Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Leaking water at the plastic part connected to Intake hose, on top of washer
I figured out how to open the front/top, and started a load to watch for water. Nothing at the bottom...the source is some water leaking out of some plastic connecter-looking item, that is just under the "hood", which seems to be a junction between the small intake hose above and the large hose beneath it. There are actually small square holes in this plastic device, that seem to belong there. Everything is snug tight, no breaks or anything obvious, other than these squirts of water. Any suggestions?? Thanks!
  • 3 more comments
  • Jan_H Mar 11, 2008
    I have the exact same problem and I was wondering if the hose is supposed to cover those square holes. What are they for? This problem only started a couple of weeks ago and is getting worse. Is the lower hose plugging up or something? My model number is JWP21000.
  • lucyshoes Mar 13, 2008
    Hey Jan....the prob was easier than you'd think....Those holes are supposed to be just where they are. However, I verrrry carefully disconnected & removed this little siphon break to clean it out with some vinegar/baking soda solution and a good stiff toothbrush. Only needed some of the "gunk" cleaned out, then reconnected everything back exactly as it was. Even went and scrubbed a little ways into the hoses, and all leaking stopped.
    The trickiest part is wrestling with those spring-squeeze components that hold everything together (I found a pair of adjustable pliers works well), or whatever tools you work well with, have at hand...and make sure you have towels around and/or a way to hold the hose (bottom one) upright , once you loosen everything, as water dumps out when it tips....Just a little bit of dexterity & balance, minimal cussing and sweat on this one. Hope this helps!
  • lucyshoes Mar 17, 2008
    Your welcome, so glad I could help!
  • Jan_H May 11, 2010
    Lucyshoes, I just wanted to tell you your solution to my water leak problem worked perfectly. Thanks again
    I found out this plastic part is the siphon break but I can't understand why it is so open that the water flows out of it. Is the hose up far enough? What can I do to stop the leak? I really HATE using the laundramat.
Thanks for you quick response lucyshoes. I will try that.
Posted on Mar 13, 2008
Water leaks when washer is filling up
The hoses are locted in the back do not open the top you may need to just replace the hoses,check intake selenoid
Jul 05, 2010 | Maytag MAV7580E Top Load Washer
Duet front load - water fills while door is open!
This is a leaking solonoid valve.
The valves are located just inside the machine where the water supply hoses attach.
  • Remove the power plug
  • Undo the top lid of the washer
  • The valves will have some internal pipes clamped on their outlets. Remove the pipes.
  • Dry the valve outlets with tissue.
  • Turn on the water supply to the washer (if it was off)
  • Watch the open valve outlets for seepage.
There may be between 1 and 3 valves depending on the model.
You should be able to replace the leaking valve quite easily.
Nov 02, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Leaking whirlpool washer
Probably the pump seal - you need to replace the pump, which is located at the front.
Apr 20, 2010 | Whirlpool LSR5132PQ Top Load Washer
Leaking water from under the washer, the hoses are all dry at the connections. leaks immediately when filling the washer,
There is no way to know until you take the back off the washer. It could be a connection inside the back, the pump, or a plastic hose connecting to the pump etc. Knowing if it is a top or front loading washer might help to diagnose as well.
Mar 06, 2010 | Whirlpool Washing Machines
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
About 1 minute into the cycle water starts running out from underneath of the washer. Checked all the hoses that are connected to the back and none are leaking
this is either the front seal that goes from the outer tub to the front of the washer or a hole in the outer tub itself or one of the hoses underneath the seal and the hoses are easiest to check you can take a cup of water and slowly pour it into the front seal. take care not to overfill it to where it spills into the tub and see if you are getting water on your floor from that. the hoses tip the washer up onto its back and look at them from the bottom for any cracking etc. the tub itself can only rust out on some of the neptune models or on others is plastic and can get punctured. just have to look for damage with a light and a mirror.
May 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Water leaks
If there is water leaking from under the washer, then you have a water leak from one of your water hoses. Check the back of the washer, where the water comes into the washer, to see if its leaking water or the hose is cracked. If its leaking water from the intake hose, then unscrew the hose and check the rubber washer, to see if it needs reolaced. Sometimes those rubber washers get cracked or broken. If that doesn't help, unplug your washer from the power cord and unscrew your intake water hoses and flip the washer gently on it's side and check the water hoses under the washer for leaks or cracks. Replace the hoses if cracked. Your local hardware store should have replacement hoses. This should solve your problem, but if not, then you need to call a washer repair person to look at it. I hope this helps.:)
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water under front loading machine
you really have to open up anything that you can see the inside to watch where the water could be dripping. check if you can open the back panel or the top cover, just to peek inside.
could be on a loose hose or a broken hose or a water pump seal leaking.
tnx 4 using fixya,
Oct 18, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing machine Whirlpool Lsn1000pq1
My washer is doing the same thing. I put it up on blocks so I could see where it was leaking from. On mine it was leaking from the pump which a big white piece of plastic in front of the motor. The pump has two hoses connected to it the **** the water out of the tub and pump it out the drain hose. Disconnect the two hose clamps, remove the hoses (use force). There are two spring clips on top and one bottom. I laid mine on it's side to remove them. There two slots one top, one bottom for you to use when prying the clips off. Place screwdriver under clip and between grove and push/pull until they come off. Carry pump to the sink, fill with water and see if it leaks from somewhere, should be obvious.
Jun 01, 2008 | Whirlpool LSN1000LW Top Load Washer
Maytag front load washer leaking water from detergent dispenser
The other end of the dispenser to outer drum hose only connects to the outer drum and if you remove the top cover of the machine, you will see it clearly. You can unclamp the hose from the bottom of the dispenser and feel inside the hose for any obstruction. Do not remove the hose from the outer drum. Pour some hot water down the hose and squeeze the hose from top to bottom to remove build up of detergent and softener on the inside walls of the hose.
Oct 28, 2007 | Maytag MAH6500 Neptune Front Loading...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
101 people viewed this question
Dan Webster
Dan Webster
Sal De
