Question about GE Dishwashers
GE Profile dishwasher; arms do not spin
I have a GE Profile dishwasher PDW7880J10SS which does not clean dishes. It appears that the upper and lower spray arms do not spin while operating but spin freely by hand. This was determined by positioning the arms at the 12 o'clock, closing the door, listening for the motor hum, and then opening the door to realize that the arms have not moved. The washer does go through its cycles as normal (fills, the motor hums, drains, and dries).
What could be the problem(s)?
Unfortunately, I am currently disabled and recently lost my job. Any help would be greatly appreciated.
Thank you!
JB
  • 11 Answers
SOURCE: water not going through spray arms
1.does motor run? no. replace motor. 2.open door and leave the bottom rack inside dw.spin the spray arm underneath the bottom rack by hand. it should spin freely without binding. if it doesnt spin freely take out the bottom rack and try again. if it does spin freely then your bottom rack is laying on your sprayarm preventing it from rotating. 3.you could also not be getting enough water into your dw.
Posted on Mar 22, 2007
Have same problem except big motor spins independent of stripped? impeller. tried to reassemble but seems mechanical or adhesive agent misssing from one shaft or the other and the motor spins the impeller (now tight) only to have it slip off again and stop pumping water.
Posted on Feb 04, 2008
SOURCE: dishwasher pump will drain but not force water into spray arms
If the washer is not used regularly the shaft can stick to the seals and prevent the motor from spinning. This happens quite regularly for me if I don't use the washer often. You can just take off the bottom panel - after shutting off power to the dishwasher - and access the motor. you should see some fins and then just try to spin the motor by hand. It usually takes about 90 degrees of rotation before the motor breaks free from the seal. You'll have to fight through the spring-like resistance created by the seal-shaft adhesion. After it breaks free the motor spins freely and you should be all set to go. I haven't found a more permanent fix for this other than running the dishwasher more regularly.
Posted on Feb 09, 2008
watugot
  • 290 Answers
SOURCE: dishwasher - no spray arm action
If it is filling with water properly then it sounds like the chopper screen is clogged so that water isn't getting into the pump. You can remove the top of the pump housing and get to the screen and chopper blade to inspect it. Go to sears.com, click on parts and enter your model number and you can view a diagram of the pump parts to help in disassembling it.
If the pump is not clogged then you have a problem with the impeller or motor. If this is the case you can replace the entire sump assembly just about as cheap as replacing individual parts of the pump.
Post back with any questions.
Thanks, Mike
Posted on Feb 16, 2008
reg501
  • 413 Answers
SOURCE: water not spraying hard enough
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Posted on Jun 08, 2008
Why are hype dishes on the top rack of my Ge profile dishwasher dirty? The upper two arms do not spin, but the lowest one is strong
There is a plastic filter down inside the pump inlet that clogs up on these. It can be difficult to remove without breaking things. d26b8b16-9f7c-47f1-863b-1baebb58de21.jpg
Aug 07, 2014 | GE Profile PDWT180VSS Fully Integrated...
GE Profile mod. # PDW7880J10SS not cleaning, leaves film
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Nov 04, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
The upper and lower spinning arms in the washer do not appear to spin at all. Water comes out of the lower arm but not forcfully at all.Not cleasning dishes and leaving soap residue all over.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Feb 02, 2011 | Asko D1876 Dishwasher
We have an Asko D3350 Dishwasher and the upper blade does not appear to be spinning and the dishes are not coming clean. Bottom appears to be working fine and dishes on bottom are clean. What could be the...
On my d3350 it is possible to choose which tray (bottom, top or both) is cleaning.
The button is the bottom left, and above it there are two lights. As you push this button, the lghts cycle through lower tray, upper tray and the both trays. You want both lights on.
Also try this - take the spray arm out (it just snaps free) and rinse it out in case there are some blocking materials in the arm which are stopping it from spraying
Dec 30, 2010 | Asko 24 in. D3350 Dishwasher
Our Ge profile Dishwasher is not cleaning the upper level dishes, mostly glasses and coffee cups. The insides are bumpy with dried on food. We have cleaned the bottom filter.
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Oct 24, 2010 | GE 24 in. Profile PDW7800 Built-in...
We have a GE dishwasher with upper and lower sprayers. The upper sprayer (one located right under top rack) won't spray or turn which leaves the dishes in upper rack dirty, any suggestions on how to fix...
try c.l.r. to clean dishwasher check and clean lower and upper spray arms out, run no detergent you can also run vinegar in it as well about a cup full,let the machine start to run then stop dish washer for a few hours then restart see if this works for you use a short cycle.
Dec 01, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Upper rack is not cleaning. Greasy dishes on top seem that dishes are not being washed. Seems the upper water turning dispenser is not working, Bottom rack seems ok. I guess I only have half a dish washer...
Check the upper arm for free spinning, then remove the arm and check that the seam between the upper and lower halves has not split somewhere. Also check all the small holes for debris plugging. Run the machine in wash cycle for a little while with the upper arm off--that should flush out anything blocking the pipe up to the arm. If still nothing from the upper arm, tear down the lower arm assembly down to the deck while noting position of all parts removed. Clean the big screen at the bottom in white vinegar and hot water. Inspect the holes in the bottom for anything blocking them.
Aug 15, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Rotating arms getting clogged very frequently
I do not have a huge amount of information about the GE Profile PWD7880 handy, so I don't know if it has a chopper blade/food disposer at the bottom of your Dishwasher, but when a dishwasher gets the holes of the spray arm, the most common cause is the chopper blade is jammed/blocked. Then the food debris never gets sliced and diced at the end of the of each wash cycle.
Opening up the filter under the spray arm, removing as much of the lower assembly and inspecting every where in the sump area, especially the drain pump area would be a great beginning.
Good Luck! Just ask if you have more questions.
Apr 04, 2009 | GE 24 in. Profile PDW7800 Built-in...
Washer arm not working
If your dishes are getting clean, then your problem is a "feture" not a failure. The LG LDS5811 has a Verio motor/check valve that switches between cleaning the upper dishes and then the lower. Depending on when you open the door, one arm will not be spinning.
All the presure is routed either to the lower or upper arm, so it really does help - especially with a water conserving model like the 5811.
Good Luck!
Mar 06, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Wont clean dishes
Check to see if the Upper and lower spin arms rotate easy .. check to see if there is anything blocking them.. also check the venturi assembly (the tower is in the center of the lower spray arm} As it is what supplies the upper spay arm. let me know if this helps?
Mar 06, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
Dishwashers Logo
437 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
