Question about Cyber Acoustics CA-3000 Computer Speakers
No sound One day i plugged in the green line into my XP'S Black line-in jack in the back and then the speakers started to fade in and out. i noticed that when ever i woulg bend the green part of the line in Jack it's self, it would work, but then it stopped working all together. I dont have the box or Warranty info and I have had these since december. Please Help
  • chrisanaru Jul 27, 2009
    thanks, but im not sure about the Warranty
  • 390 Answers
This a problem with the loose connectin in the jack i think the soldering has gone off or there is a breakage in the wires if it is still under warranty then i suggest u take it to the service guys
else just cut the wire a lil away from the jack and get a new jack soldered n things would be back to normal u can get this done in any radio shack nearby
Posted on Jul 26, 2009
    Scholar:
  • 63 Answers
That sounds to make like a break in the line, depending on how much you know, it would be possible to find the bad section and cut it out of the wire in the process known as "wire splicing"
Solution #1.
What you will need:
x1 Wire Nut - (splice wire cap)
x1 Wire Stripper - (optional - but recommended)
To do this, you would need to first find the bad section. This can be accomplished by having the speakers plugged in and putting pressure down on the wire until the speakers output increases. The area where the speakers pick up is where the break is, now you need to cut about 1/2 an inch to both sides of the bad area and then you need to peel the insulation off, or strip it off with wire strippers if you have the right size. After the wires are stripped you will need to place a wire nut on them. (Also known as "splice wire caps") This is done by placing both wires inside of it and twisiting the cap down. This insures that the wires touch each other.
I actually found a guide online for this if you'd like to take a look click here
In that guide, they patched it up by soldering it and using electrical tape, if you have a soldering gun then I would recommend that, but if you don't they can be expensive.
If this did not solve your problem please leave a comment and I'll get back to you as soon as I can.
How to connect my speakers to my pc
Just connect them at the green jack of your card.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 06, 2010 | Creative Labs Sound Blaster Live! 5.1...
Wharfedale s20030 speakers broken?
First, check input power (electricity) of your speaker. You can see lamp indicator on speaker (usually LED lamp, Light Emitting Diode, green light or else) must be light ON.
Two, jack line out (usually green) on the speaker, you must touch that jack. Don't worry, you can't heart attack cause of it (for touching that jack, DC-Direct Current supply). If you hear some noise, sound of droning, buzzing, that is indicate of sound will be come out from that speaker.
Three, you play WinAmp software (or Windows Media Player, from Microsoft) and get in one of mp3 file, and load it into WinAmp player. Make sure if your mp3 file is normally sound.
Four, plug in your green jack (of speaker) to the line in of your sound card (refer to mainboard PC, if your soundcard get in ONBOARD or plug in PCI slot). Green jack line of speaker to socket green of sound card.
Five, now you can hear sound of your song....
Sep 06, 2009 | Computers & Internet
No sound from external speakers system
Look into your monitor settings and computer settings and see if you can reverse the "input" and "output". If both are set to line in or line out then they pretty much cancell themselves out.
May 23, 2009 | Televison & Video
NO SOUND
They should be plugged in and turned on when you power up your system.They should be plugged into the green jack (line out). You then may have to check settings in control panel for your sound card's properties to see if digital only is checked. Try it both ways. Hope this helps.
May 22, 2009 | Boston Acoustics BA735 Computer Speakers
No sound coming through Toshiba Dynadock station
Try to plug in the speaker jack to Headphone jack on you laptop not to your docking station. So the desktop speaker is treated as an external average speaker. GoodLuck!
May 12, 2009 | Toshiba Dynadock Port Replicator, Docking...
No sound from speakers when in rear speaker port
you need to download the drivers, or check the volume control on the quink lanch in the right hand counter
Feb 14, 2009 | Dell 5650 Computer Speakers
Cannot connect my surround sound altec lansing system to my compu
The first thing you can do is go to www.retrevo.com to download the manual. Secondly all you have to do is match the colors of the wires to the imports in the back. You have five speakers. Two have gray wires, two have red and one has blue. If you also notice each speaker has two wires. One a solid color, the other striped with black. For instance, put the solid red wire into the red import and the red wire with the black stripe into the black import. Repeat this with all the other wires. The easiest way to hook it up to your computer or laptop is to take one of the aux wires (the wires with the yellow/green/black tips). It doesn't matter which one. Put into you headphone import on your computer or laptop. Then put the other side into the Aux on the subwoofer. Located on the front. Turn on the power on the back. Then hit the aux button on the remote. That should work....
If you have any other questions or need any more help you can contact me brown.faith@rocketmail.com
Jan 22, 2009 | Altec Lansing VS3251 Speaker
LOW VOLUME FROM RIGHT CHANNEL OF STEREO 1 SIDE OF SYSTEM
It seems like the speaker jack tip needs cleaning, or the contact has become bent away from the connector and needs to be re-aligned.  The Passport is a portable system, so after years of plugging and unplugging the speaker jacks may be worn.  Try using the "Stereo 2" connectors. You can also try cleaning the jack with electrical contact cleaner, and. a cotton swab.
Jan 07, 2009 | Fender Passport Deluxe 500watt Sound...
Continued No Sound on Acer Aspire AST180 desktop
9a52092048cbdae64a4b299e2e809cbd_page_05.jpg2cd1c16.jpgUse either the headphone or output socket as shown.
Nov 19, 2008 | Acer Aspire™ T180 PC Desktop
Cyber Acoustics CA-3000 Computer Speakers Logo
196 people viewed this question
Top Cyber Acoustics Audio Players & Recorders Experts
mukhtar21 shaikh
mukhtar21 shaikh
Carlos L. Burgos
Carlos L. Burgos
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
