Question about GE WJSR4160DWW Top Load Washer
Wash cycle dial wont turn...will still push in and pull to start
Worked fine last night..today dial acts like it is stripped...will push in and can be pulled to start and stop...but I have to manually turn dial...small circular plate under knob
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing the knob turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you will get easier access to the retainer clip. You can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Posted on Nov 04, 2009
This is another solution that doesn't involve any parts. My dial was spinning and would not engage. I noticed that when I tried to push the outer knob in to stop the machine, it had a lot of play in it. In fact it did. I removed the clip and the knob/dial, removed the console (3 screws behind it), and checked where the timer was mounted to the front panel. There is only one screw holding the timer to the front panel on the left side of the timer (facing the machine). The other side is held in by (you guessed it) a plastic clip molded into the front panel. The clip on the right side was broken, allowing the entire timer assembly to move when trying to change the cycle - giving the appearance the timer knob was worn out. Thanks GE for a 3 cent shortcut instead of another screw.
I fixed mine by simply running 2 stainless 6 x 1" sheet metal screws through the front panel into the standoffs on the timer assembly. The machine is such a piece of cheap junk that I didn't care about the appearance of the screws on the front panel, although they really don't look too bad.
Hope this helps someone else who made the mistake of buying this machine.
Posted on Sep 30, 2012
Kenmore 80 Series washer wont turn on from the push-pull knob.
On this type of washer, you have to push it in to engage the dial and rotate it slightly clockwise then pull it out to start filling.
Feb 11, 2017 | Kenmore Washing Machines
My bosch nexxt 100 series washer will not start. The spin, wash and finish indicator lights flash simultaneously when try to start.
Make sure dial is switched to 'off'. Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes. If if doesn't work, do it again.
To get the clothes out if you are having trouble, open door manually. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off. The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Click helped if helped.
Mar 07, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
How do I stop my Bosch logixx 8 from beeping endlessly at the end of a cycle?
hi, I found out last night after being wokenup by endless beeping.... start with program dial at " off position", then turn 1 notch to the right, and then press and hold eco-perfect button and turn prog.dial 1 notch to the right. a number will appear in the display. press"clock" button until number is 0. then turn prog.dial one notch more and do the same. all sounds are off now....
May 09, 2012 | Washing Machines
MAV4755A Top Load Washer: When I turn the dial to start wash cycle, nothing ...
if press button selection, make sure that no 2 buttons are pressed
Jan 27, 2018 | Maytag MAV4755A Top Load Washer
In mid cycle my daughter accidently lifted the lid to our Top Load washing machine. It did not turn on again and is sitting with water in it. What to do?
You need to reset your washer cycle. There is typically a dial that you push in and turn, then pull to start. If so, push it in and turn it to the start of a new cycle, then pull it to start the cycle. This should activate the new cycle and solve the problem.
Hope this helps! Rate my solution!
Jan 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Power wont come on at all
May be the power supply check for power to the power supply and the output voltage from it as well !! May need to be replaced ! It cost $125.00 for part and $225.00 for a new one installed !!
Jul 21, 2009 | Denon AVR-1506 Receiver
The rinse cycle does not work, but everything else does
I don't know if the problem is solved but last night we ran the washer without any clothes in it and everything seemed to work fine. My wife was able to run a load of laundry and it seemed to work. I hope it was just too much clothes the first time it stopped or the washer was just acting up. Either way, I had nothing to do with the fix. Sorry I couldn't be any more help. Thank you for the link to assistance plan, it might come in handy in the future.
Thanks again,
Sandro Micocci
Mar 30, 2009 | Kenmore Washing Machines
Washing machine will not start wash - just beeps - key on display
Press and hold the Rinse Plus button and wait for the washer to start emitting a tone.
Whilst you are pressing and holding the Rinse Plus button, the tone increases in volume from low to high and then it briefly goes silent, before it starts over agian.
If you release the Rinse Plus button immediately the tone goes silent, then this will turn off the beeping.
If you don't release the Rinse Plus button in time, just continue to press and hold the button and the tone will cycle around again from low to high to silent.
Hope that helps.
Dec 07, 2008 | Audiovox Bosch 718 World Cellular Phone
I have a technika diswasher,not sure of the model, is approx 3 years old and has a big dial on the left hand side with 7 wash functuions and the power button is smaller and is on the RHS. I cant remember...
I have the same model. You just turn the dial to the setting you want, push the dial back in, turn the (right) power button on then turn the smaller start button on. I use different cycles all of the time depending on whats in the load and this works fine for me.
Apr 27, 2008 | Dishwashers
GE WJSR4160DWW Top Load Washer Logo
475 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
