Question about Robotoolz RT-5250-2XPK ePlane XP High Power Automatic Leveling Laser and E
RT-7610-5 turn the calibration screws and nothing changes......
Hi ...i turn adjustent screw and nothing changes....i have two of theses electronic five beam levels and cant get eather of them to adjust.....turn the adjustment screws and nothing happens .....also one of theses is out out of adjustment to an extream, while the other is only out a tolerable amount. model RT-7610-5
3 Suggested Answers
  • 10865 Answers
SOURCE: the self leveling does not
hi chapelhillco. Remove the batteries and clean the contacts with the eraser end of a common pencil. Then clean the contacts on the batteries and reinsert them. This may solve the problem.
Joe
Thanks for choosing Fixya!
Posted on Nov 29, 2010
  • 5603 Answers
SOURCE: I have a 5 beam
The bearings are likely damaged or dirty. Take this to an instrument repair facility.
Posted on Jun 10, 2011
How to calibrate oven?
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element
Dec 01, 2016 | Ovens
Low beam headlight adjustment on 2011 Chrysler 200
How to Adjust Car Headlights Level your car. Start by removing any excess weight from the trunk of the car. Also, ensure that the tire pressure in all tires is at the manufacturer's recommended levels. If possible, have somebody sit in the driver's seat, and that the gas tank is half-full. As well as this, check that your headlight aim adjustment wheel (if fitted) is at the zero position. Position your car. On level ground, park 10 to 15 feet (3.0 to 4.6 m) from a dark wall or garage door, with the front of the car aimed at the wall. A paved parking lot or level driveway is best Turn the headlights on. Do not use your high beams or fog lights. Mark the horizontal and vertical center lines of the headlight beams with masking tape to make two T's on the wall or garage door.Make sure the lights are level. Place a carpenter's level between the two marked center lines to see if they are even. If they are not even, use a tape measure to measure how far up the wall the lower mark is and lower the other center line marker to the same height. These center lines should be no higher than 3.5 feet (1.1 m) from the ground.Back your car exactly 25 feet (7.6 m) from the wall or garage door. Don't estimate the distance! Use a tape measure to make sure you are the proper distance away from the wall. Turn off the headlights. Remove the trim ring from around the headlights and locate the adjusting screws. These screws are typically found adjacent to the headlight, though some manufacturers put the screws in the engine compartment, behind the the headlights. The horizontal adjuster and the vertical adjuster should be marked.
  • Always defer to the specs in the owner's manual-Adjust each headlight separately. Block one with a sweatshirt or other object while adjusting and testing the other, since the light-bleed can make it difficult to distinguish one from the other. Have a helper sit in the driver's seat while you do the adjustments, to turn the lights on and off while you make the proper adjustments
Sep 30, 2016 | 2011 Chrysler 200
Left low beam of my A4 model 2011 is very low, how can I adjust to higher level
place the car 3ft from a reflective wall turn the lights on to high beam and adjust using the adjuster screws at the back of the light. Low beam is part of the high beam so when high beam is set then low beam will be correct.
Dec 26, 2014 | Audi A4 Cars & Trucks
Pronto not getting hot enough
need to calibrate the thermostat, usually requires unattaching the thermostat from the unit and adjusting the calibration adjustment screw or lever (older units), if electronic sorry cant help ya as i am an old school tech
Jul 09, 2012 | Microwave Ovens
I changed about everything,cylinders calipers,shoes,pads,and new rotors. then after following correct bleeding proceedures still no pedal.oh, and no e- brake either .what the heck am i doing wrong?(1991...
If you have no e brake that tells me your problem is something to do w/rear brakes. Pull your re brakes back apart and make sure everything is seated properly. Sounds like you didn't adjust rear shoes out far enough. Double check rear adjustment THEN bleed again - rt rear -> lft rear ->rt frt -> lft frt.
Mar 14, 2011 | 1991 Toyota Pickup
How do i calibrate the scotts speedygreen 2000
Your SpeedyGreen 2000 Rotary Spreader spreader was calibrated at the factory. However, a spreader's calibration may change or slip during periods of frequent or heavy use.
You may check the calibration by using the following directions. First, adjust your micrometer setting to 2. Squeeze the trigger against the handle. The calibration line is a small, raised line embossed on the top of the spreader's shut-off plate. With the micrometer set at 2 and the trigger squeezed against the handle, the calibration line should be aligned with the back edge of the hopper opening.
To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel. Adjust the screw until the calibration line and back edge of the hopper meet. If you have any difficulty checking the calibration, contact us and we will be happy to help walk you through the adjustment.
When you are not pulling on the trigger handle, the cable should be loose. When you pull on the handle, the cable becomes taut and the shutoff plate slides open.
If you have any additional questions feel free to contact Scotts directly @ 1-800-543-8873
Jan 24, 2011 | Scotts Company Garden
Oven is not holding correct temp
Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
When you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, and then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Let us know if you want something else please accept the solution.
Jan 02, 2011 | Maytag MGS5770 Gas Kitchen Range
Oven doesn't get to desired temp.
Hello there:
When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Hope this is very helpful for you please feel free to rate this solution it helps our askers get the best possiable solutions from our fixya staff
best regards mike
Dec 26, 2010 | Ovens
Takes long to reach it's temperature
Hello there
Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. bullet.jpg Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. bullet.jpg If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Aug 09, 2010 | Fisher and Paykel OS302SS, Stainless Steel...
Robotoolz RT-5250-2XPK ePlane XP High Power Automatic Leveling Laser and E Logo
563 people viewed this question
Top Robotoolz Measuring Tools & Sensors Experts
Jim Parker
Jim Parker
 Mikey
Mikey
Tom Chichester
Are you a Robotoolz Measuring Tool and Sensor Expert? Answer questions, earn points and help others
