Question about Sony Video Cameras
Sony handycam HC36 - Error message ''E:61:00'' (on LCD screen)
Sony handycam HC36 - Error message (on LCD screen) ''E:61:00''. Symptom(s): seems to be regarding 'Focus', when in camera-mode (playes back prerecorded Mini-DV tapes & memory card normally).
Cam will not focus, either in 'auto', 'manaul', or 'spot focus'. Additionally, 'Tele-Macro' does not fuction.
'Zoom' DOES work.
Have already tried 'Reset' button... (not resolved).
Owner's manual error code index says to contact Sony authorized service dept. I'm comfortable opening the cam, and attempting repair myself... if someone can suggest remedy to problem.
  • 76 Answers
SOURCE: Reinsert cassette error... cannot record via tape
What error message is it giving to you ?? as this will be a good indication of fault.You have tried all the usual things to try by the sounds of things,
Posted on May 15, 2007
  • 36 Answers
SOURCE: Black and white playback with sony handycam dcr-hc20
There is no problem on your camera, DCR-HC19E is PAL system(European system) DCR-HC20 is NTSC(American system). Are you in US or Europe? I think your TV is NTSC, cause the tape recorded on DCR-HC19E you played has no color. To confirm, connect your HC20 to TV in camera mode, not recording yet, just look at the TV as your monitor, If its in color, no problem, just erase the old video recorded on the HC19E, but if its important to you, you can convert it to NTSC using a PC. thanks
Posted on Sep 13, 2007
  • 169 Answers
SOURCE: SONY DCR-HC42 - auto focus will not work ???
that problem is on the lens assembly...one the two motor is not working properly...sometimes it is a poor connection to the socket of the main board...other is photo sensor of the lens(not the ccd image sensor)or the driver ic of the 2 motor...i suggest you have to go the service center for repairing you camera cause it need to disassemble the camera for doing this....
Posted on Oct 19, 2007
SOURCE: Video camera displaying Error code C:31:23
I have been fighting the same problem. I just now picked up the camera and a small rubber roller fell out of the tape door area. I was not sure where it came from but looking closer there are 4 small rods sticking up on the right side inside the area where the tape is located. It looked like this was where the roller went so I placed it on the center rod and replaced the tape. This solved the problem and I am now able to view and recored as before. There most likely is a part that has either fell or broken off or is loose inside the tape area.
Posted on Aug 03, 2008
  • 586 Answers
SOURCE: Unable to load tape
according to the symptom you don't need reset, This problem is related to the loading tape path which is mechanically unstable, that's why problem arise, For your convenience please see the given below pic of SELF DIAGNOSTIC SYSTEM to understand better.
Your camera needs just mechanical adjustment by any expert, contact any expert nearby or from Sony for mechanical adjustment, this will solv the problem.
Thanks for using fixya.
Posted on Jul 02, 2009
I cannot seem to upload video from my sony handycam model DCR-HC36. My home operating system is Windows Vista basic 32 bit. I've tried downloading things but it never seems to locate the needed...
You should not need additional drivers if you have Windows Movie Maker on your machine, it's standard kit for Vista.
Connect with a firewire cable and open WMM and capture from the tape. Firewire is also known as iLink or IEEE1394a.
May 22, 2011 | Sony Handycam DCR-HC36 Mini DV Digital...
Cannot playback tape on Sony DCR HC36
Have you try cleaning tape? Sometimes, it is just a dirty head. Try to clean it, see if it helps.
Jan 06, 2010 | Sony Handycam DCR-HC36 Mini DV Digital...
LCD DISPLAY SCROLLS Sony Handycam DCR-SR62
Had the same.after stopped showing anything and the rest was working perfectly. Changed the flex wire connecting camcorder and it's like new. got from the repair shop and did it by miself. Good luck
Meggita
Aug 04, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Flashing error message C:31:23
Hi Jazzy,
Please see the detail below for the said error codes C31:23.
According to the symptom and self diagnostic system the problem is in mechanical section (tape loading section) Therefore camera just need mechanical adjustment and will work fine again. This problem aries when the insertion of the cassette is improper or forced insertion.
Jan 09, 2009 | Sony Handycam DCR-TRV240E Digital...
Microphone
DCR-HC36 doesn't have External Mic option. Sound can be recorded only with built-in mic.
May 30, 2008 | Sony Handycam DCR-HC36 Mini DV Digital...
Still photos
you have to buy a memory card first then you turn the mode to where it says CAMERA MEMORY then you hit the photo button
Nov 22, 2007 | Sony Handycam DCR-HC36 Mini DV Digital...
Sony Handycam DCR-HC36 wont playback on TV
if the sound is coming out on tv then the video cable has to be replaced. (You did not tell if the sound is coming out on tv)
Jun 25, 2007 | Sony Handycam DCR-HC36 Mini DV Digital...
DCR-HC36 E UNABLE TO CREATE VCD
First of all create a image on pc of what you want to record edit it then record
Feb 07, 2007 | Sony Handycam DCR-HC36 Mini DV Digital...
Video Cameras Logo
729 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
