SOURCE: CD Player not playing any audio CDs
The laser is damaged or dirty. Try gently swabbing the lens with rubbing alcohol and drying with canned air. If this fails the laser is damaged and unrepairable.
SOURCE: Emerson PD6810 CD Boombox Error
My older model PD6810 had the spindle that holds the CD on the player missing causing the ER message to show and the player to stop working.
SOURCE: cd player is not working
?: Does the cd spins? If it does the optical eye that reads the cd could be dirty. Clean the eye with cd lens cleaner. If the cd is not spinning the motor could be bad. Also some cd players can't read certain disks because of the density of the disk. Make sure you read the manual to see what cds are compatible with your boombox. I hope these solutions were helpful.
Good Luck
George
SOURCE: 2003 audi a6 cd player error 2
HI,THE REASON YOU ARE GETTING AN ERROR MESSAGE IS BECAUSE THE MECHANISM IS FAULTY,YOU WILL HAVE TO HAVE IT REPAIRED,ANDY
SOURCE: 2002 Ford Explorer CD player error
First get a CD Lens Cleaner and try it; if not, disconnect the negative lead from your car battery for about 10 min. BUT! Unless you have the radio code make sure you car radio doesn’t have a anti-theft system; if after this few steps still nothing you have to send it to an electronics repair shop (the CD Lens is bad).
