Question about Toro Lawn Mower With Toro Power Tools
Yerf dog go-kart, engine wont rev when gas pettal is mashed
6 1/2 tecumseh motor idiles fine will move when the govonor is turned but does nonthing when gas pettal is mashed, cable is working fine
Jenx
True, but keep in mind, some engines require an air filter to run or even start. Too much air will dry the fuel before it reaches the cylinder. Which in turn results in "under-fueling".
Posted on Jan 08, 2012
    Scholar:
  • 173 Answers
This is probably, a timing problem.
check the plug, and the magneto.
Also, if you haven't already, make sure the air and fuel filters are in good order.
Have fun.
Posted on Jul 26, 2009
I have a yerf dog 6.5 hp motor go kart that the
Starter pawl or improperly wound string inside the starter housing most likely.
Sep 07, 2014 | Garden
5 hp tecumseh engine on manko go kart starts and idles high but when gas i pressed it stalls out
check for blockage ion the main jet and loose carby or bad gasket as you may be running too lean . Check float level is correct.
Sep 14, 2013 | Tecumseh Enduro Horizontal Engine 5 HP...
5.0hp tecumseh power sport wont start
you have to take the bowl off the carb and see if the Jets are clogged.
How long did it run before you shut it off?
Oct 04, 2012 | Garden
Yerf Dog Tricycle needs bearing.
not sure who sells the bearings,but i just fixed my little girls yerf-dog trike using BB's out of my daisy. they would only work on the bottom of the forks and was easy to do first putting new grease in the frame and sticking the BB's in to the bearing cuppling then sliding the forks in. good luck
May 23, 2012 | Radio Flyer 32s All-terrain Steel and Wood...
I have a Yerf-dog 3203 go-kart with a 6.5 HP Tecumseh engine. It's a pull start, and the pull cord broke. I can't get the cover off to fix the pull because the cover doesn't have screws. It has metal flat...
they are rivets, you will need a drill, the bit should be just big enough to fit the pin, once you start to drill it will come off. You can put screws back in once the repair is made. Good Luck Tim
Oct 23, 2010 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Engine works, but my car won't move when I give it gas.
Could be your clutch or the cable from the shifter has a plastic piece that is easily broken that wont allow proper gear placement
Jul 28, 2010 | 2004 Mazda 6
I was driving my 1999 beetle and it just stop moving. The engine stayed running but the car wouldn't move. Any suggestions?
may have bad gas pedal sensor, or throtle body motor, thats only if you step on gas pedal and engine wont even rev up, if it rev then possible trany problems.
Oct 01, 2009 | 1999 Volkswagen Beetle
Where the heck is the drain plug?! Yerf Dog Fun Cart 3203
The drain plug is located under the mower where the blade shaft comes out it may be covered in caked grass clippings scrape them of with a screwdriver or putty knife to reveal the square oil plug.
Aug 07, 2009 | Toro Lawn Mower With Toro Power Tools
Lack of power
The computer will not allow the car to full rev in park to protect the engine. Likewise there is a rev limiter when in drive which will shut down injectors at high engine speeds usually around 5000 RPM or so.
Mar 16, 2009 | 2005 Chrysler 300
Chyrsler sebring lxi 1995 2.5 v6 24 valve
ok this sounds easy when you ran the vehicle the computer controled the idiling motor now that you replace the idiling motor the computer hasnt been reset to except the new parameters
once you reset computer this should bring the idle back down to its specified idle
you can also adjust back of gas pedel the idle cable and on the throttle body by the idling screw
Jun 13, 2008 | 1995 Chrysler Sebring
Toro Lawn Mower With Toro Power Tools Logo
594 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
