
If your company extentions are 2 digits long enter "120000"
If your company extentions are 2 digits long enter "1020000"
If your company extentions are 2 digits long enter "10020000"
SOURCE: T7316E Voicemail Password Issues
Feature 983
password is: 1020000 (if you use 3 difit extensions)
OR
120000 (if you have 2 digit extensions)
SOURCE: I can not change the Auto Attendant Message
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
SOURCE: T7316E forgotten password - need reset
sounds like you might have a BCM 50 Try feature 983, id:738662, pswd:266344. Hopefully the password wasn't changed.
SOURCE: Can't get into Auto Attendant
Feature 985 Press 9 enter 73738767793. That will reset the log in to 1020000. Good Luck
