Question about InFocus ScreenPlay 5700 Multimedia Projector
Unit will not Power Up.
While pluged in the power LED continuously blinks to the beat of the fan on the lamp. The lamp fan is continuously running while unit is plugged in and it has a ticking sound which the power LED blinks to the beat of the ticking sound.
I push the power button and nothing happens. I'm thinking either the lamp is bad, or the power supply is bad.
Any ideas?
  • 8 more comments
  • lyman888 Dec 25, 2007
    I have the same problem. Did you come up with anything?
  • Anonymous Dec 27, 2007
    25/12/07 Exactly the same problem- cant get projector to come on at all- not good over christmas!!!! No sollution yet.
  • Anonymous Dec 28, 2007
    Mine did the same thing tonight.
    Last night it was fine.
    The manual says that if the lamp is out, the led should be red.
  • smokefjr06 Dec 29, 2007
    I purchased a new lamp @ $426 a pop and that was not the problem. Dang these lamps are expensive! So I called Infocus and if you have never called them for service, you're in for a treat. You have give them the problem and they estimate how much it will cost before you send it in. They charge you that amount up front. For this problem (which they thought was the power supply) was going to be $575! I thought YIKES!
    So, I first called around my town to see if anyone could put a power supply in and there was no one that would work on an Infocus. Next option was that I went to the web and found a place in Colorado that would fix it.
    The process is that you fill out a form and they give you an estimate and reference number for the repair. I went this route. They installed a refurbished power supply and it is a new type according to the repair person. New type in being that it is more reliable than the original one. Anyhow, the cost was $298.90. A whole lot better than $575 that Infocus wanted. They warranty their repairs for 90 days. It was right about 2 weeks from the time I sent the projector off to the time I had it back in hand. They seemed to be very professional about the whole thing so I would recommend them for sure.
    Here is their website address: www.justrepairs.com
    I only had 1350 hours on my unit and the power supply went out. I'm curious as to how many hours everyone else has on theirs. This looks to be common problem in which I think Infocus should address and take care of. When I talked to the repair person at Spectronix, it seemed to pretty common with the Infocus units. Sucks if you ask me. As much as I paid for this unit 4 years ago, it should not have quit on me at 1350 hours of use. I may just have send Infocus a little note about that.
    Hope this helps someone out. Good luck!!!
  • Anonymous Jan 03, 2008
    1/2/2008 - same thing. Noticed LED was faintly flickering with subtle clicking sound. Removed power and plugged back in .. now nothing. This 2nd lamp is less than 100hrs too. Movie on 1/1/2008 played great, so yeah probably power supply.
    All these within a week ... hmmm .... Planned obsolescence?
  • Anonymous Mar 11, 2008
    Yes, I had the same problem with the Infocus SP5700 and I also know another party too and their unit failed also. You are correct that Infocus just quotes an amount (for me $550) before they even know what the problem is but that assumes it's not optical. My unit will also not power up and just blinks the LED which they assume is the power supply. This is definitely a defective product and confirmed by a number of dealers.
  • Anonymous Oct 27, 2008
    I have tried holding down the power button this worked once.
    So it looks like the power supply
  • Anonymous Nov 20, 2008
    Exact same symtoms,1800hrs on unit, first bulb went out at 620hrs now the power supply, They rated the bulb 2000hrs to 3000hrs, so far nothings made it that long.
  • terryr6r6 Dec 08, 2008
    i have the same prob. seems to be when its left in stand by i unplug it for 5 min and it powers up when i try again
  • john745 Apr 26, 2009
    I also have the same problem. My unit has been down for over a year now. I purchased a new bulb, that was obviously not it. If this happened to this number of people, there are hundreds more. What do you think of a small class action suit against InFocus? This is rediculous, they should be paying for this.
Hi, we had the same problem... Bought a new lamp and then encountered the power light blinking repeatedly problem. After much frustration and anquish, we finally got it to work again... The way I did it was, take out the power cord from the back, then hold down the power switch and re-insert the cord. Somehow it made a difference to the unit and it powered back up all fine.. Cos we heard the fan come to life properly.
Cant guarantee it'll work for everyone but give it a try all the same.
Good luck
Posted on Jun 29, 2008
  • kfpsam Aug 03, 2011
    I just tried this...and it worked. At least for now...thanks!!!!
I have just had the same probelm and took it to B&H for an inpsection and quote for repair over $1000 AUD, tried a Sony repair place same problem, the costs for repair were stupid, trying to force me down the line of buying a new unit, so through investigation discovered there are various eletronic repair places, one guy looked and tested the board and apparently two capacitors on the unit had fried, cost $100 AUD, good as new....
So although its a little frustrating, forget the mainline service providers, go to your local eletronics shop, and get the boards tested
Hope it helps anyone.
Posted on Mar 13, 2009
Anyone ever find a solution to this
I have the exact same issue
I had already sent the damn thing in last year, good thing I purchased a extended warrenty and I got it in just in time
they stated they replaced the mother board power supply
and updated the software. Now last week I have what everyone else is seeing.
And as far as support WHAT A JOKE, That's a hole other issue in itself
Posted on Apr 17, 2008
Mine too. I'm on my second bulb..~1000 hours...noticed the LED blinking slowly when the unit was powered off. I took it down, swapped in the old bulb...flickering with the fan...put the newer bulb back in...flickering with fan/no power up.
THIS ALL TRANPIRED AN HOUR BEFORE THE SUPERBOWL!
Posted on Feb 04, 2008
Mine here too, and it worked yesterday, but not today with divisional playoffs to watch.
GO COWBOYS!
BOO INFOCUS.
Posted on Jan 13, 2008
12/27/07
Last night it was fine. What gives ?
The maunal says that it the lamp is bad, the led should be red.
Posted on Dec 28, 2007
2 Suggested Answers
SOURCE: Unit will not Power Up.
Terry, I had the same problem. Its a small capacitor on the power board labelled 'C16'(right in the middle of the board) its value is 16volt 100uf.
I also changed the biggest one on the board as well( 450volt 270uf @85deg). The big one was sourced through RS components @£5.14, the other I got through a maplins store for the grand sum of 13 pence.
Both are quite easy to change if your not adverse to taking the unit apart. (Just remember where all the leads plug in).
A torx T10 screwdriver, and soldering iron is all you need.
Posted on Aug 08, 2009
Power led is blink 4 times so how can i mentain?
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
turn on the projector ,at the same time ,if you can hear a continuous beep beep sound (the ballast igniting the lamp)
means the lamp may be fault,and other parts is working well
Lampdeng.com
Oct 08, 2015 | Electrified Replacement Lamp with Housing...
Power led and lamp led blink simultaneously on my jvc hd65s998 rear projection tv
You might need to replace your lamp driver, or ballast as some call it. This is what strikes the lamp to make it light.
Mar 20, 2013 | JVC Televison & Video
The power light continues to blink and will not go solid.
what is the projector issue? is the lamp not lighting? are the fans running? did you just replace the lamp? is the led red or green? need more info.
Dec 29, 2009 | Sharp XR-30S Projector
Jun 03, 2009 | InFocus ScreenPlay 5700 Multimedia...
Infocus screenplay 7200 fan failure with new lamp After powering on, red LED blinks 4 times which means fan failure of the fan that is part of the lamp module. Already returned initial new lamp and got...
Not sure if this helps with the 7200 bu had a 4805 with a failed fan issue. There are two fans inthe unit, one smaller one that cools the color (colour) wheel and the larger one that cools the lamp. This unit had a problem with the larger lamp fan not turning. Unplugged and disassembled the unit to get the fan out and tested the fan using a 9v battery and a couple of wires (best to uplug the fan from the controller board so you are not forcing voltage into the unpowered controller board... that said, I did it hooked up just peeling back the label in the centre of the fan and touching the wires to the solder contacts) The fan worked fine so figured the controller board was the issue, so this wasn't going to be a simple "buy a new fan" issue.
Here is where your mileage may vary...
I decided that it would be OK to just run the fan. Unplugged the fan and powered it from the 9V battery and assembled the unit and powered it up. Found that there was 7v available on the power board at the second pin that was alwasy on when the power switch was on (thats the positive 7 V pin, but measure it with a meter since we are talking about a different projector) and just wired the fan direct to pin 1 and 2 (1 is ground on the 4805, 2 is +7V) and so now whenever the main power is on the fan runs, so after ti cools down I just power off the main power when not in use... or let the fan run if the noise isn't an issue. Crude but effective fix.
Mar 13, 2009 | InFocus ScreenPlay 4805 Multimedia...
Sanyo PLC-XU47 seems to power cycle
Welcome to resolve the problem if you please say what are the solution to me the same problem
Jun 07, 2008 | Sanyo PLC XU35 Multimedia Projector
SONY VPL-CS3
Hi there
Replacing the lamp won't make any difference at all.
If you have checked the fuse on the Powersupply Board and it tested ok , then the whole Board will need replacement.
Apr 29, 2008 | Sony LMP-C121 Projector Lamp for VPL-CS3,...
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
JVC HD-ILA Projection TV
From the manual...
The POWER LED
and LAMP LED are
blinking
alternately.
• It may be a malfunction that the fan is locked or the temperature has increased.
The POWER LED
and LAMP LED are
blinking rapidly
simultaneously.
• The lamp may not have been installed correctly, or it may be due to a malfunction.
• The lamp door may not be closed correctly.
The LAMP LED
continues blinking
• It may be a malfunction of the internal electrical circuits
Feb 16, 2008 | Televison & Video
InFocus ScreenPlay 5700 Multimedia Projector Logo
552 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
